I sunk my boat!
This forum is for the discussion of outdoor activities, other than trail rides
Re: I sunk my boat!
Postby Hack » Tue Jul 05, 2016 8:43 am
My fingers are crossed!
Mario
Trail Truck: 2001 Amigo, Auto, 3.2L, Rear LSD, Front Aussie Locker, HD Torsion Bars, OME 912s, BFG M/T KA2 33x10.5R15
Hack
Have thanks: 119 times
Re: I sunk my boat!
Postby imamonstertruck » Tue Jul 05, 2016 9:03 am
Wow Mark! Meticulous as always, looks great!
Does tge boat float?.... :D
Cheers
-Ian :blackeye:
1989 Trooper RS http://forum.planetisuzoo.com/viewtopic.php?f=15&t=81642&p=722882#p722882
Previous Troopers and Build Thread->http://forum.planetisuzoo.com/viewtopic.php?f=15&t=63260
imamonstertruck
Has thanked: 49 times
Have thanks: 164 times
Re: I sunk my boat!
Postby squatch » Tue Jul 05, 2016 11:09 am
It should. I'll let you know once I've tried it! :D
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 319 times
Re: I sunk my boat!
Postby squatch » Wed Jul 06, 2016 4:23 pm
Initial test was a no go. I pressurized the fuel system and some of my fuel lines and fittings are leaking. So I stopped there. I found a Johnson dealer that has the exact right lines and clamps. So I hope to pick those up tomorrow morning. Normal stuff when you make this many changes.
squatch
Re: I sunk my boat!
Postby Hack » Wed Jul 06, 2016 4:33 pm
squatch wrote:Initial test was a no go. I pressurized the fuel system and some of my fuel lines and fittings are leaking. So I stopped there. I found a Johnson dealer that has the exact right lines and clamps. So I hope to pick those up tomorrow morning. Normal stuff when you make this many changes.
That is a good attitude. With so many lines, I am not surprised you have some leaks.
Mario
Hack
Re: I sunk my boat!
Postby squatch » Wed Jul 06, 2016 5:05 pm
When you go through stuff the way I do there will always be bugs to work out.
squatch
Re: I sunk my boat!
Postby bradzuzu » Wed Jul 06, 2016 9:58 pm
Nice bit of work you've done squatch !! I haven't messed with reeds in a very long time , I almost forgot 2 strokes have em :)
What size is that motor ?
Has thanked: 188 times
Have thanks: 355 times
Re: I sunk my boat!
Postby squatch » Thu Jul 07, 2016 2:46 am
60 hp.
squatch
Re: I sunk my boat!
Postby squatch » Thu Jul 07, 2016 7:48 pm
Getting closer everyday. Picked up the exact right fuel and primer lines today. Got them installed and fuel leaks seem to be solved.
Next issue was that I must have killed the starting battery when we flooded the battery box last year. Just like the similar age Optima that died in Red beans a while back. Looks good on the charger and shows good voltage. But nobody home when amperage is needed. it wouldn't crank the motor with the plugs in. I checked the stamp on top. May of 2006. 10 years old. I got my money out of this one. I'll replace it with a group 24 AGM in the morning.
I used a trolling motor battery and I did get the motor started. It seems to be running fine. But I need to check the timing and adjust the linkages. It won't idle down where I want it yet. One step at a time it's getting there.
squatch
Re: I sunk my boat!
Postby JoeIsuzu » Thu Jul 07, 2016 9:17 pm
It's not much consolation, but you didn't really "sunk" your boat. You sank it. :lol: Sounds weird, I know.
And that was a brilliant recovery, too! Glad you're making progress.
Jack
Original owner, 1983 Isuzu P'up LS Diesel. Engine overhauled by JLEMOND. Ready for new paint now!
1994 Isuzu Amigo 2wd
IsuzuPup.com
"There are no dumb questions"?! Maybe not...
but there are smart ways to ask. Old, but classic:
How To Ask Questions The Smart Way
JoeIsuzu
Has thanked: 70 times
Have thanks: 75 times
Re: I sunk my boat!
Postby squatch » Thu Jul 07, 2016 10:08 pm
Looking back I sank it last year. But at the time it sunk! I watched it happen. Gave me a real sinking feeling. :mrgreen:
squatch
Re: I sunk my boat!
Postby squatch » Mon Jul 11, 2016 9:14 pm
I thought I had it running yesterday in the drive pretty good. Took an hour and a 1/2 drive to the river and put it in the water. Then spent 1/2 an hour trying to get it started and no go. Back on the trailer. My batting average has taken a total dump lately! The control cables are hanging up some. They are OLD. So new ones were ordered today.
squatch
Re: I sunk my boat!
Postby imamonstertruck » Thu Jul 14, 2016 10:20 am
Looks like your luck with this boat and my luck with the trooper have been hanging out.
Cheers
-Ian :blackeye:
imamonstertruck
Re: I sunk my boat!
Postby squatch » Thu Jul 14, 2016 9:50 pm
Pretty much the same for all my projects!
squatch
Re: I sunk my boat!
Postby squatch » Fri Aug 05, 2016 1:25 pm
The boat is back on the water as of the day before yesterday. Finally got some rain and some water n the Potomac. I got the boat out and did some fishing. It's running good and no leaks at all.
squatch
Re: I sunk my boat!
Postby MarcusInMD » Sun Aug 07, 2016 4:40 pm
squatch wrote:The boat is back on the water as of the day before yesterday. Finally got some rain and some water n the Potomac. I got the boat out and did some fishing. It's running good and no leaks at all.
Congrats!
Anything biting?
99 Trooper. Black 161k miles - April 2015 AT Rebuild
MarcusInMD
Have thanks: 22 times
Re: I sunk my boat!
Postby squatch » Mon Aug 08, 2016 12:08 am
Thanks. Caught a couple.
squatch
Re: I sunk my boat!
Postby imamonstertruck » Mon Aug 08, 2016 1:53 pm
Good news Mark!
><> J
Cheers
-Ian :blackeye:
imamonstertruck
Previous
Return to Outdoor Life
