Cancooker
This forum is for the discussion of outdoor activities, other than trail rides
Cancooker
Postby squatch » Wed Apr 12, 2017 12:23 pm
Has anyone here got any experience with the can cooker?
http://www.cancooker.com/
Seems like a very useful item. I think I might like to try using this on the grate over my Gas campfire.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 326 times
Re: Cancooker
Postby MarcusInMD » Wed Apr 12, 2017 5:01 pm
Don't have any experience with it but considering how much propane the gas camp fires use might not be worth it for slow cooking. We used to go through so much in a weekend of camping while dredging for gold. Easily burn through 40lbs in 3 days..But of course this is using the camp fire at night on moderate to high.
99 Trooper. Black 161k miles - April 2015 AT Rebuild
MarcusInMD
Has thanked: 15 times
Have thanks: 23 times
Re: Cancooker
Postby Von » Wed Apr 12, 2017 6:15 pm
Is that a steam cooker of some sort? I've heard they cook faster than an oven or crock pot but never messed with one.
mmm... imagining an open faced roast beef sammich under the stars. Made from a wonderful pepperocini roast, swiss and pepperjack cheese... on sourdough bread toasted over a campfire.
I hate camping. But I'd camp for one of those.
2004 Pontiac Grand Prix GTP
Von
Has thanked: 14 times
Have thanks: 33 times
Re: Cancooker
Postby squatch » Thu Apr 13, 2017 10:55 am
I gather they are a cross between a crock pot and a pressure cooker/steamer. They cook with steam but little pressure. There is a hole in the lid that vents steam and pressure. So not high pressure. Supposedly will cook most anything in under an hour.
Marcus that's just one way to put heat to it. I would only use the gas fire if that was being used already.
I just ordered one in the companion size with grate.
squatch
Re: Cancooker
Postby reran » Thu Apr 20, 2017 11:11 am
Mark,
Have you tried to make any meals yet? I took the plunge too. Mine should be arriving shortly. I like the ideal of one pot one meal. You could store and transport your food in it as well. Anyway, let me know how it works out for you.
"As slowly as possible, as fast as necessary."
"Do what you can, with what you have, where you are." Theodore Roosevelt
89 Trooper, 2.6L Turbo, AW 30-80LE
90 Spacecab LS 4wd, 2.6, 5spd
94 Trooper SE, 3.2 DOHC
Image Image
reran
Has thanked: 8 times
Have thanks: 22 times
Re: Cancooker
Postby squatch » Thu Apr 20, 2017 11:17 am
Not yet. It just came in. Maybe I'll use it at URE.
squatch
Return to Outdoor Life
