Frankentumbler....
This forum is for the discussion of outdoor activities, other than trail rides
Frankentumbler....
Postby PPCLI-JIM » Sun Feb 12, 2017 12:16 pm
To everyone heres a warning you will be able to throw your eyes away as you will have seen everything now. i need to get a motor that can be speed controlled a controller and a GFI type plug for it . total cost for this was 18 $ for the 2 pillow blocks and the 1/2 " shaft. I will be adding the cost of the motor and switch. so under 100$ it is a piece of 4 " pvc with a cap and 2 small pieces of angle aluminuminumninum, some 1 inch square tubing i had around, i cut a pair of rollers on the backside not shown from some delrin i got from a friend and used a hole saw to cut a pair of them. i have tumbled some brass both 9mm and .223 works great
https://youtu.be/ZFsQo6mjvHM
97 Rodeo 3.2 AKA THE PAVEMENT PRINCESS pretty much stock
88 TROOPER II 2.6 auto Winch going carb with weber 32/36
9 ft 1963 Harbercraft
12 ft fiberglass boat
14ft 1962 Powercat 14T boat
GUNS LOTS AND LOTS LOL
PPCLI-JIM
Trail Rider
Has thanked: 35 times
Have thanks: 13 times
Re: Frankentumbler....
Postby squatch » Sun Feb 12, 2017 1:44 pm
Good ingenuity. Looks like it did a good job. I like shiny cases.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 328 times
Return to Outdoor Life
