Flat link
Flat link
Postby outofrshell » Thu Nov 12, 2015 2:17 am
I had some time to make a flat link for my winch line, I used 2 pieces of 6061 Al. 1" X 2" bolted together with socket head 5/16 bolts (now before you panic the bolts do nothing but hold the 2 halves) this gave me a 2" X 2" bar to work with. The winch line is pinned to the bar using the 1/2" pin from the hook (keeping it simple) this allows the link or the hook to be swapped with out looking for the pin. The clevis end is made for a 3/4" clevis. Dave
The 2 halves drilled and tap
Bolt mock up
Milling slot for winch line
Completed showing a 1/2" pin
Showing recess for head of hook pin, this was done so I could use the cotter pin on the far side
1989 Trooper 2.8/ 3.2 built V6, 5speed
Revolution gears
ARB Rear locker
ARB Front locker
SWAY-AWAY HD TORSION BARS
Self made Longer shackles
1998 Trooper front disc brakes and front seats
Self made HD Tie rods
Self made bumpers and grill guard w/ KC & Hella lights
Self made sliders
Waren VRS 8000 winch set up to use at either end of Trooper
Custom made cargo box w/ full length roll out drawers
31 X 10.50 X 15 Cooper STT Pro on Cragar black steel wheels
outofrshell
Have thanks: 43 times
Re: Flat link
Postby Van » Mon Nov 16, 2015 9:33 pm
Brilliant. :thumbup:
Not knowing anything about metals, but after doing a quick search of 6061 Al, seems like it's plenty strong enough. :D A quick google "flat link" search showed me some examples and now I need one. :santa:
Thanks
Van
Has thanked: 22 times
Have thanks: 87 times
Re: Flat link
Postby hessmess » Mon Nov 16, 2015 9:49 pm
I like how it allows for options instead of just a hook. Brilliant! I really like how you made it up yourself.
88 Trooper (recycled)
viewtopic.php?f=15&t=81567
viewtopic.php?t=55081
hessmess
Has thanked: 8 times
Have thanks: 144 times
Re: Flat link
Postby wmorrisiii » Fri Nov 27, 2015 11:11 am
Nice!
The Duck Marsh Debutante
The Coonhound
wmorrisiii
Has thanked: 86 times
Have thanks: 173 times
Return to Tool & Shop
cron
