Tie Rod Removal Tool
Postby itsmehb » Sat Aug 29, 2015 6:37 am
Recently replaced my tie rod ends. Anyone doing this may benefit from renting this tool from O'Riellys.
Has thanked: 99 times
Have thanks: 180 times
Re: Tie Rod Removal Tool
Postby Who is TJ » Sun Sep 13, 2015 10:52 pm
A few hits on the knuckle with a hammer would pop that tie rod right out! Just some advice in case you are ever in a jam.
1999 Isuzu Trooper LS. 3.5L Auto. 283,000 KM (175000 miles) and counting.
33" Hercules Mud Digger MT's
Surco Safari Rack custom fit.
6K HID Dual High and Low beam.
3"x3" Square LED fogs.
3" Total lift - Independent4X
View my build page: http://forum.planetisuzoo.com/viewtopic.php?t=79400
Who is TJ
Postby N law » Wed Sep 16, 2015 11:31 am
I have found a big hammer and a bigger hammer will pop tie rods loose. Use the bigger hammer on the backside of where the tie rod mounts up and the big hammer to whack the frontside. It will shock the tie rod right out.
For those who might have trouble following: if the tie rod stud is vertical, the hammer hits are horizontal on the spindle at the tie rod mounting hole.
99 VX
96 Rodeo Build thread
1975 FJ40
69 Beetle
84 Westfalia
70 VW bus turned camper
86 VW Diesel Golf
07 Frontier V6 6 speed
1999 4Runner Limitee- wife's
2004 Genuine Stella Scooter
N law
Has thanked: 16 times
Have thanks: 55 times
Postby Darby » Wed Sep 16, 2015 12:36 pm
Yeah, don't force it, get a bigger hammer.
Original owner of a 1993 Isuzu pick up, 2.3 engine, 5 speed with power steering and air conditioning. All original except the radio (still have factory radio).
It's cheaper to fix what you have than to buy someone else's problems.
Darby
Have thanks: 17 times
Postby Von » Mon Mar 21, 2016 11:09 pm
LOL, I rented one of those yesterday. Tried to use it today and it's way too small, the little claw won't fit around the studs on my tie rods.
Might try the Double BFH approach.
2004 Pontiac Grand Prix GTP
1965 Ford Fairlane 500 Sports Coupe 289 & 4 speed (on jack stands awaiting new floorboards, interior and rebuilt T-10)
Von
Has thanked: 12 times
Have thanks: 29 times
Postby Beamer » Fri Apr 15, 2016 12:24 am
Just put new gears in the front end. Watched JohnnyFive's BFH technique on a youtube video. So i gave it a whirl, and it worked better than the pickle bar, or the pitman arm puller.
94 Rodeo, 115k on odo. 4x4, 5spd.
Changes; Indy4x HD torsion bars, OME springs, indy4x shackles, Indy4x ball joint flip/spacers, Warn hubs, sway bar bushings. New polyurethane boots for ball joints, and Mecatech boots for CV joints. Shock post extensions, shock boots, low profile bump stops.
BFG AT KO2 285/75/16, alloy wheels.
Regeared to 456, and front Lokka locker
Build thread; viewtopic.php?f=15&t=85242&p=753729#p753729
Beamer
Return to Tool & Shop
