Flapper discs.
Flapper discs.
Postby squatch » Mon Jul 27, 2015 9:30 pm
One of my favorite tools. I have a couple of 4 1/2" angle grinders. They get a workout. a few years ago I discovered these flapper discs. The abrasive is bonded to steel leaves that lay like fish scales. They clean like crazy without over heating the metal like a grind stone wheel does. They also last a long time. This week I've been cleaning leaf springs with mine.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 319 times
Re: Flapper discs.
Postby JLEMOND » Mon Jul 27, 2015 11:00 pm
I WILL PICK UP ONE OF THOSE AND CHECK IT OUT , LOOKS GOOD . THANKS MARK
JLEMOND
Have thanks: 236 times
Re: Flapper discs.
Postby paulevans76 » Tue Jul 28, 2015 11:50 am
Love me some flapper discs.
91 SAS Trooper - Neverending tinkering
Semi-hopped-up 3.4 + MUA5 + 3.07:1 low
Waggy D44 Front - 5.38's + RCV's + OX
Rodeo D44 Rear - 5.38's + Detroit
35" General Grabber X3's on Interco Birddogs
Has thanked: 61 times
Have thanks: 76 times
Re: Flapper discs.
Postby PPCLI-JIM » Tue May 31, 2016 10:03 am
been using for years , what a great piece of kit :D
Its a small amount of fuel , but it's a whole lot of walking..Note from my Dad
97 Rodeo AKA the Pavement Princess.Maybe ill just keep it fairly stock but more capable ... And the 88 Trooper II Christine viewtopic.php?f=15&t=86504
The wild Infantryman is never truly happy in a domesticated role, though they may act like it with their stories of deployments past and the suffering they have endured.
PPCLI-JIM
Trail Rider
Has thanked: 30 times
Have thanks: 10 times
Re: Flapper discs.
Postby imamonstertruck » Tue May 31, 2016 11:30 am
Use them all the time, especially in the shop when i clean up bourbon barrel rings
Great idea on the springs Mark. They look great
Cheers
-Ian :blackeye:
-91 Trooper, 3.4 V6, 5speed, 4.77 gears, 3:1 Revo T-Case Gears, HD tie rods, 3" body lift, 2" suspension lift, 1.5" diff drop, 33x10.5x15 BFG A/T,
Round Eye Swap (JDM marker lamps).
1989 Trooper RS http://forum.planetisuzoo.com/viewtopic.php?f=15&t=81642&p=722882#p722882
Previous Troopers and Build Thread->http://forum.planetisuzoo.com/viewtopic.php?f=15&t=63260
1988 ISUZU TROOPER WORKSHOP MANUAL
"There are only two days in the year that nothing can be done. One is called yesterday and the other is called tomorrow, so today is the right day to love, believe, do and mostly live."~ Dalai Lama
“Unless someone like you cares a whole awful lot, nothing is going to get better. It's not.”Dr.Suess
Aaronmcvay84 wrote:I think with isuzus there is a more mature crowd that realizes the value of their hard work. They keep things.
imamonstertruck
Has thanked: 49 times
Have thanks: 164 times
Re: Flapper discs.
Postby geoffinbc » Wed Jul 06, 2016 3:01 am
They are descent. In a production environment they are only good for finishing. If you have serious rust and scale removal jobs and a sand blaster is not available then use Walter Mill Scale Flex Cut Discs. They work much faster and don't clog up.
The idea behind a flap disc is they remove material like 36 grit but leave a finish like an 80 or 120 grit.
Big Bore Intake Kits Here
Have thanks: 314 times
Re: Flapper discs.
Postby wesharris » Wed Jul 20, 2016 9:52 pm
I love flap discs ...I like them cause you can nearly Polish with them ...but also clean up nasty metal for welding
1990 trooper 2.6 msd6al ignition system msd turned "out to junk" blaster ll coil accel wires iridium NGK plugs 5 speed new head brake rotors and brakes 16" wheels new tires. new axles new clutch,flywheel,clutch master and slave cylinder all new ball joints 95 trooper front seats and turbo coming soon
viewtopic.php?f=15&t=65233
wesharris
Has thanked: 78 times
Have thanks: 28 times
Return to Tool & Shop
