Flapper discs.
Flapper discs.
Postby squatch » Mon Jul 27, 2015 9:30 pm
One of my favorite tools. I have a couple of 4 1/2" angle grinders. They get a workout. a few years ago I discovered these flapper discs. The abrasive is bonded to steel leaves that lay like fish scales. They clean like crazy without over heating the metal like a grind stone wheel does. They also last a long time. This week I've been cleaning leaf springs with mine.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 328 times
Re: Flapper discs.
Postby JLEMOND » Mon Jul 27, 2015 11:00 pm
I WILL PICK UP ONE OF THOSE AND CHECK IT OUT , LOOKS GOOD . THANKS MARK
JLEMOND
Have thanks: 255 times
Re: Flapper discs.
Postby paulevans76 » Tue Jul 28, 2015 11:50 am
Love me some flapper discs.
Has thanked: 92 times
Have thanks: 87 times
Re: Flapper discs.
Postby PPCLI-JIM » Tue May 31, 2016 10:03 am
been using for years , what a great piece of kit :D
97 Rodeo 3.2 AKA THE PAVEMENT PRINCESS pretty much stock
88 TROOPER II 2.6 auto Winch going carb with weber 32/36
9 ft 1963 Harbercraft
12 ft fiberglass boat
14ft 1962 Powercat 14T boat
GUNS LOTS AND LOTS LOL
PPCLI-JIM
Trail Rider
Has thanked: 36 times
Have thanks: 14 times
Re: Flapper discs.
Postby imamonstertruck » Tue May 31, 2016 11:30 am
Use them all the time, especially in the shop when i clean up bourbon barrel rings
Great idea on the springs Mark. They look great
Cheers
-Ian :blackeye:
1989 Trooper RS http://forum.planetisuzoo.com/viewtopic.php?f=15&t=81642&p=722882#p722882
Previous Troopers and Build Thread->http://forum.planetisuzoo.com/viewtopic.php?f=15&t=63260
imamonstertruck
Has thanked: 49 times
Have thanks: 166 times
Re: Flapper discs.
Postby geoffinbc » Wed Jul 06, 2016 3:01 am
They are descent. In a production environment they are only good for finishing. If you have serious rust and scale removal jobs and a sand blaster is not available then use Walter Mill Scale Flex Cut Discs. They work much faster and don't clog up.
The idea behind a flap disc is they remove material like 36 grit but leave a finish like an 80 or 120 grit.
geoffinbc
Has thanked: 8 times
Have thanks: 324 times
Re: Flapper discs.
Postby wesharris » Wed Jul 20, 2016 9:52 pm
I love flap discs ...I like them cause you can nearly Polish with them ...but also clean up nasty metal for welding
1990 trooper 2.6 msd6al ignition system msd turned "out to junk" blaster ll coil accel wires iridium NGK plugs 5 speed new head brake rotors and brakes 16" wheels new tires. new axles new clutch,flywheel,clutch master and slave cylinder all new ball joints 95 trooper front seats and turbo coming soon
viewtopic.php?f=15&t=65233
wesharris
Has thanked: 78 times
Have thanks: 28 times
Return to Tool & Shop
cron
