New use for engine hoist
Postby outofrshell » Sat Apr 18, 2015 11:23 pm
I am finishing up the sheet rock in my shop, neighbor helped with one sheet but it was a struggle and he suggested using the hoist to hold it, worked great and we got that sheet screwed in place. But I had more to go by myself so I cobble up an improvised sheet rock jack which worked better than I expected. So now my engine hoist is a multi function tool. Last summer we used it to pull fence post.
The 2X4 is bolted to the metal bracket and the OSB is screwed to the 2X4 the bolt is tightened enough that it doesn't flop down- a little awkward but worked
1989 Trooper 2.8/ 3.2 built V6, 5speed
Revolution gears
ARB Rear locker
ARB Front locker
SWAY-AWAY HD TORSION BARS
Self made Longer shackles
1998 Trooper front disc brakes and front seats
Self made HD Tie rods
Self made bumpers and grill guard w/ KC & Hella lights
Self made sliders
Waren VRS 8000 winch set up to use at either end of Trooper
Custom made cargo box w/ full length roll out drawers
31 X 10.50 X 15 Cooper STT Pro on Cragar black steel wheels
outofrshell
Have thanks: 39 times
Re: New use for engine hoist
Postby Combatspace » Sun Apr 19, 2015 1:12 pm
Well, whadayuno? That's fancy.
Combatspace
Have thanks: 10 times
Postby btw1549 » Sun Apr 19, 2015 3:59 pm
Nice! I built a transmission jack with the same concept.
BtW - 1991 LS Trooper In Progress, Complete Restoration with 3.4L Swap! (The Tank)
viewtopic.php?f=15&t=72642
2002 Isuzu Axiom In Progress, Complete Drivetrain Rebuild with Suspension Refresh/Lift
viewtopic.php?f=15&t=74409
btw1549
Have thanks: 18 times
Postby squatch » Thu Apr 23, 2015 11:40 am
Great idea. Mine also gets used for stuff other than engines.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 319 times
Postby Cronk » Sat Jun 20, 2015 9:28 pm
Great idea, thanks for sharing!
Cronk
Has thanked: 122 times
Have thanks: 87 times
Postby FABRIK8TOR » Sun Jan 03, 2016 2:24 am
Thats a great mod....i think i have only used my hoist for just 2engines since i boguht it over 12 years ago.
I think ive used it for everything else besides what it was intended for.
FABRIK8TOR
Return to Tool & Shop
