new to me air compressor
Postby wesharris » Mon Sep 29, 2014 10:58 am
I believe I have got a good deal on an older compressor its a sears 4 HP 20 gallon 230 volt
I need advice on what to do to it before I put power to it thanks
1990 trooper 2.6 msd6al ignition system msd turned "out to junk" blaster ll coil accel wires iridium NGK plugs 5 speed new head brake rotors and brakes 16" wheels new tires. new axles new clutch,flywheel,clutch master and slave cylinder all new ball joints 95 trooper front seats and turbo coming soon
viewtopic.php?f=15&t=65233
wesharris
Has thanked: 78 times
Have thanks: 28 times
Re: new to me air compressor
Postby BigSwede » Mon Sep 29, 2014 11:58 am
Make sure it has oil in the compressor. Drain condensation from the tank.
BigSwede
Has thanked: 16 times
Have thanks: 252 times
Postby wesharris » Tue Sep 30, 2014 7:21 am
I'm thinking about changing the oil in the compressor. Is that a good idea ?
wesharris
Postby BigSwede » Tue Sep 30, 2014 10:35 am
It's certainly not a bad one. It should be changed occasionally, but I don't remember what the schedule is. I should probably get the manual out for my compressor...
BigSwede
Postby wesharris » Tue Sep 30, 2014 12:15 pm
Our compressor at the shop went out the other day . so the boss brought one from his dads shop that he had bought years ago it exactly like mine except it a 2hp 15 gallon and its a little hoss of an air compressor
I'm excited to see how mine does we're gonna run some wire later this week
wesharris
Postby Chitzu » Tue Sep 30, 2014 12:59 pm
The compressor is just like a gas engine, lots of air goes through it so keep the air filter clean. Most compressors do not have adequate filters in my estimation.
Chitzu
Has thanked: 34 times
Have thanks: 15 times
Postby wesharris » Tue Sep 30, 2014 7:13 pm
Yeah I was thinking that the filter could use updating. Its not dirty but it doesnt seem like it would keep all the dirt and debris out
wesharris
Postby 2wheels2 » Tue Sep 30, 2014 10:17 pm
Older compressors scare me anymore after Squatch posted a video of one grenading. Not saying I'd never buy one but if I did I'd have a real temptation to tap along the bottom of it, especially around the drain if it's the lowest point. Sure, you might tap a hole in it but better that then to have the thing literally blow up on you unexpectedly if the tank were rusted thin from not draining it.
2wheels2
Has thanked: 2 times
Have thanks: 39 times
Postby wesharris » Wed Oct 01, 2014 9:15 pm
check did that before i loaded it
wesharris
Postby wesharris » Fri Oct 03, 2014 1:20 am
Compressor runs great cuts off around 130 psi comes on @ 90
wesharris
Postby N law » Fri Oct 03, 2014 10:41 am
2wheels2 wrote:after Squatch posted a video of one grenading.
this was the link he posted to. Very scary!
http://www.mytractorforum.com/showthread.php?t=166972
99 VX
96 Rodeo Build thread
1975 FJ40
69 Beetle
84 Westfalia
70 VW bus turned camper
86 VW Diesel Golf
07 Frontier V6 6 speed
1999 4Runner Limitee- wife's
2004 Genuine Stella Scooter
N law
Has thanked: 17 times
Have thanks: 62 times
Postby wesharris » Fri Oct 03, 2014 12:27 pm
Wow that is horrible , But I inspected my compressor as well as could be done...with all that said ....I am not in a position to buy a new compressor of this quality nor am I gonna give money away for a POS that they sell new in most stores so I will take this one for what it is and use it .I appreciate all your concern and the information
wesharris
Postby Tad » Tue Oct 14, 2014 5:36 pm
That looks like a Speedaire too so parts will be easy to find. I "restored" one I got for almost nothing. It needed some new reed valves and an air filter. Changing the oil is easy, and even HF carries air compressor oil.
-Tad
Tad
Site Admin
Has thanked: 121 times
Have thanks: 95 times
Postby wesharris » Fri Oct 17, 2014 12:44 pm
Thanks for the info Tad I need to replace the pressure switch ...other than that and it being a little bit loud it works great
wesharris
Postby Tad » Fri Oct 17, 2014 5:47 pm
There were intake mufflers for those. I found one after a month or two of watching ebay. They may be more or less available now, but it's worth looking.
-Tad
Tad
Site Admin
Postby wesharris » Wed Dec 24, 2014 2:53 am
Thanks for the info tad
wesharris
Postby Tad » Wed Dec 24, 2014 11:49 am
Here is someone's home built intake adapter:
http://photos.phpwerx.net/dan/2010-12-0 ... CF3837.JPG
There are lots of intake mufflers out there. I bought a craftsman. It's like a small air filter housing but it has a set of tubes so there is no direct path for sound to exit.
-Tad
Tad
Site Admin
Postby gb89amigo » Thu Jan 01, 2015 2:51 am
A happy New Year to all!
As a matter of routine, one should open the condensation drain on the bottom of the tank at the end of each days use! It only takes a minute to do and will insure all that accumulated moisture is blown out. Your tank should enjoy a bit more longevity with this procedure. If you forget to close that valve on start-up, the extra noise of escaping air will remind you!
A yearly change of compressor lubricant should be plenty in most cases! Make sure you have moisture traps in place if using to spray paint.
Cheers,
GB
'89 Amigo XS RWD, 4ZE1, MUA5, HC6 (Rear Wheel Drive, 2.6L Fuel Injected, 5 spd trans f/ 2.6L and up, 4.56:1 differential 2WD/4WD)
Future: Install the "Big Brake" upgrade, so I don't break things! . Acquired '95 V6 Passport/Rodeo front rotors (11.04") and assemblies. Need to pull G80/LSD rear from '92-'97 Trooper.
'90 Amigo 4WD, Parts car
More FUN!!! :)
gb89amigo
Has thanked: 49 times
Have thanks: 116 times
Postby Tad » Thu Jan 01, 2015 11:53 am
If you use the compressor a lot, you might benefit from an auto-drain setup. The one that Harbor Freight sells isn't very good, but there are other options. I have found their blue garage hose kit to be good, as are the large-ish oilers, filters and regulators.
-Tad
Tad
Site Admin
Return to Tool & Shop
