Welding Stainless
Welding Stainless
Postby N law » Wed Jul 09, 2014 2:04 pm
A buddy of mine always comes to me to weld up whatever he can break. This new one is off of his boat and is stainless steel. I currently have a MIG welder and I've toyed around with aluminum but really needed the spool gun. What all does one need to know about welding stainless? From what I've figured, I can use a MIG with stainless wire and its recommended to use Tri-Mix gas.
I am sure TIG is the way to go, but I'm still saving up for that!!!
99 VX
96 Rodeo Build thread
1975 FJ40
69 Beetle
84 Westfalia
70 VW bus turned camper
86 VW Diesel Golf
07 Frontier V6 6 speed
1999 4Runner Limitee- wife's
2004 Genuine Stella Scooter
N law
Has thanked: 17 times
Have thanks: 62 times
Re: Welding Stainless
Postby BigSwede » Wed Jul 09, 2014 4:04 pm
Probably not the answer you were looking for, but exposure to hexavalent chrome can be a problem when welding stainless.
BigSwede
Has thanked: 14 times
Have thanks: 251 times
Postby btw1549 » Wed Jul 09, 2014 4:18 pm
You can weld stainless with a mig set-up as you mentioned with tri-mix gas. You don't need to know anymore than welding regular steel with the correct wire and gas. Yes tig in many applications is better, such as header pipes, however for most projects migging the stainless will yield excellent results.
BtW - 1991 LS Trooper In Progress, Complete Restoration with 3.4L Swap! (The Tank)
viewtopic.php?f=15&t=72642
2002 Isuzu Axiom In Progress, Complete Drivetrain Rebuild with Suspension Refresh/Lift
viewtopic.php?f=15&t=74409
btw1549
Have thanks: 23 times
Postby geoffinbc » Wed Aug 27, 2014 12:44 pm
If you don't want to buy or rent gas for one job you can use flux core with a 75/25 standard gas. Flux core is very nice to use on SS
geoffinbc
Has thanked: 8 times
Have thanks: 323 times
Postby Chitzu » Wed Aug 27, 2014 7:41 pm
BigSwede wrote:Probably not the answer you were looking for, but exposure to hexavalent chrome can be a problem when welding stainless.
This got bumped up, Is the hexavalent from boat stainless? I did a lot of tig 302 years back,maybe that's what is wrong with me. :alien:
Chitzu
Has thanked: 34 times
Have thanks: 15 times
Postby Med!c » Mon May 04, 2015 3:15 am
any steel that has chromium in it poses a risk. I've read even recycled mild steel can have chrome in it.
00' Trooper 4x4- V6 3.5L
5-Speed Manual Aisin AR-5
Isuzu 12-Bolt Modified LSD
Isuzu 10-Bolt Aussie Locked
BGF AT T/A KO 285/75/16
Miss my old rodeo.
Med!c
Have thanks: 86 times
Postby HoldFastTx » Tue May 19, 2015 6:40 am
Breathing burnt flux doesn't help either. Nor does burning any metal covered in things like motor oil and brake fluid. I'm a long time welder , started in structural now pipe. There's a link to Parkinsons. My father owns a steel business and when I worked for him I saw a lot of old welders with shaking hands. I personally have had galvanize poisoning, milk helps. Respirators are the way to go but in Texas its so hard to wear it and breath. My eyes are messed up and I'm scared to even see what my lungs are like, 20 year smoker too, I know, I know. Saftey first
95 Trooper LS 3.2sohc auto/4wd 130k (stock, daily driver/slow project)
92 Chevy G20 Mark III swb, 4.3 v6, 4L60e, wheelchair lift, 70k orig.(running project)
HoldFastTx
Has thanked: 20 times
Return to Tool & Shop
