JLEMOND Style Transmission Jack
Postby gruff54 » Sun Mar 30, 2014 7:40 pm
After a tip from Jerry, I put this together. Transmission is held very secure. I was always afraid it might fall off the jack before. Not any more. Thanks for the idea Jerry!!!
Mike
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54 was thanked by:
1999Amigo4WDBeamer
gruff54
Has thanked: 33 times
Have thanks: 56 times
Re: JLEMOND Style Transmission Jack
Postby red cube » Tue Apr 01, 2014 11:01 pm
Oh man, that's so much better than the adapters I tried! I've still got the old mount from the last swap, so I know what I'll be building in the shop next week! Oh, wait... gotta do the taxes... okay, the week after that!
On a slightly different note, what I did use to finally get the trans mounted was running an engine hoist through the front door, and picking up the trans from the main (3-bolt) shifter I welded a ring to a simple flat plate and bolted it to the trans with the shifter bolts. The trans balances very well from that point, although you do loose the ability to put the trans into gear and rotate input shaft to help line up the splines. I am still gonna make a jack adaptor for the MUA-5...
Mark
for Lo! I am Isuzu: consumer of fuel and harbinger of rust;
Look upon my tires, ye potholes, and despair!
red cube
Has thanked: 25 times
Have thanks: 23 times
Postby DSUZU » Mon Apr 07, 2014 7:32 pm
Similar to mine, but mine was plywood, holds up fine, much easier to make. Dennis
Has thanked: 220 times
Have thanks: 624 times
Postby NE_farmhand » Sun Jun 07, 2015 2:56 pm
red cube wrote:Oh man, that's so much better than the adapters I tried! I've still got the old mount from the last swap, so I know what I'll be building in the shop next week! Oh, wait... gotta do the taxes... okay, the week after that!
Mark
Put it in gear before putting the lift plate in place.
90 amigo, 2.6, can be a fun little bugger
NE_farmhand
Postby imamonstertruck » Mon Jun 08, 2015 9:55 pm
Well, I'm going to take this one with me :D
Mr. LEMOND is genius
Thank you for sharing
cheers
-Ian :blackeye:
1989 Trooper RS http://forum.planetisuzoo.com/viewtopic.php?f=15&t=81642&p=722882#p722882
Previous Troopers and Build Thread->http://forum.planetisuzoo.com/viewtopic.php?f=15&t=63260
imamonstertruck
Has thanked: 49 times
Have thanks: 166 times
Return to Tool & Shop
