What chain saw do you have?
Re: What chain saw do you have?
Postby QuantumRift » Fri Dec 12, 2014 1:10 am
ALso have a Stihl blower/vac and it starts first pull about every time.
"If Opportunity knocks and he's not at home, Opportunity waits."
"Find out what it is in life that you don't do well, then don't do that thing."
1990 Isuzu LS SpaceCab 4x4 (Japanese-built, September 1989)
224,000 miles.
K&N Air Filter
2.6 L 4ZE1 engine, 5-spd manual
Monroe Sensa-track Load Adjusting Shocks (rear)
Monroe OE Spectrum Shocks (front)
MagnaFlow Muffler & Cat Converter
Akebono ProACT Ultra-Premium Ceramic Brake Pads (front)
Wagner Thermoquiet Ceramic Brake Pads (rear)
Owned since 15 miles. Bought new Honolulu, HI in Oct '89.
Original sticker price: $15,000.
QuantumRift
Has thanked: 23 times
Have thanks: 99 times
Postby JFoster » Tue Feb 10, 2015 11:55 pm
This year I decided I would not borrow any more chainsaws and that I should buy one for myself. I did what I usually do, and read about chainsaws until I tripled my budget. :roll:
JFoster
Drives in Mud
Have thanks: 5 times
Postby Heffalump » Wed Mar 18, 2015 5:31 am
I made the mistake of getting into chainsaws this last fall. I grew up running Jonsereds saws in NH, and decided to seek them out here in the PNW. I've capped off my collection at 9 saws total. I have a 111S, an 80/90 (that is a Jonsereds 80 with a 90cc cylinder) two 70E's, two 52E's, a 2036, a Stihl 034AV Super, and a non-running old Skil. Pics soon, I promise.
1990 Trooper
4ZE1 .020" over / 95 Rodeo cam
MUA-5 w/ 3.07:1 Revo Gearset
Round eyes up front, G80 in the rear
31x10.5 BFG TA/KO - 15"x8" 3.75
Heffalump's Pics
Heffalump
Has thanked: 15 times
Have thanks: 9 times
Postby Heffalump » Wed Mar 18, 2015 7:43 pm
1990 Trooper
Heffalump's Pics
Heffalump
Postby 800XL » Fri Mar 20, 2015 4:54 pm
In currently between saws right now, but I've got access to an old two man Maul saw with an 8ft bar. You know, just in case I need to cut a little firewood.
-Tim
1995 Trooper SOHC 5 Spd, daily driver.
97 camshaft swap
Multec 2/Delphi 98-02 Isuzu injector swap
drilled out exhaust restrictors
285/75-16 Kenda Klever M/T on Snowflakes
95 Trooper Build Thread
1986 Trooper LWB 2 Door - Impulse 2.3L high compression motor, 31x10.5 tires
1977 and 1979 Chevy LUVs - a 2WD and a 4WD matched set, projects in the works
800XL
Has thanked: 52 times
Have thanks: 42 times
Postby squatch » Sun Mar 29, 2015 10:31 pm
My grandfather used to have an old 2 man chainsaw. You got to be crazy! :shock: I think a 2 man chainsaw is about as safe as using a running outboard motor to scratch your doodads!
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 328 times
Postby 800XL » Mon Mar 30, 2015 2:01 am
My dad bought this one when I was much younger. I recall it had been sitting for a decade then and the fuel tank was full of gummed up funk and varnish but it still fired over a bit when we pulled the rope. It looks something like the closest two on the left in this pic e except it has the gear box that rotates to turn the bar horizontal.
-Tim
97 camshaft swap
For this post the author 800XL was thanked by:
Heffalump
800XL
Postby squatch » Tue Mar 31, 2015 6:51 pm
It's been many years since I saw my grandfathers. It had a vertical handle on the non powered end. When I was a kid I thought it was so cool. Never saw it in use. After years of using saws it just gives me the willie's. Chainsaws are potentially dangerous when just one is using it. I'd have to have ultimate trust in the man on the powerhead to ever hold the tip end.
My thoughts go to working with ladders my whole life. Every time someone goes to help you with a ladder you are moving or folding. Someone gets their hands pinched.
squatch
Postby dvan72 » Wed May 13, 2015 1:04 pm
I love my stihl....best chainsaw out there for my money.
2000 Rodeo LS 4x4 new to me as of 1/09/2015
1998 Rodeo 2wd looking a bit of her age
04 Chevy Avalanche
2003 Harley Fatboy 100th anniv edition too many extras to list here
dvan72
Drives in Mud
Have thanks: 6 times
Postby Heffalump » Wed May 13, 2015 1:14 pm
My only two complaints against Stihl is clogging air filters and absurd resale prices. But they do make a fine saw!
1990 Trooper
Heffalump's Pics
Heffalump
Postby 93stormtrooper » Tue Jul 07, 2015 12:19 am
My small around the yard saw is an echo cs306, I can let it sit for month and it'll fire right up, my bigger saw is an early model poulan 306a back when they were still made to last, loudest thing ever but it'll cut whatever you put it on, I have a 20 in bar on it now and could probably get away with running a 24 on it
1993 Trooper, 3.2 SOHC, 5 speed, auto hubs
Luck can change. Skills will last a lifetime if you dont get lazy.
93stormtrooper
Has thanked: 4 times
Postby heckcreek » Tue Jul 07, 2015 10:42 pm
I work at an Auto Parts Store and we sell an assortment of weedeaters, saws, and even Mahindra tractors. I must say that of every saw I've used the Jonsered saws we sell are the toughest out there. Some cross over to their light duty Husq. counterparts, but for the most part they are a Husq. on steroids.
For Sale 1986 Isuzu Trooper Diesel- Factory diesel swapped for n/a c223 out of a pup, 5 speed. Mods, 31x10.50's, JVC Stereo, and other mods to come.
Wrecked and Sold- 1985 Isuzu Trooper Turbo Diesel- 3rd Gen Rod truck with little rust, A/C, and Power Steering. Only mods so far are Eagle Alloy 16x8 bullet holes with 4.5" BS and 245/75/16 Treadwright Guard Dogs.
heckcreek
Postby totten » Fri Jan 01, 2016 3:27 pm
i HAVE A 18" BAR LIGHT DUTY HOMELITE 42CC. Works good for small trees.Good price and easy to start.
totten
Have thanks: 85 times
Previous
Return to Tool & Shop
