What chain saw do you have?
Postby slainer » Fri Aug 31, 2012 6:00 pm
Well after 12 year of no maintenance and much abuse my Poulan 2150 is just now giving me problems. The fuel line have deteriorated so I replaced two of them but must of got some dirt in the carb and now its not starting and running right even after cleaning it out could have a air leak from not using new gaskets.
I'm considering getting another cheap saw like Poulan or Ryobi or maybe spend a little more on a better name brand. Let me know what how you all like the saw you use.
slainer
Has thanked: 12 times
Have thanks: 27 times
Re: What chain saw do you have?
Postby thebigbread » Fri Aug 31, 2012 9:52 pm
Husqvarna is my preferred brand.
I picked up a slightly used 60cc 2-stroke after katrina for about $250. yes, i know, that's expensive for a used chainsaw.
but this thing is massive, 24" bar, plenty of power. when i lived in alabama, my father and I cleared 16 acres, the chainsaw just kept taking a beating.
I still have it, and i'm about to use it to clean up isaac's mess tomorrow :D
1988 Trooper Special Edition, 133K miles, spectra red, rebuilt 2.6 engine, New tires are DONE!
thebigbread
Trail Scout
Have thanks: 6 times
Postby slainer » Fri Aug 31, 2012 10:02 pm
I don't think that's to much money for a good saw that size, anyway sounds like it paid for its self already. Good luck with the clean up.
slainer
Postby BigSwede » Fri Aug 31, 2012 10:06 pm
I have a 30 year old Homelite EZ...since you asked.
BigSwede
Has thanked: 16 times
Have thanks: 252 times
Postby gruff54 » Sat Sep 01, 2012 6:38 am
Old Husky's here also. 266 and 277, I think. Finally wore the 266 out last winter. While trying to find parts(some are NLA :( ) I picked up the 277. Believe I gave $300, which I felt was a fair price, given the cost of a new one!
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54
Has thanked: 33 times
Have thanks: 56 times
Postby ArdWrknTrk » Sat Sep 01, 2012 7:48 am
If you're looking for a similar 16-18" homeowner type saw I can vouch for the Stihl 025.
I've had mine for well more than a decade and it cuts plenty of firewood, deadfall and even some construction timbers.
Get a decent rip chain and run it dry of fuel when you're not using it.
1995 Honda Passport EX
Auto, G80 LS, Sunroof, 16" Snowflakes w/ Khumo KL 61's, Brush Bar, Selective yellow fogs, Shackles
Catching up on neglected maintenance, Priceless
200k and climbing. :)
ArdWrknTrk
Has thanked: 91 times
Have thanks: 30 times
Postby reran » Sat Sep 01, 2012 9:18 am
I have a 7-8 year old Husqvarna 141 with a 16" bar. One of the smaller models Husky used to make. The only problem I ever have with it is if I use gas with the ethanol additive. Then it gets finicky and makes it hard to start. Otherwise, it's a great little saw. And I always run it dry before it's put away.
"As slowly as possible, as fast as necessary."
"Do what you can, with what you have, where you are." Theodore Roosevelt
89 Trooper, 2.6L Turbo, AW 30-80LE
90 Spacecab LS 4wd, 2.6, 5spd
94 Trooper SE, 3.2 DOHC
Image Image
reran
Has thanked: 8 times
Have thanks: 24 times
Postby ArdWrknTrk » Sat Sep 01, 2012 9:25 am
Yes, ethanol is the worst for two strokes. :evil:
ArdWrknTrk
Postby slainer » Sat Sep 01, 2012 12:19 pm
I do think the ethanol is having an effect on the saw, even the gas cap is tight must of been swollen from the new gas we have now. Well After taking the carb apart today found it clogged and missing a screen, so I'm going to get a carb rebuild kit and new in tank fuel filter, that should get it going.
Still like to get a bigger saw, if I can find a good used saw and refurbish it that maybe the way to go. Some how I feel unprepared not having a working saw on hand.
slainer
Postby squatch » Sat Sep 01, 2012 7:50 pm
ArdWrknTrk wrote:If you're looking for a similar 16-18" homeowner type saw I can vouch for the Stihl 025.
This man knows what he is talking about! I have 4 chain saws 2 older Poulans that are worn out and a 20" Stihl 029 farm boss as my big saw. 2 years ago I bought a Stihl MS250. New emissions version of the above. 2 stroke saw. It has an 18' bar and uses the bigger 325" chain. `Same as my big saw. 16" and smaller use the smaller "pico" chain. Stihl considers it to be a "homeowners saw" but it's more than good enough for most folks. What a little cutting machine! :D It's lighter than any of my Poulans and with the bigger chain cuts dang near anything my big saw will but at seemingly 1/2 the weight. I'm going to buy another I've been so impressed with it. Get a case, a couple of spare chains and a sharpening kit. Learn how to sharpen with a file. Always use the Stihl parts and oil and it will last a long time and do plenty of work for you. Don't go with a smaller saw in the same line. They are all the same engine with different displacement so you might as well buy the most powerful one. Otherwise exactly he same per my local dealer.
I always pour the fuel back in the can when I'm done with it and then start it till it dies. No probs with fuel at all. If your saw fuel sits around very long run it in the lawn mower. The little bit of 50:1 won't hurt a thing. Stihl want premium fuel but will run on regular. Just like all small equipment these days use fresh fuel. I have gone to Stihl for all of my power equipt. now all my saws, boats, weedwacker run on the same 50:1 mix! My Stihl weedwacker is 10 years old and I just put the 1st new cutting line head on it. It replaced a POS Ryobi that didn't even last a season. Husky and Echo also make good saws and OPE. Stay away from the chain store junk. Poulan used to make good saws. Now they make trash that won't run out of the box.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 328 times
Postby slainer » Sat Sep 01, 2012 9:21 pm
I think that I'm going have to check into the Stihl 025. Pouring the fuel back into the can will be a new habit of mine.
slainer
Postby WhoUtink » Sat Sep 01, 2012 10:39 pm
I have a husky 455 rancher 18". Great saw, has plenty of power to cut through anything I have tried. Always starts right up on the second pull and I don't take care of it at all. If I had to do it over again I would definitely buy a husky in a heartbeat. But I still would want the stihl. LOL. Stihls make more power and weigh less for comparable models. Weight is a BIG thing to consider when looking for a saw that will be used frequently or for extended periods of time. Only problem is they cost a lot. But I'd imagine the extra cost is worth it.
WhoUtink
Postby soot fart » Sat Sep 01, 2012 11:01 pm
Huskies are great saws for doing small up on the pipe jobs but cutting quantities of wood I and NW loggers use nuthin but Stihl! Jerry
soot fart
Trail Rider
Have thanks: 13 times
Postby dryvr12 » Mon Sep 03, 2012 8:26 am
I have an old McCullough wild cat. 18" bar I believe. Picked it up not running for $15 a few summers ago. Was my first experience with tearing down and rebuilding something with an engine. Took it down to the block and cleaned every piece meticulously. This was a HUGE mistake because after the first use, all my detail work was hardly even noticeable. Even though its a cheap saw, it gets the job done and is one of our most reliable starters.
Zack
1988 Trooper LS 2.6L Auto to manual swap, Asin hubs, 228k+
http://forum.planetisuzoo.com/viewtopic.php?f=15&t=50707
LED gauges, sony h/u, alpine speakers, jl audio w3's, grant steering wheel, cup holders, procomp 98s
Odometer correction: http://forum.planetisuzoo.com/viewtopic.php?f=1&t=67546
Dome light fix: http://forum.planetisuzoo.com/viewtopic.php?f=17&t=62898
LEDs:http://forum.planetisuzoo.com/viewtopic.php?f=1&t=51643
dryvr12
Have thanks: 43 times
Postby slainer » Mon Sep 03, 2012 1:46 pm
I wouldn't mind getting a old saw for cheap and repairing it, if I could find one but a new ms250 with 18" bar for $300.
slainer
Postby dryvr12 » Mon Sep 03, 2012 6:34 pm
slainer wrote:I wouldn't mind getting a old saw for cheap and repairing it, if I could find one but a new ms250 with 18" bar for $300.
Check craigslist. In chicago cheap chainsaws are a dime a dozen.
Zack
dryvr12
Postby slainer » Mon Sep 03, 2012 8:46 pm
Went to look at the MS250 today, I like it. The guys at the shop told me that they run promos for a free case in mid Oct, I think i can wait till they.
slainer
Postby haynesdad2 » Mon Sep 03, 2012 9:15 pm
I have the 20" ryobi and it has worked well for home use. The reason i bought it was that every a-hole in bham post April 27 tornados returned their "broken" saws convienetly after their yard was cleaned up. I was able to buy a gently "broken" one for $100. Is it a Husky? No but for light duty use, its great.
2000 Trooper LS
265/75/16 Wardens
Graco Car seats
Double Jogging Stroller
Sippie Cup rolling under the front seat
haynesdad2
Mi Amigo
Has thanked: 2 times
Postby squatch » Tue Sep 04, 2012 11:27 am
slainer wrote:Went to look at the MS250 today, I like it. The guys at the shop told me that they run promos for a free case in mid Oct, I think I can wait till they.
That's the way I bought mine. Sounds like you found a good dealer. No sweat off their brow if you wait for the promo. You'll have to do a mail in deal for the case and then they mail it to you. It's a nice case. My local dealer does a 2 for 1 saw chain sale every November. I buy 2 for each saw every time they are on sale. $70 worth of chains for $35! Can't beat that.I recommend the sharpening kit with the files and guides for your specific chain. It fits in the case. It only takes about 3 strokes a tooth to keep them sharp in the field. Always use Stihl bar oil. Some of the generic stuff is too thick and won't feed well. I have a little 1 gallon gas can for my saws. You can cut for days on 1 gallon with that saw.
Compared to the pro gear that is a cheap saw. But for us weekend warriors I've been real impressed with mine. A real Stihl for box store price. Start off with the "green" anti kick chains till you learn the saw. They are the safest and cut fine. They make more agrressive chains for it as well.
I'm all for buying used equipment but with a chainsaw I want new. You get the latest safety stuff that way. This saw will most likely still be running like a champ 10 years from now. That's worth the cost. Most of the used stuff out there is for sale for a reason. Plain worn out.
squatch
Postby slainer » Tue Sep 04, 2012 1:55 pm
Yea Mark, i agree with you on used saw are usually worn out. Most of the used saw I see on Craigs List look well worn for $200 or lightly used $250 but a brand new saw for $299 plus tax. Maybe a lager saw would be a better deal used as they go for more money to begin with.
Mark, what has me confused is the brochure they list two pitches, 3/8 for the 9 tooth bar and .325 for the 11 tooth bar, I amuse you have the latter bar on your saw? I really would like to start off fresh with a good saw, chain/bar and keep them all maintained and sharpened properly.
slainer
Postby Sags » Tue Sep 04, 2012 3:18 pm
I'll cast another vote for Husqvarna.
My father, brother and I ran a firewood business for a few years (buying truckloads of lodgepole pine, bucking and splitting it and selling it by the cord local)
We use a couple Husqvarna saws (don't remember model but one of the bigger ones) with Oregon 28" professional series bars and chains. With proper maintenance we never had any issues with them.
'99 Rodeo 3.2L LS 4wd, 5 speed, 265/75 r16s and 3" lift.
Sags
Have thanks: 42 times
Postby squatch » Tue Sep 04, 2012 3:33 pm
slainer wrote:Yea Mark, i agree with you on used saw are usually worn out. Most of the used saw I see on Craigs List look well worn for $200 or lightly used $250 but a brand new saw for $299 plus tax. Maybe a lager saw would be a better deal used as they go for more money to begin with.
I think they may have changed specs since I got mine but pretty sure I have what is recomended on this page. When I got mine the norm was a 16" bar. The 18" was an upgrade. Pretty sure both of my saws use the .325 chain. I would go with Stihl recomended. They know what works best with their saws.
http://www.stihlusa.com/products/chain- ... aws/ms250/ click specs.
Just a quick word about Stihls. They are high compression saws and can kick you with the pull cord. There is a reason some models come with a stretchy non kick pull start. You ride bikes you know what I mean. Occasionally when cold my big saw will kick and pull the cord out of your hand. The payback is a powerful saw for it's size. Neither of mine is a 1 pull starter when cold and each has it's own personality. 2 pulls full choke, then starts 1 pull on 1/2 choke kind of thing. once warm no issue at all. But neither is a hard to start saw either. Always start with the chain brake locked.
squatch
Postby slainer » Fri Sep 07, 2012 10:16 am
Well as luck would have it I found a used Husqavarna 55 very close to my house, with 12 good chains, case, brand new top end 20" and 18" bars for $50. Of course it need to be taken apart and correct some mistakes to make it run, but I got it running good. Funny thing is the guy I bought the saw from got a new stilh MS250c as a replacement for the Husqavarna.
slainer
Postby squatch » Fri Sep 07, 2012 3:05 pm
Sounds like you lucked out!
squatch
Postby slainer » Fri Sep 07, 2012 6:03 pm
Darn lucky, took a chance on an old saw and it worked out for me. I still would of liked to get that new ms250 but this saw will do for how little I need it.
slainer
Return to Tool & Shop
