WTB Folding trail jackstands
Postby Nelsoncycles » Wed Mar 22, 2017 2:18 pm
http://www.jkowners.com/forum/jk-genera ... stand.html
I would be really interested in something like the Slee prototype Has anyone bought anything similar to this product? What do normal people do when they have to do more than pull a tire? Is there a better option than cutting a section of log?
Nelson
Nelsoncycles
Re: WTB Folding trail jackstands
Postby Von » Mon Mar 27, 2017 10:58 am
I have no idea what normal people do.
Interesting thread though... those JK owners can get kinda pissy.
Pretty cool stands though, wonder why they haven't pursued that. That's the only jack stand design I've seen that I'd trust on soft ground though. Or carry around some lumber to put under a regular jack stand.
2004 Pontiac Grand Prix GTP
1965 Ford Fairlane 500 Sports Coupe 289 & 4 speed (some assembly required)
Von
Has thanked: 16 times
Have thanks: 34 times
Postby N law » Thu Mar 30, 2017 3:56 pm
Seems like if you need jack stands on the trail, you're in deep doo doo. I've seen everything from using nearby rocks or logs for cribbing under the frame. Most of the time though, unless you're changing a tire, an off-road rig will have clearance to climb under and fix a rear end or driveshaft issue. If you do have to pull the wheel to do brake or CV work, stick the tire between the frame and the ground. Keep your arms and legs out of the way while you work and just be careful.
If you really wanted to haul something around, get or build something like a dirt bike stand or the pedestal that elephants put their feet on at the circus as a stationary jack stand. But I would make sure it was wide and stable and only use it on flat, solid ground.
99 VX
96 Rodeo Build thread
1975 FJ40
69 Beetle
84 Westfalia
70 VW bus turned camper
86 VW Diesel Golf
07 Frontier V6 6 speed
1999 4Runner Limitee- wife's
2004 Genuine Stella Scooter
For this post the author N law was thanked by:
Nelsoncycles
N law
Has thanked: 17 times
Have thanks: 62 times
Postby BigSwede » Thu Mar 30, 2017 4:24 pm
Spare tire under the frame.
95 Trooper LS - 4" lift, 35" tires, 5.38 gears, ARB lockers
Indy4x Revolution 3.07:1 low range gears, Indy4x HD tie rods, homemade sway bar disconnects, Calmini HD sway bars, Darlington diff drop, OME 929 coil springs + 1" poly spacers and 1" body lift, Indy4x HD torsion bars, Indy4x HD rear axle links, Indy4x Kevlar brake lines, ARB bullbar, custom rear bumper with swing-out dual jerry can carrier, rock sliders, Sears Platinum Group 31 battery, ARB mini-compressor, Indy4x kevlar air lines, Warn M8000 winch, Blue Sea 6006 winch cutoff switch, Yaesu FT-1900R 2-meter ham radio, Larsen MHW-150C 1/2 wave antenna, Cobra 18WXST CB radio, Firestik II CB antenna, IPF driving lights, generic fog lights, two (2) Blue Sea auxiliary fuse panels, sleeping platform, and outofrshell Dave's custom 1" shifter extension. (I actually typed this list as a joke but people seem to like it.)
BigSwede
Has thanked: 14 times
Have thanks: 251 times
Return to Tool & Shop
