1989 Trooper Fuel Pump Bracket Ocala, Fl
This is the place to post if you have something to sell or are in need of a part (No commercial posts)
Postby JCS » Wed Jan 11, 2017 1:52 am
Looking for the mounting bracket housing for the electric fuel pump. Don't need the pump just the hardware unit the pump mounts into that is lowered into and screwed into the top of the fuel tank. Needs to be in good electrical and mechanical condition. The wiring terminals on mine went bad and I have been unable to located a feed-thru for the power wires. They are riveted on originally.
JCS
Re: 1989 Trooper Fuel Pump Bracket Ocala, Fl
Postby Ed Mc. » Wed Jan 11, 2017 3:39 am
If you can't find one in a wrecking yard, try Jerry Lemond in Dacula, GA.
If anyone would have that part, he would.
He's a user on this site, " JLEMOND ". Send him a private mssg and I bet he can help.
HTH...ed
'90 3.4 Troop LS;
Yes, I am a Trooper-Holic!!!
Keep On Troopin' !
Ed Mc.
Have thanks: 179 times
Postby RickP » Wed Jan 11, 2017 12:04 pm
4 cyl or V6 or does it matter?
RickP
Has a Trail Truck
Has thanked: 22 times
Have thanks: 26 times
Postby kg4miq » Wed Jan 11, 2017 12:23 pm
Fuel pump mounting bracket and housing does not matter if it's 4- or 6-cylinder. The pump is different, but the rest of the unit is the same.
How to rebuild a 2.6L 4ZE1 distributor
'92 Pickup - "Blacktail" - 4ZE1
'89 SE Trooper - "Vader" - 4ZE1
'89 Pickup - "Wicket" - 4ZD1
'90 S Trooper - "Nan" - 4ZE1 (possible V8 swap - Ford 302 with 5 speed?)
kg4miq
Has thanked: 21 times
Have thanks: 54 times
Postby RickP » Wed Jan 11, 2017 12:49 pm
kg4miq wrote:Fuel pump mounting bracket and housing does not matter if it's 4- or 6-cylinder. The pump is different, but the rest of the unit is the same.
Cool, thanks for the info. I think I may have one, but I just have to find it. I think it's in the shed and I'll check when I get home from work.
RickP
Has a Trail Truck
Postby JCS » Sat Jan 14, 2017 1:08 am
Thanks Rick
JCS
Postby RickP » Sat Jan 14, 2017 1:39 pm
JCS wrote:Thanks Rick
Sorry, I forgot about this. Yes, I have one. The only issue is that the connector is missing. Does $25 shipped sound ok?
RickP
Has a Trail Truck
Postby JCS » Thu Jan 19, 2017 11:56 pm
Doesn't matter Rick, I am going to drill out the riveted in power connectors on top and replace them with something more substantial. How can I get the funds to you?
JCS
Return to Classifieds
Users browsing this forum: 95BadBoy and 2 guests
