In search of 1st gen Diesel tachometer
This is the place to post if you have something to sell or are in need of a part (No commercial posts)
Postby 1988trooper2auto » Tue Jan 10, 2017 4:58 pm
I'd really like to keep the original trooper tachometer if I can when I swap a diesel into my trooper.
If you have one let me know. Thanks
1988 trooper 2 auto.. 2.6.. 4cyl. heat/air..
33's 3 inch body lift..3 inch suspension..flip balljoints and spacers. add a leafs.. one piece driveshaft.
hammer 22 inch rims lookin lovely in the summer.. 7 inch lip
custom wood grain dashboard..blue house/style carpet
1990 Isuzu Trooper ls SAS with spacers on 37 Wrangler Hummer Tires...
If you don't catch yourself looking back at your vehicle when you get out of it, why do you own it?
1988trooper2auto
Has thanked: 21 times
Re: In search of 1st gen Diesel tachometer
Postby kevins08 » Tue Jan 10, 2017 7:35 pm
I have a tachometer from a diesel, but i dont have the sending unit. lmk if you're interested.
1989 Isuzu Trooper - 2.8l/mua5
kevins08
Drives in Mud
Postby 1988trooper2auto » Wed Jan 11, 2017 10:32 am
On the 4jb1 the sending unit is in the injector pump. Is that the same area on the diesel 86?
If so it would just be wiring I believe.
1988trooper2auto
Postby kg4miq » Wed Jan 11, 2017 11:41 am
EDIT FOR CLARIFICATION: The tachometer in a gas-engine Trooper is different from the tach in a diesel-engine Trooper.
Jerry told me the sensors are different, and therefore, the tachometers are different as well, due to the type of signal sent.
I know for certain the connectors are different, with the diesel tach being a slightly larger connector, so the wiring is not just a simple "plug-n-play," unfortunately.
I don't have the connections worked out yet, but that will happen in the next week or two, as I've got to get it done, so the owner can come pick it up.
How to rebuild a 2.6L 4ZE1 distributor
'92 Pickup - "Blacktail" - 4ZE1
'89 SE Trooper - "Vader" - 4ZE1
'89 Pickup - "Wicket" - 4ZD1
'90 S Trooper - "Nan" - 4ZE1 (possible V8 swap - Ford 302 with 5 speed?)
kg4miq
Have thanks: 58 times
Postby kevins08 » Wed Jan 11, 2017 12:40 pm
I'm not sure, I just pulled the tach from a diesel at the yard as i was told that might be a hard to find part without realizing the sending unit was also needed. If you want to pay shipping, I would just send you the tach as i have no use for it personally.
thanks, Kevin
kevins08
Drives in Mud
Postby kg4miq » Wed Jan 11, 2017 12:43 pm
EDIT: I didn't realize this was someone else's request for a tach. Didn't mean to undercut or preempt that. Sorry. PM retracted.
kg4miq
Postby 1988trooper2auto » Wed Jan 11, 2017 12:47 pm
kg4miq wrote:Jerry told me the sensors are different, and therefore, the tachometers are different as well, due to the type of signal sent.
ok well im looking forward to what you come up with. my 4jb1 is incoming today(leavingshippin)
and plan to start soon there after.
i will make a thread for it when it get here.
so any help is appreciated.
so do you think other than the connector does it seem much more difficult. or what are people using for there swaps? i know there isnt many.
would a diesel tach be more useful or research my gas tach to work?
1988trooper2auto
Postby 1988trooper2auto » Wed Jan 11, 2017 12:49 pm
kevins08 wrote:I'm not sure, I just pulled the tach from a diesel at the yard as i was told that might be a hard to find part without realizing the sending unit was also needed. If you want to pay shipping, I would just send you the tach as i have no use for it personally.
thanks, Kevin
and kevin what is the milage behind the tach you have? i would think i would still need this one over my gas possibly.
1988trooper2auto
Postby kg4miq » Wed Jan 11, 2017 12:53 pm
Mileage on a tachometer won't matter, as long as it's working.
kg4miq
Postby 1988trooper2auto » Wed Jan 11, 2017 2:42 pm
Ahh i dont know why i was thinking the speedometer with the mileage on it
1988trooper2auto
Postby kg4miq » Wed Feb 01, 2017 1:10 pm
Okay, update on the diesel tach situation:
The tachometer is slightly different, due to a different type of pickup sensor on the fuel pump. If your fuel pump is equipped with the sensor (some aren't), you'll see two wires coming from the fuel pump tach sensing circuit - one is black and the other is black with red stripe (same colors as the gas engine tach signal, located over near the battery - two wire connection which stands alone). The black simply goes to a ground connection and the black with red stripe is the signal to send to the tach. I ran a wire from the fuel pump over to the connection near the battery, which was already wired into the instrument cluster, and made the dash connections easier.
Google "Isuzu pup tachometer conversion". I think it's the first link: http://www.isuzupup.com/viewtopic.php?t=12049 This thread deals with the C223 diesel, specifically, but I believe it's the same circuit modification for the 4JG2.
HTH,
/tim
kg4miq
Return to Classifieds
Users browsing this forum: No registered users and 9 guests
