2016 Hallowharrie Run Nov 3 - 6
This section is reserved for discussion of the Semi-Annual Isuzu Uwharrie Events
Moderators: DRaider90, Staff
Re: 2016 Hallowharrie Run Nov 3 - 6
Postby Hack » Fri Jul 29, 2016 9:39 pm
At least the Raider is rolling. Hopefully, the frame will stay in one piece. Sounds like you have to do a transplant. Maybe find one with a blown motor.
Mario
Hack
Have thanks: 123 times
Postby DRaider90 » Fri Jul 29, 2016 10:05 pm
Hack wrote:At least the Raider is rolling. Hopefully, the frame will stay in one piece. Sounds like you have to do a transplant. Maybe find one with a blown motor.
Supposedly according to a Fabricator buddy "he has seen worse", and would cut out and rebuild my frame in that section for $500. We will see. I have 2 sitting in the back that have good frames, so there is always that option.
Eli,
1988 Dodge Raider(Red): 170k, 2.6 I4 w/ Weber+K&N. 5spd KM145, SW Hubs, 34x9.5 Swamper TSLs, 4.62s & R/LSD, 1" T-Bar, 2" 4Crawler BL, some lights, CB, headlight washers and other neat stuff. Daily Driver Once Again
1988 Dodge Raider(Silver) & 1988 Mitsubishi Montero (Brown): Parts Rigs
2016 Ford Mustang GT: 11k, Premium Package, Flowmaster Outlaw Axlebacks
1996 Mazda 626:268k, Totaled
2013 Ford Mustang V6: 54k, Traded-In
DRaider90
Has thanked: 12 times
Have thanks: 5 times
Postby Hack » Sat Jul 30, 2016 9:07 am
Eli,
I went the fab route on my first (red) Trooper. I do not recommend it.
1. Even if you cut out the bad sections, the problem tends to show up somewhere else.
2. Everything takes longer to complete because the bolts are all seized. So you end up breaking bolts, cuzzing and then drilling them out, not to mention the cracked knuckles.
I ended up getting a Southern truck (the white Trooper) and transferring my good parts. If you have 2 trucks with good frames sitting in the yard, I'd definitely save the $500 and go that route. Even if it costs you a little more time and funds in the short run, trust me, you will be better of in the long run.
Mario
Hack
Postby TPR10inchIFS » Tue Aug 02, 2016 11:23 pm
I'm a maybe and looking at sites 13 or 15. I was in a motorcycle accident recently. A lady decided she didn't want to wait for me to stop and make a left turn. She crossed the double yellow lines as if to pass or go around me as I was turning left and and pin my leg between her bumper/tire and my R1. I'm on crutches and don't know exactly when I will be off them. I plan on being there but will wait a little bit longer to decide and reserve a spot. I have been taking this time from work to hobble out to the garage and weld up some things. I strengthened all the things I bent last year, the center link, the idler arm and the tie rod ends. I'm also replacing all the control arm bushings and may strengthen the rear diff track arms. Hope to see everyone there.....and yes Scarlet wants to make the trip as well!
DONE: 02 Isuzu Trooper Limited, 10" custom lift, 7"suspension, 3"body. Calmini torsion bars indexed, Rusty's coil overs with pucks, fitted Rancho 5000 shocks, widened/welded brackets for shocks, extended front sway bar links, Independent4x extended brake lines, Independent4x steering extension, Independent4x HD tie rods with custom spindle/hub assembly insert for full +- travel, custom shortened cv axles and custom welded front diff drop brackets for full +- travel, upper and lower ball joint shims/wedges with Independent4x ball joins swap spacers for full +- travel, extended body safety hooks, extended e-brake brackets, extended shift linkage, extended transfer case shifter, 1.5" front wheel spacers, rebuilt engine, rebuilt trans withe the "playing with fire" front PWM pump swap, 300-400rpm lower stall torque converter, external trans cooler, Super Winch manual locking hubs, ARB front bumper with angled end caps, driving light inserts, and mounted PIAAS, front/rear custom 3" bumper brackets, Surco roof rack on custom Bosch extruded aluminum sliding frame to cover or expose sunroof, custom fog light wiring harness to allow roof rack travel, front fogs, side "camping" fogs and rear reverse fogs on rack, cold air intake, thrush high flow muffler, rodeo head rests front and rear, oh *!$!@*! grab handles drivers side, custom sound with 6" speakers in rear and two 12" subs, six 17" Moto Metal wheels with BFG TA KO 315s (35") tires
TO DO: Warn Winch and reinforce bumper brackets, custom rear bumper, Ausie lockers, rear jump seat, rear oh *!$!@*! handles left and right. tint windows, 1/4" - 1/2" rear wheel spacers, upgrade brakes to dual pistons and slotted, custom rock sliders, all new poly bushings, convert all lights to led.
MIGHT DO: Snorkel, air shocks with onboard compressor, roof rack tent, dual alternators and battery, cb, front Reese hitch, winch Reese mount for using front or rear.
TPR10inchIFS
Postby Hack » Wed Aug 03, 2016 7:57 am
TPR10inchIFS wrote: I was in a motorcycle accident recently. . . I'm on crutches and don't know exactly when I will be off them.
Dang, I guess you are lucky that you are up and about. People just don't see bikes. Hope you make it.
Mario
Hack
Postby Timberwolf » Wed Aug 10, 2016 8:01 pm
Timber wolf (Earl) will be there. We are in space 35 arriving on Wed. 11/2. Look forward to seeing you all again.
Earl
1989 Amigo - 4.3, Blackbox I, 700Rr, SAS DANA 44 front and rear with ARB lockets and 5:38s
Timberwolf
Postby squatch » Fri Aug 12, 2016 2:34 pm
I'm in site 26 wed 11-2-sun 11-6.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 321 times
Postby shaggydoink » Wed Aug 17, 2016 2:38 pm
I sifted back through the pictures from the Spring gathering and wasn't able to find conclusive evidence on whether or not people made it out on any of the kayak trips? If not, does anyone have any interest in trying to fit one or two in over the course of this upcoming gathering?
Shaggy
Has thanked: 738 times
Have thanks: 377 times
Postby squatch » Wed Aug 17, 2016 4:52 pm
I actually had my solo canoe on the water for 3 days last spring. I may bring it again. A lot depends. I have my boat back on the water now so if the wife doesn't come I may bring that. If she does I'll be bringing the camper instead. Maybe with the canoe on the roof.
squatch
Postby slainer » Fri Aug 19, 2016 3:01 pm
shaggydoink wrote:I sifted back through the pictures from the Spring gathering and wasn't able to find conclusive evidence on whether or not people made it out on any of the kayak trips? If not, does anyone have any interest in trying to fit one or two in over the course of this upcoming gathering?
Shaggy
Yes I had my yak last time but was the only one so it just rode around on the roof of my trooper.
slainer
Have thanks: 27 times
Postby shaggydoink » Fri Aug 19, 2016 6:28 pm
OK, we can at least hit the caves!
Postby slainer » Sun Aug 21, 2016 8:45 am
Sounds good to me.
slainer
Postby 88toy4x4 » Sun Aug 21, 2016 5:33 pm
Got site 41 for Thurs to Sat. Got a buddy with a rover coming as well.
Stoked to get back there after almost 4 years! :D
1998 Taco - RIP
2000 4Runner - 4wd conversion and a few other things.
88toy4x4
Has thanked: 2 times
Postby lorenzo816 » Mon Aug 22, 2016 10:21 am
Maybe.
I marked my calendar.
Will keep ya posted
lorenzo816
Has thanked: 78 times
Have thanks: 50 times
Postby Van » Tue Aug 23, 2016 9:55 am
:thumbup:
88toy4x4 wrote:Got site 41 for Thurs to Sat. Got a buddy with a rover coming as well.
And I'm very grateful of you making that one and pulling me out of the soup bowl. :lol: :thumbup:
Van
Has thanked: 22 times
Have thanks: 87 times
Postby egagnon086 » Tue Aug 23, 2016 11:20 am
For those from GA do y'all normally all go caravan style or go your own way up there. I'm gonna try to attend this one, but don't want to get lost in SC/NC on the way to the woods.
egagnon086
Has thanked: 49 times
Have thanks: 82 times
Postby 88toy4x4 » Tue Aug 23, 2016 10:40 pm
Van wrote::thumbup:
Ahhh, good times. TIme for a snorkel, eh? :wink:
1998 Taco - RIP
88toy4x4
Postby Hack » Wed Aug 24, 2016 9:14 am
88toy4x4 wrote:Ahhh, good times. TIme for a snorkel, eh? :wink:
Naw. Van's strategy is to fill the bed with wood, so the truck will float. :lol:
Mario
Hack
Postby sassee » Wed Aug 24, 2016 1:03 pm
Nothing like having an exhaust system full of mud. 8)
The sad part is I think that was the last time we were there as well.
2000 Nissan Xterra SE, Daughters toy.
94 Trooper S 3.2 w/ a 5-speed brand new off the showroom floor in 1994.
88 Trooper LS GONE
89 Trooper XS (Red) - GONE to a good home in Alabama
89 Trooper SE (Blackie) - Gone to a good home but won't be forgotten anytime soon!
98 Acura SLX. Sadly, it lost the engine and I can't justify putting any more money in it. Gone to crusher.
95 LS Trooper bought for parts. Now gone to the crusher.
98 Trooper, 3.5 w/ a 5-speed. 15" Snowflakes with 31" AT's, 2" lift with OME 919's, KYB shocks. Manual hubs. My son's DD.
89 Trooper "Blue" 2.6 w/ "Jerry Cam", 5-speed, LSD Rear, Lock Rite in front, Manual Aisins, Big brake upgrade, Rock Sliders, 15" Snowflakes with 31" , AT's. MY DD!
sassee
Has thanked: 4 times
Have thanks: 124 times
Postby superman27344 » Wed Aug 24, 2016 2:30 pm
shaggydoink wrote:OK, we can at least hit the caves!
There are caves at Uwharrie? I really need to explore the rest of the place more instead of just the OHV trails.
Lou
2000 Trooper aka "Brawn", 3.5 liter V6, 5spd
1989 Trooper aka "The Armadillo", 2.6 liter, 5spd SOLD
Carolina Isuzu Owners Facebook Group
Brawn Build Thread
The Armadillo Build Thread
"It has been my experience that folks who have no vices have very few virtues."
-Abraham Lincoln
Has thanked: 416 times
Have thanks: 73 times
Postby shaggydoink » Wed Aug 24, 2016 7:41 pm
superman27344 wrote:There are caves at Uwharrie? I really need to explore the rest of the place more instead of just the OHV trails.
You and me both bud! There's a cool looking cave that's right at the dam at the bottom of Badin lake that I've seen people canoe/kayak into, there are also a few on land in that area that you can crawl around in... although after seeing so many rattlesnakes out in those parts I'm not all that interested in doing the latter. :shock:
For this post the author shaggydoink was thanked by:
Postby superswire » Mon Aug 29, 2016 1:23 pm
Haven't booked yet but I'm in. I will post dates as soon. As I decide. Vx won't be done but I should have my new zu ready to at least play a little :D
1999 vx, magnaflow, k&n drop-in, ome coils, 2" diff drop, rancho 9x, Darlington bump stop extensions, tones hidden hitch, reese basket on facory Yakima bars, mb razors w/ 33x12.50 Hercules M/T. (Currently undergoing a heart transplant because she seized up on me)
1999 rodeo ls, mua5, Moog cc784, Reese basket, 31x10.50 and some stickers !
Past zu's: '92 migo, '95 troop, '93 rodeo, '97 passport.
superswire
Has thanked: 30 times
Postby superswire » Mon Aug 29, 2016 1:37 pm
I wanna see you in a kayak Lou
superswire
Postby superman27344 » Mon Aug 29, 2016 1:51 pm
I would probably need a canoe instead of a kayak.
Lou
Brawn Build Thread
-Abraham Lincoln
Postby b1ganuf » Wed Sep 07, 2016 3:37 pm
hello everyone, just joined the group yesterday as i picked up a 00 rodeo 3.2 4wd for $500 with 156k on it. i live about 5 miles north of the eldarodo outpost and seen you guys are meeting up in november, i work allows im gonna try to at least come down saturday if not sunday too.
b1ganuf
Return to Uwharrie Forum
Users browsing this forum: Georgia159.com and 3 guests
