Georeferenced Uwharrie Trail Map for your phone/tablet GPS
This section is reserved for discussion of the Semi-Annual Isuzu Uwharrie Events
Moderators: DRaider90, Staff
Postby paulevans76 » Tue Oct 27, 2015 4:12 pm
A guy from my 4x4 club recently sent this around (clicky for big) :
Here's a (edit: NEW) direct link to download the map:
http://s000.tinyupload.com/download.php ... 4896310874
So basically, after you get the Avenza PDF Maps app on your device, just open this thread on said device, download the pdf in the link there, then open the map file with the app, and viola, you can keep track of where you are out on the trails. Pretty cool, IMO.
If the link doesn't work, just let me know and I'll find another place to host it.
paulevans76 was thanked by:
HackVan
Has thanked: 82 times
Have thanks: 86 times
Re: Georeferenced Uwharrie Trail Map for your phone/tablet G
Postby Hack » Tue Oct 27, 2015 6:06 pm
When you download the file, my iPhone asked which app to open it with. I had to select the Avenza PDF Maps app. Then when I went to the app, I saw the Uwharrie map.
Mario
Hack
Has thanked: 7 times
Have thanks: 128 times
Postby shaggydoink » Tue Oct 27, 2015 7:36 pm
Very cool Paul, thanks for posting this up!! :thumbup:
Has thanked: 750 times
Have thanks: 385 times
Postby Ssiggy » Tue Oct 27, 2015 8:04 pm
We installed it on both phones. Thanks!
THERE IS NO DANA ONLY ZUUL!
Well, there IS a Dana-- a Dana 44
'99 Amigo 3.2 AT 4WD - 2" body lift, 3" suspension lift, revos, Aussie Locker front, sliders, Superwinch 9K, vinyl wrap, VX seats, OME 912 springs - Rolled but running
'92 Amigo (from Shaggy) future project
90 Amigo 2.6 5-sp 4WD - 3" body lift, 3" suspension lift, Calmini uppers, Calmini headers, Delta cam, Jet chip, sliders, revos, Warn brush guard/winch mount, ProMark 12K winch, snakeskin wrap
Ssiggy
Has thanked: 21 times
Have thanks: 64 times
Postby paulevans76 » Tue Oct 27, 2015 9:02 pm
Hack wrote:When you download the file, my iPhone asked which app to open it with. I had to select the Avenza PDF Maps app. Then when I went to the app, I saw the Uwharrie map.
You did it perfectly!
Postby Hack » Wed Oct 28, 2015 6:15 pm
Also went through the list of maps in the app and found several free ones for areas that I wheel including Assateague National Seashore.
Mario
Hack
Postby Van » Wed Oct 28, 2015 7:57 pm
I'll have to try it when I get a chance, I've been looking for something like this for awhile. :thumbup:
Van
Has thanked: 22 times
Have thanks: 87 times
Postby shaggydoink » Thu Oct 29, 2015 7:59 am
I'm getting a "couldn't process map file" error with the Uwharrie map on Android... grrr.
Postby paulevans76 » Thu Oct 29, 2015 8:58 am
shaggydoink wrote:I'm getting a "couldn't process map file" error with the Uwharrie map on Android... grrr.
Did you open it with the Avenza PDF Maps app? If so, maybe try downloading the map over again?
Postby shaggydoink » Thu Oct 29, 2015 9:18 am
paulevans76 wrote:Did you open it with the Avenza PDF Maps app? If so, maybe try downloading the map over again?
Yeah, it's Avenza PDF Maps - and I've tried to download the maps itself couple times via different ways. I'm going to try and find some other maps just to see if it's the app or map file specifically.
Postby paulevans76 » Thu Oct 29, 2015 9:47 am
hmm. weird.
Postby MarcusInMD » Thu Oct 29, 2015 10:43 am
Same problem here with android. lollipop.
99 Trooper. Black 161k miles - April 2015 AT Rebuild
MarcusInMD
Has thanked: 15 times
Have thanks: 23 times
Postby MarcusInMD » Thu Oct 29, 2015 10:59 am
The PDF program works fine. I think that the uploaded file is where the problem is located.
I was able to download a Uwharrie map right from the program for free. Click the shopping cart button and then do a search for Uwharrie and then show the list. The first one is provided by the USFS and has the trails on it as well. There are other maps as well but they cost $. I think there is also a free topo map of the area for download.
MarcusInMD
Postby shaggydoink » Thu Oct 29, 2015 12:46 pm
MarcusInMD wrote:The PDF program works fine. I think that the uploaded file is where the problem is located.
Thanks for the info on this Marcus, I'll off to find the map!!
Postby shaggydoink » Thu Oct 29, 2015 12:51 pm
Bingo! Thanks again Marcus!!
Postby paulevans76 » Thu Oct 29, 2015 1:59 pm
Sweet! I bought the brown mnt map for 3 bux as well.
Postby paulevans76 » Thu Oct 29, 2015 2:08 pm
I rehosted the file with the same site, maybe this one will work better for y'all.
The USFS map is great but isn't as colorful and detailed. Hope the new file works!
Postby MarcusInMD » Thu Oct 29, 2015 4:00 pm
I dint think the file is a valid off file.
MarcusInMD
Postby Van » Mon Nov 02, 2015 5:17 pm
I downloaded the app, then the link you provided in the 1st post (several times).
It then opened up a "Playerme.com"....... Never mind, I think it's working now. :?
Van
Postby Hack » Mon Nov 02, 2015 6:31 pm
You don't need the link. Just open the app and browse the maps. You will see the free Uwharrie map towards the end of the list.
Mario
Hack
Postby MarcusInMD » Mon Nov 02, 2015 6:40 pm
The only one that I see that is free is at the very top. it says Uwharrie National Forest (provided by USDA) I searched for Uwharrie and did the list view (as I mentioned above)
What is this other map called on the map store?
MarcusInMD
Postby Hack » Tue Nov 03, 2015 12:21 am
MarcusInMD wrote:The only one that I see that is free is at the very top. it says Uwharrie National Forest (provided by USDA) I searched for Uwharrie and did the list view (as I mentioned above)
Go to the store. Search on Uwharrie. There is a map titled "Uwharrie National Forest" that is listed as free. It is published by jodybgoode and was uploaded Dec 16, 2014.
Mario
Hack
Postby MarcusInMD » Tue Nov 03, 2015 1:17 am
Yeah, thats the one that I downloaded a few days ago. I don't think that is the map that was hosted above? The one above has more detail? I have no idea.
MarcusInMD
Postby paulevans76 » Tue Nov 03, 2015 10:55 am
The free map on the app is a different map than the one I posted. The road numbers are there but the trail names and descriptions aren't. The one I posted is basically the same but with an overlay of a common Uwharrie trail map with legend and trail info. (here's a snapshot):
Return to Uwharrie Forum
