Hallowharrie 2015
This section is reserved for discussion of the Semi-Annual Isuzu Uwharrie Events
Moderators: DRaider90, Staff
Re: Hallowharrie 2015
Postby MarcusInMD » Wed Nov 18, 2015 2:22 pm
Excellent ideas. :)
99 Trooper. Black 161k miles - April 2015 AT Rebuild
MarcusInMD
Has thanked: 15 times
Have thanks: 23 times
Excellent ideas. :)
MarcusInMD
Postby squatch » Wed Nov 18, 2015 3:38 pm
Marcus, For individual tubes take a length of 4x4 and drill a hole lengthwise the same diameter as the tubing with a long bit. Now slice the 4x4 lengthwise through the middle of hole. you can now place 1/2 of the 4x4 on each side of the tube and c lamp it with some C clamps. This will do wonders on short bends in each tube. For the bigger rougher stuff you can use 1/2 the same board and press against it with a high lift jack or ect. I used this same technique to straighten a bent rail on my boat. Previous owner had hit a deer on rt 50 going to the ocean. Deer missed the truck and hit the boat on the trailer. Left a pretty good dent on one side.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 328 times
Postby MarcusInMD » Sat Nov 21, 2015 9:25 am
Hack wrote:My mileage on that tank of gas was about 2 mpg less than on the rest of the trip. Squatch said his engine was pinging on that gas. So I think that was a lot of your problem although there is still some electrical issues with those trailer lights.
Looks like that electrical issue with the trailer lights was that flakey turn signal bulb.
we towed the camper last night and the lights worked perfectly with a simple plug them in and test.
Crazy!
MarcusInMD
Postby Hack » Sat Nov 21, 2015 10:00 am
Good deal!
Mario
Hack
Has thanked: 7 times
Have thanks: 130 times
Previous
Return to Uwharrie Forum
