89 TROOPER COLLIDING WITH 79 LANDCRUISER
Postby steve_gicas » Sun Aug 10, 2014 3:57 pm
BEEN WORKING AN THIS RIG FOR AWHILE NOW, I ORIGINALLY PUT A TOYOTA SOLID AXLE AND A 22RE WITH W56 TRANS AND TCASE. WAS AWESOME, AND I HAD LOADS OF FUN WITH IT..... BUT IT WAS LACKING IN SOME AREAS. PAY LOAD WAS NILL, THE STOCK TROOPER FRAME DIDNT ALLOW FOR MUCH UP TRAVLE IN THE FRONT SUSPENSION WITH OUT LIFTING IT A BUNCH MORE, AND FUEL ECONOMY AND RANGE WASNT ALL THAT GREAT.
SO I STARTED TO CHOP
THEN I GOT SOME AXLES
[img][IMG]http://i186.photobucket.com/albums/x55/bike_slut/IMG_1713_zps4589b8e8.jpg[/img][/img]
DID A CUT AND TURN ON THE FRONT AXLE AND CENTERED THE REAR WITH MINI TRUCK OUTERS
BUILT A FRAME AND HUNG SUSPENSION
BUILT AN ADAPTER PLATE TO MOUNT A 5SPD TO THE DIESEL , AND NOW IM WORKING ON THE MOUNTS. HOPEFULLY I CAN GET THE BODY ON IN THE NEXT WEEK
SPECS SO FAR ARE
TOYOTA 2.9L B DIESEL WITH R151F 5SPD GEAR DRIVEN T-CASE WITH 4.7 LOW GEAR (MOCK UP MOTOR IS A 3.4L 3B THAT WILL GET A FULL OVERHALL WITH TURBO)
TOYOTA FJ40 DIFFS REAR IS CENTERED WITH MINI TRUCK OUTERS WITH FRONT HUBS TO MAKE FULL FLOATER, WITH ISUZU REAR CALIPERS..GONNA GET SOME 4.88S WITH ARB WHEN $$ ALLOWS
GOOD YEAR 33X12.5R15
91 4RUNNER IFS STEERING BOX, GOT A GM STEERING COLUMN OUT OF A 79 TRANS AM FLOOR SHIFT CAR.
PLAN ON GETTING A AMERICAN AUTO WIRE WIRING HARNESS
GM HYDRO BOOST BRAKE BOOSTER.
NO THAT THE DRIVE LINE IS 90% COMPLETE I CAN SET THE BODY ON AND SEE WHAT IM GONNA HAVE TO CHOP OUT OF THE FLOOR
For this post the author steve_gicas was thanked by:
ervan
steve_gicas
Re: 89 TROOPER COLLIDING WITH 79 LANDCRUISER
Postby Hack » Mon Aug 11, 2014 11:25 am
Wow. This looks like a great project. Keep us informed of your progress.
Mario
Hack
Has thanked: 7 times
Have thanks: 128 times
Postby wmorrisiii » Mon Aug 11, 2014 1:35 pm
This would be a little more extensive than a bolt on modification...be following this to see how it turns out! Gret work!
The Duck Marsh Debutante
The Coonhound
wmorrisiii
Has thanked: 86 times
Have thanks: 177 times
Postby mudoilngears » Mon Aug 11, 2014 5:50 pm
Wow! Lots of work you've put into that machine! Just out of curiosity, why did you choose the B engine specifically?
1998 Rodeo LS 4x4 4JB1-TC Diesel Swap, more mods to come!
Build in progress...
mudoilngears
Has thanked: 12 times
Have thanks: 64 times
Postby chuffer » Mon Aug 11, 2014 10:24 pm
Neat project. There were a couple of minutes where we were really close to lopping off the front of my frame due to the uptravel problem.
Just out of curiosity, why leaf springs in the rear with the 3-link panhard up front? Would a four link in the back with a sway bar, be a more balanced match?
Either way, nice work so far. Cool stuff. Bradzipple here on the planet keeps threatening to link my Trooper.
-Chris
chuffer
Has thanked: 48 times
Have thanks: 119 times
Postby steve_gicas » Tue Aug 12, 2014 11:44 am
Thanx guys, it has been a lot of work.. But it's a labour of love...
Well the body bolts on... So technically it's a bolt on mod for a trooper... Haha
I went with leafs in the rear for pay load capacity. It will be an expo rig in the end, so with 2 spare tires, extra fuel, recovery gear ect it will get heavy.... Mans I had plan to reuse my old leafs but they turned out to be broken.... And as for the B diesel, where I am there are lots around, it's a bullet proof motor.. And in the next 4 Years I plan to drive to South America and hopfully ship it to Africa, and that motor is everywhere in Africa.. In the end I'll be running a 3B with a turbo
steve_gicas
Postby leftarmtan » Tue Aug 12, 2014 2:50 pm
Looks great man,looking forward to this build.My 89' also has some LC parts hiding under it.
89' trooper SAS 4.3
April 2014 ROTM
leftarmtan
Has thanked: 15 times
Have thanks: 12 times
Postby electricpuppyboy » Sat Aug 16, 2014 7:31 pm
Wow! Nice work!
Subscribed.
-Bob
Image Image Image Image
1988 Trooper LS 4ZE1 mua5 - "Build" Story
1990 Trooper S 4ZE1 mua5 - Being parted out - click for parts
1989 Trooper RS 4ZE1 Auto - gone
1989 Trooper LS 4ZE1 Auto
electricpuppyboy
Has thanked: 28 times
Have thanks: 43 times
Postby steve_gicas » Tue Sep 02, 2014 3:07 am
GOT A LITTLE MORE DONE ON THE TROOPER LAST WEEK.. BODY IS SITTING ON THE FRAME, GRABBED SOME 37" TIRES FOR MOCK UP AND HAVE BEEN PLAYING WITH WHEEL OPENINGS. I THINK IM GOING TO STRETCH THE OPENING AND KEEP THE STOCK BODY LINE. ALL SO GOT THE INSIDE GUTTED AND STEERING COLUMN AND BRAKE BOOSTER MOCKED IN PLACE.
GOT IT OFF THE OLD FRAME
MAKES THE 33s LOOK TINY
FLOOR CUT OUT FOR THE TRANS AND TCASE
GM STEERING COLUMN ZAP STRAPPED IN PLACE.... I HAD TO PUT IT IN SO I COULD SIT BEHIND THE WHEEL AGAIN AND SHIFT SOME GEARS... LOL
HYDRO BOOST WITH TROOPER PATTERN AND I JUST THREADED THE ROD TO ACCEPT THE TROOPER CLEAVES... ITS A "BOLT IN" MOD
FRONT END SITTING ON WITH THE 37s ( ACTUALLY 39.5 BUT THEY MEASURE A C-HAIR OVER 37)
NEXT UP IS BODY MOUNTS AND DRIVE LINE. IM THINKING OF CUTTING THE ROCKERS OFF AND REPLACING THEM WITH SOME 5X2 REG TUBING LIKE SLIDERS AND DOING MILD BOAT SIDE KINDA DEAL. THEN THERE WILL BE SOME 1X2 REG TUBING FOLLOWING THE FENDER LINE FOR RUB RAILS THAT WILL TIE INTO THE BUMPERS AND SLIDERS.
steve_gicas
Postby chuffer » Tue Sep 02, 2014 10:20 am
Looking good. Stoked to finally see some wheeling related body work on one of these. Rub-rails on the fenders and boatsides? Yes, please!
My advice: figure out a way to protect your d-pillar too. Maybe it is just me, but I can't keep that stoopid thing outta trouble.
Is that ride height? What's the belly height? It looks pretty tall, but it might be the pics...
-Chris
chuffer
Postby steve_gicas » Thu Sep 04, 2014 4:07 am
yes thats ride height in the front, rear should come down about 2-3in. at ride the belly is 25" and the bottom of the rockers will be 28.5-29 with the little bit of boat side. ya i wanna do a full low pro exo cage.. kinda incorporate a roof rack and rear ladders into it. im trying to find myself a mitsubishi delica with the crystal roof and transplant that roof on to the trooper, i think that woud be super sweet.. the measurement from drip rail to drip rail is the same for both vehicles so it would be relatively easy.
steve_gicas
Postby wmorrisiii » Wed Sep 10, 2014 9:51 pm
Damn I really like this. A tree climbing beast of a ride! Best bolt on mod I've ever seen...again...great work!
The Coonhound
wmorrisiii
Postby steve_gicas » Fri Sep 19, 2014 4:06 am
small update, havent had much time to work on this thing in the past couple weeks, been super busy with work...... but i was in sheet metal mode all week so i decided to take the zip disc to the trooper once again.. let me know you all think, im not sure how i feel about the rear
at ride height
full bump
and the rear
im also thinking of filling in the stock tail lights and putting flush mount LEDs into the bumper, then i can run some tubing up the rear on the corner for protection. hopefully netx week ill have the metal for doing rock sliders and body mounts....
steve_gicas
Postby Hack » Fri Sep 19, 2014 8:34 am
Looking good. It is getting there.
Mario
Hack
Postby paulevans76 » Fri Sep 19, 2014 8:41 am
Digging the body work. I want to see how you get the interior cargo area finished and whatever issues you run into (if any). I'm planning to do some work in the cargo area and I'm wondering if it's any sort of special pain in the ---.
Has thanked: 82 times
Have thanks: 86 times
Postby mustanger999 » Fri Sep 19, 2014 4:35 pm
I like how you enlarged it by moving the openings instead of just hacking them out. It doesnt look too complicated either. Very nice!
Truth. The pill that everyone wants, but cant seem to swallow.
Planetisuzoo/Isuzu FB Groups Member map
'89 Trooper RS, 2.6 5spd, Smittybilt rear bumper Sort of build thread
'89 Trooper: 2.6 5spd, Weber 32/36, Round eye swap, 3" body lift, Sliders, Auto-Meter center cluster, Hand throttle. Build thread
SOLD '93 pickup: 2.6 mfi, 4x4, 5spd, Passport Bucket Seats, Intermittent wiper added. Build Thread: forum.planetisuzoo.com/viewtopic.php?f=15&t=72720&p=639130#p639130
mustanger999
Have thanks: 80 times
Postby steve_gicas » Tue Sep 30, 2014 3:55 am
another small update... been playing with the rear end, got my adapters made up to bolt front toyota spindles and hubs with solid brake rotors on to the stock toy wheel bearing flange.
so with some custom 30 spline shafts and drive flanges i will have a full float rear axle
im using 83 toyota pick up front spindles, hubs and rotors along with the stock isuzu trooper rear calipers. i torched out a 1/2" think bracket to mount the caliper and welded her up..
also scored this sweet gas filler from one of my customers.... most expensive gas cap on an isuzu trooper ever... lol
steve_gicas
Postby Hack » Tue Sep 30, 2014 8:05 am
Not much left now,
Mario
Hack
Postby geoffinbc » Thu Nov 06, 2014 11:52 pm
What master cylinder did you end up using? I am switching to Hydroboost and thinking of using a mid 90's 1 ton master cylinder. They are 1.25" bore. In the early 2000's they got even bigger and were 1.375" Both have the outlets on the wrong side but I think I will use AN lines to jump from the master to the proportioning valve.
geoffinbc
Has thanked: 8 times
Have thanks: 323 times
Postby steve_gicas » Fri Nov 07, 2014 12:16 am
I ordered a wilwood Product Number: 261-13269-P With a 1" bore... Stock is 3/4 bore i believe, wich was plenty with the big toyota 4 piston brakes up front.. So I figure 1" will give me even harder of a pedal
steve_gicas
Postby geoffinbc » Fri Nov 07, 2014 1:14 am
The stock Isuzu one is 1". I saw some of the aftermarket ones but I would prefer something more common so it is easy to rebuild or replace.
geoffinbc
Postby totten » Wed Nov 26, 2014 8:17 pm
Great job. Like the fenders mods, the adapter plate for 5-speed and your fab skills-welding,metal work. Thanks for pics,Tony :arrow:
totten
Have thanks: 83 times
Postby chuffer » Wed Nov 26, 2014 8:30 pm
I like the tub-mod. What's the plan for the sheet metal on the inside?
-Chris
chuffer
Postby TacoSupremez » Thu Nov 27, 2014 10:30 pm
Your trooper is what mine wants to be when it grows up. Subbed.
1996 Trooper SE / Fully Loaded
TacoSupremez
Postby Viggen » Fri Dec 05, 2014 10:59 am
As an ex owner of a 3B powered BJ60, good motor choice. With the right sized turbo, plenty of power is there.
Also, restoration on a MKIII Sprite/ MKII Midget?
Viggen
Return to Hall of Fame
