To turbo or not to turbo my 3.2 ??
Re: To turbo or not to turbo my 3.2 ??
Postby bradzuzu » Fri Aug 09, 2013 8:07 pm
The guy made it sound like it gives input now, I hope so..!!
No injectors yet !! Need to stop down at a few yards next week..
Has thanked: 214 times
Have thanks: 375 times
Postby bradzuzu » Sat Nov 02, 2013 12:33 am
Finaly getting back to this after getting all the wiring ports identified .. Good news is it runs with the bypass plug, bad news I couldn't get the labtop to interface so the fic is tucked under the dash doing nothing but sucking on the vac line :)
I brought the PC home , hopefully tomorrow I can get something to link up and start programming ...
Postby JFoster » Fri Mar 13, 2015 3:08 pm
kickerfox wrote:
bradzuzu wrote:Yep !! Asked about the wide band , they have a new one that sends signal to the tuner for even better programming and sensing..
New one? All the widebands have a 0-5v output for tuning. It's still not going to tune it for you. The FIC just uses it for logging and it's virtual gauges.
Did you order up some injectors too?
Does the FIC allow you to edit both fuel and timing maps?
I think it's already been said but if you're not richer than 12:1 by the time you get to 2-3psi then you are creating really high egts.
JFoster
Drives in Mud
Have thanks: 5 times
Postby chuffer » Fri Mar 13, 2015 7:56 pm
This thread kinda died out...current discussion on this build is here:
viewtopic.php?f=15&t=56799&start=2225
-Chris
chuffer
Has thanked: 48 times
Have thanks: 119 times
Previous
Return to Hall of Fame
