ABS Light along with the "fix"
Postby ssmokn » Sun Dec 25, 2011 9:02 pm
Posting this up as I thought it may be helpful to somebody sooner or later...
My '01 Trooper lit up the ABS light recently. The light was on almost all the time (would go out briefly once in a while).
First I checked both the 15 and 40 AMP fuses (both OK). Then I inspected all the wiring that I could get to for the front and rear wheel sensors. I didn't find any shorts or other problems. Next I shorted pin 12 to ground (pin 4) on the OBD-II connector using a paperclip. The ABS light flashes displaying code 12 (Self Test Working System OK) and code 43 (RF Holding Solenoid open/shorted). Note: If you have never done this before (I hadn't) it displays each code three times (12, 12, 12, 43, 43, 43).
I pulled the connector off the EBCU and everything was in great shape (no corrosion etc.) I cleaned it out anyway with some electronic contact cleaner and blew out both sides of the connector with some compressed air (no change).
So looks like maybe the wiring to the RF solenoid fried in the EBCU (the electrical half of the ABS unit under the hood behind the right headlight).
I contacted Jerry to inquire about a new ABS uint. Jerry informed me that they are about $2600 wholesale :shock: He recommended going with a used one from a boneyard. I checked a number of local yards. There are quite a few ABS units available at all sorts of prices (average price is about $125). The only problem is that a used one is most likely going to fail like my existing one sooner or later (hopefully later).
I then decided to google "ABS repairs". At least two shops came up that repair ABS units. I looked over a couple of websites and decided to call Module Masters http://www.modulemaster.com. Based on the information on their website the unit in my '01 Trooper is a Bosch 5.4 unit. I spoke to the folks at Module Master told them what unit I had (Bosch 5.4), the error code (43) and the vehicle.
They stated that they could most likely fix it but probably not test it (different electrical connector that they aren't setup for). They said ship it to us and we will inspect it. If we can't fix it you don't pay any bench time only shipping both ways. If they can fix it they would charge me $160 plus return shipping and if it didn't work (assuming they couldn't test it) they would refund all my money less shipping if I still had the problem.
I figured this was a no brainer. Shipped my unit out to them. They got it on a Thursday afternoon. They called me back Monday morning and said it is all done. Price was $177 ($160 for the repairs with a 5 year warranty and $17 for 2 day return shipping).
Got the unit back and it works perfectly. So if you come across problems with your ABS unit you may want to give Module Masters your business. They were really outstanding to deal with. Easy to get on the phone, helpful, reasonable cost, fast service and very generous warranty.
I have no affiliation with Module Masters other than I'm a very satisfied customer. If you run into ABS problems, repair may be an option depending on the issue.
- Cliff
2001 Trooper S 3.5L 6VE1, Auto 4L30e, TOD, 130K+
ssmokn was thanked by:
John in NCkelly551Patdog
ssmokn
Have thanks: 6 times
Re: ABS Light along with the "fix"
Postby JY » Tue Dec 27, 2011 1:07 pm
I've had the same '43' code for years, and finally got around to swapping out the old pump with a bone yard pump, and got the same exact code back(even after clearing the codes)!
Just to clarify: are the EBCU and the pump the same thing?
I've been messing with this ABS thing on and off for years. The only time the light is off, is on very cold mornings. Lasts about a mile or two, then comes back on for the day.
I haven't really used the ABS, but the fact that I know it's not working bugs me:)).
I'd sure like to get that light to go out without me pulling the bulb!
JY
Postby ssmokn » Tue Dec 27, 2011 9:13 pm
I'm no expert but the EBCU (Electronic Brake Control Unit) is the black portion of the ABS pump in your picture above. There are two electrical connectors (one on the bottom that you can't see and the big one on the top.
You remove the EBCU (black portion) but unhooking the two wiring harness and removing the six torx screws (need a T20 driver). Four of the six screws are easy to get to. Two are a bit more difficult. Took me about 75 minutes to remove it and about 40 to put it back (it's always easier once you do it once and I don't work all that fast).
I removed the grill and headlight and went through the headlight opening to get the other screws. Mail off the EBCU and they fix it and send it back. You can even drive the vehicle when it is out. You are not opening up the hydraulics at all.
If interested read modulemaster.com website and/or give them a call. Their FAQ has some info. and there is even a trouble shooting section.
The light was driving me nuts too and I'd rather keep everything working on my truck rather than just let stuff go into disrepair.
For this post the author ssmokn was thanked by:
JY
ssmokn
Postby bsmart10 » Wed Feb 12, 2014 1:30 am
I was able to get the large electrical plug off the front block by pulling the 'handle' on the right side of the black block toward the radiator about 2 inches, then pulling straight up on the connector itself. Cute retaining mechanism.
bsmart10
Super Trooper
Postby cptcljerjr » Thu Nov 27, 2014 5:06 pm
I think this trooper is for sale in NY
Carl
Veteran
Albany, NY, USA
http://www.cardomain.com/ride/2528787/2 ... u-trooper/
"Men sleep peacefully in their beds at night
because rough men stand ready
to do violence on their behalf."
cptcljerjr
Postby wbuz5707 » Sun Mar 15, 2015 5:29 pm
I have a 2004 axiom with abs light on all the time,how do I go about testing abs thanksbill :alien:
wbuz5707
Postby JoeIsuzu » Thu Apr 30, 2015 4:43 pm
wbuz5707 wrote:I have a 2004 axiom with abs light on all the time,how do I go about testing abs thanksbill :alien:
Great question, but this topic is about an '01 Trooper. Please start a new topic for yours. Taking someone else's topic over is called a "hijacking the topic", or in shorthand, a "threadjack".
Jack
Original owner, 1983 Isuzu P'up LS Diesel. Engine overhauled by JLEMOND. Ready for new paint now!
1994 Isuzu Amigo 2wd
IsuzuPup.com
"There are no dumb questions"?! Maybe not...
but there are smart ways to ask. Old, but classic:
How To Ask Questions The Smart Way
JoeIsuzu
Has thanked: 73 times
Have thanks: 76 times
Postby cptcljerjr » Thu Apr 30, 2015 7:25 pm
do axioms use the same TOD system as our troopers ? :bigsmurf:
Carl
Veteran
Albany, NY, USA
cptcljerjr
Postby John in NC » Tue Feb 09, 2016 5:16 pm
Thanks ssmokin I used your guide to get my ABS fixed!
2002 Trooper
viewtopic.php?f=1&t=85789
John in NC
Return to Hall of Fame
