T case hybrid build- 92 auto gears into mua5- Done !!!
Re: Auto t case gears into manual t case ???
Postby BigSwede » Wed Nov 02, 2011 9:19 am
bradzuzu wrote:You mean just to show it's location ??
Mostly I just wanted you to be aware of it so you don't forget it during re-assembly.
BigSwede
Has thanked: 14 times
Have thanks: 251 times
Re: Auto t case gears into manual t case-- same ratio !!!
Postby psguardian » Wed Nov 02, 2011 10:47 am
Ok so the wimpy gears got introduced in '97 for auto & manual transmissions. JLEMOND also said the full gear set out of an earlier auto tcase should fit just fine, butt you'll need all three sets out of... say... A 92-95 auto tcase.
~psguardian
hot 2.6L build
Her Rig: '06 TrailBlazer Ext 4.0L Strait 6 (my Daily Driver till my rig is street legal)
Dae wrote:Jerry is the Chuck Norris of Isuzu's, he could build one blind folded with one arm behind his back if he had to. :lol:
PNW Zoo Facebook Group
psguardian
Have thanks: 26 times
Postby bradzuzu » Wed Nov 02, 2011 12:02 pm
So that ratio difference would be around .10- .12 difference ??? Thanks BigSwede !!! Atleast that one was on the bench and easy to deal with. Made for a great write up/how to...
Has thanked: 207 times
Have thanks: 366 times
Postby psguardian » Wed Nov 02, 2011 12:22 pm
Brad if you can get hold of a 2nd gen 4L30E transfer case the full gear set will swap over (according to Jerry), this would be an even more notable upgrade then what you thought you were in for.
We all thought you would be getting this upgrade... 0.38:1 gain
1{eng}*3.767{man. 1st}*2.28{man. t-case low}*4.10{diffs}=35.214:1 (<-- 92-96 man.)
1{eng}*3.767{man. 1st}*2.66{auto t-case low}*4.10{diffs}=41.083:1 (<-- 92-96 auto)
You would actually be getting this upgrade... 0.61:1 gain
1{eng}*3.767{man. 1st}*2.05{man. t-case low}*4.10{diffs}=31.662:1 (<-- 97+ auto & man.) (<-- your current crawl ratio)
Or you can get Revo lows for your application... 1.02:1 gain
1{eng}*3.767{man. 1st}*3.07{Revo Low}*4.10{diffs}=47.415:1 (<-- 97+ Revo low)
~psguardian
hot 2.6L build
For this post the author psguardian was thanked by:
psguardian
Postby bradzuzu » Wed Nov 02, 2011 12:59 pm
That's what the doner transfer case is from I think... 99 amigo with the 4l30E, when I counted teeth they apear to be an exact match. I didn't count teeth on the low drive idler gear that's on the main shaft, but counted the intermediate shaft and they had the same values... You would have to have atleast two different gears to mesh. What year are we talking about ???
Thanks do much for your efforts Psguardian !!!
Postby bradzuzu » Wed Nov 02, 2011 1:02 pm
Come on guys chime in let's get some values put in retrospect !!!!
Might be able to build a hybrid !!!
Postby psguardian » Wed Nov 02, 2011 1:20 pm
I think you misread that. You will need a PRE 96 donor. Yours is 97+ so you have 2.050 & your 99 auto has 2.050... You need an auto tcase 92-96.
~psguardian
hot 2.6L build
psguardian
Postby bradzuzu » Wed Nov 02, 2011 2:22 pm
So sorry just kick me !!!! I need a early 90's or mid auto t case gear set !!!
Anyone have some ????
Pm Me !!!
Re: T case hybrid build- looking for mid 90's auto t case ge
Postby bradzuzu » Thu Nov 03, 2011 5:11 pm
I found my doner !!! Thank you 92 trooper may your parts live on in my amigo !!!
Thank you Psguardian for making phone calls for me !!! :)
I did a low drive rotation count and it's a little over 2-1/2 revolutions .....:)
Postby psguardian » Thu Nov 03, 2011 5:56 pm
I did some web crawling, Jerry confirmed a few things for me also lol. I have a feeling the 92-96 auto tcase is about to become slightly more desirable to crawlers with 97+ rigs lol.
~psguardian
hot 2.6L build
psguardian
Postby bradzuzu » Thu Nov 03, 2011 6:37 pm
It looks good inside !!! Probly will even use the bearings..
Now I get to tear this one apart, and yet one more after that lol...
Thank God it will be worth it !!!
Postby bradzuzu » Thu Nov 03, 2011 9:00 pm
Yep it happens and hears proof !!
She's seen some abuse !!! Hopefully I can swap hubs around with a newer model one,
Along with the main shaft sincro hub...
Not sure it's even feesable to turn the hub around...
The gear itself is just fine, the hubs softer material so it took the brunt of the abuse of being jammed into 4wd. Still smillin so far !!!
Postby psguardian » Thu Nov 03, 2011 9:34 pm
That parts house has tyre of em. Call & tell em this one is thrashed. See if they'll swap it.
~psguardian
hot 2.6L build
psguardian
Postby bradzuzu » Thu Nov 03, 2011 9:48 pm
If it comes to that I will... I broke the dumb gear ....:(
Postby psguardian » Thu Nov 03, 2011 9:53 pm
Oh.... Nvm lol.
~psguardian
hot 2.6L build
psguardian
Postby trooper T/diesel » Thu Nov 03, 2011 11:51 pm
so there's no way to bolt it on, the auto T-case will not fit on the back of a manual trans.
what about mixing gears like we can do on the 2wd diesel tranys, to get a taller O\D
could there be a mix for a deeper LOW gear?
or are the two gears on the counter shaft made from one peace of steel, that would stop that idea....if it is....
trooper T/diesel
Have thanks: 21 times
Postby bradzuzu » Fri Nov 04, 2011 1:12 am
I found a 92 automatic trooper t case. Advised from Psguardian and Jlemon , 92-95 is the available years. The low range ratio is 2:66:1, my 2000 amigo is 2:05:1 .... If all goes well I will put all the gears into my new t case housing. Hopefully keep the sincro on the front output shaft, and r&r the lockout piece on the shift rail to gain normal shifting instead of just hi/low......and keep the servo shifter possibly hooked up still.
Postby trooper T/diesel » Fri Nov 04, 2011 1:20 am
so this works for a 88\91 MUA right :? or is it only 1992 and newer :?:
trooper T/diesel
Postby bradzuzu » Fri Nov 04, 2011 1:48 am
It would probly work on yours, but the early isuzu's have a different gear mesh coming out of the tail shaft. Just something that needs to be checked. Do you know what your low drive ratio is ??
Postby trooper T/diesel » Fri Nov 04, 2011 9:23 am
should be the 2.28-1 that's what all the charts say.
i thought the 2.6L and the 2.8L V-6 have different T-cases on the auto trans. i remember the 2.8L V-6 having a chain not gears....
so if it works it would need to be from a 2.6L auto to mach up :?: or a 92\95 auto trans model
trooper T/diesel
Postby bradzuzu » Fri Nov 04, 2011 10:32 am
If yours is a chain drive, it will be more chev or Borg Warner orientated I think. Do some research you might have any easy avenue of available parts !!!
Postby bradzuzu » Fri Nov 04, 2011 2:41 pm
This compares the new style front output shaft to the older non sincrode shaft..
As far as the shaft itself it's the same and the hub tooth count is the same lucky for me...
This compares the difference of the two gears.. I'm planning on pulling off the sincros and using the late model shaft and hub assembly.
Postby bradzuzu » Fri Nov 04, 2011 2:52 pm
I forgot to show the sincros ... This is a double setup system inner and outer. This is the same setup in the transmission, and why they last so long !!!
Postby bradzuzu » Fri Nov 04, 2011 4:02 pm
Here's another fun fact as I sigh in relief , old first gen and second gen t case output spline.
Same spline and seal , meaning if you wanted to upgrade to bigger U joints and more travel, along with the bolt removal easement , You Can !!! The front drivelines bolt up to the old flanges. So if you wanted to you could upgrade by using front flanges on a late model drive shaft, same U joints....:) I'm hoping the speedo drive gear is the same location on the shaft and size...
Postby psguardian » Sat Nov 05, 2011 1:47 pm
So whats the latest?
~psguardian
hot 2.6L build
psguardian
Return to Hall of Fame
