ARB Installed (Front Third Removal - Drop Diff Brackets)
Postby :::Matski::: » Thu Jan 29, 2009 4:32 pm
chikoroll wrote:not concerned about the void in the diff brackets there?
No, I needed it for a job quick and ran out of plate :oops:. But TBH they only bare the weight of the axle its not like it takes any shocks from the suspension. I have since welded the gap up as it was in the back of my mind, but nothing had moved after some serious off roading.
I would say its not finished till you fill it in but in truth it probably doesn't need it so long as you cut close to the top hole.
1989 2.8TDI Isuzu Bighorn Hybrid
Front Aussie Locker - Rear LSD - Petrol Diffs
2" Lift - 1" Body lift - +2" shocks - 32" KL71s
2.5" free flow stainless system - TMIC - 20psi Boost
Suckin' Diesel Baby!
:::Matski:::
Super Trooper
Postby chikoroll » Fri Jan 30, 2009 7:08 am
i was thinking more on the lines of, if you're in a crash, the crash investigation blokes would nit pick at the obvious homebrew mod, and quickly blame the crash on that- whether it was the cause or not
(similar to the bloke with the landy that rolled down a hill killing his kids recently when his homebrew swaybar disconnects broke)
good to hear you filled it in :) peace of mind and hiding the homebrew is always best
Holden Jackaroo '98 3.5L Petrol Auto (Isuzu Trooper) (Australia)
Isuzu Trooper '97 3.1 Turbo Diesel Manual (UK)
Isuzu Bighorn '94 3.1 Turbo Diesel Auto (UK)
Holden Jackaroo '98 3.0 Turbo Diesel Manual (Australia)
Holden Jackaroo '94 3.1 Turbo Diesel Manual (Australia)
my ride - viewtopic.php?t=25833
my videos
chikoroll
Postby Fisher » Fri Apr 03, 2009 1:29 am
So just to clarify for a Noob.
I am going to be doing mine during a public holiday so nothing will be open so I'll need to get all the stuff before I do it and I won't be able to go and buy anything else.
The checklist for the job (please tell me what I've missed)
2x trolley Jacks (Can I get by with just 1?)
2x Drop Brackets
Diff Oil, little pump thingo to pump the oil in
Socket/ratchet/spanner set
Bearing Puller (don't have one, do I need one?)
Axle stands
Allen Keys
Welder and Grinder for modding the X-member
Grease for hubs
Hammer
Needle nose pliers
10,000 Rags and some degreaser
Assorted v.basic tools like screwdrivers, hammers, pliers, vice grips.
What have I forgotten?
I'd have to get it done in a day (I'll be getting started at about 6am) so I need to get prepared early.
Fisher
Re: ARB Installed (Front Third Removal - Drop Diff Brackets)
Postby Trooper King » Fri Jul 29, 2011 7:11 pm
Nice job looks good
Trooper King
Has thanked: 49 times
Have thanks: 10 times
Postby recon » Sat Mar 10, 2012 2:57 pm
i will be doing diff drop and aussie locker in my truck this year.
recon
Has thanked: 109 times
Have thanks: 47 times
Postby mudoilngears » Wed Jun 12, 2013 12:10 am
For the record... I wanted to know how much the diff weighs before I pulled it. Couldn't find anything, so I pulled it and weighed it. With both brackets attached and full of oil it weighs around 105Lbs. Just so you know what you're going to be handling.
1990 Isuzu Amigo 4X4 4ZE1 engine. Front Aussie Locker, HD Sway Away T-bars,Smittybilt XRC8 winch.
Build in progress...
mudoilngears
Has thanked: 12 times
Have thanks: 64 times
Postby RedKevin47 » Wed Mar 23, 2016 1:25 am
I realize that this thread is quite old. But if anyone is still following it, I am looking for advice. I want to install a front locker on my 1986 Trooper II, turbo diesel. Is this a good example to follow?
RedKevin47
Previous
Return to Hall of Fame
