How to fix 2nd generation Rodeo driveshaft clunk
Postby Slinky » Tue Jun 19, 2007 8:07 pm
93rodeoTpS wrote:how long do u-joints typically last - the ones on this truck were replaced in '04
They should be fine, the ones on my truck are the factory ones with 195,000 miles on them and they're still fine.
93 Rodeo 3.2 auto 4x4 205,000 miles
Indy4x 3" lift, HD tie rods, SS brake lines
DOR diff drops, UB Skidders
31" BFG A/T's
91 & 02 Ford Explorer 4x4s, Both bone stock
Slinky
Postby DAstormtrooper99 » Wed Jun 20, 2007 12:55 am
yeah i figured u-joints were quite robust i think i'm leaning back towards a clutch/pressure plate/flywheel issue now...like i said nothing drastic but it does get annoying to have my head thrown forwards everytime i take my foot off the gas with the clutch engaged
96 Volkwagen Passat GLX VR6 (old boxy FAST german sedan >-D)
99 Trooper LS (Daily Driver) - Got Oil? (SOLD)
'93 Rodeo 3.2 5spd - Custom Intake, Broke Driver, DEAD due to sabotage
http://www.cardomain.com/ride/2434079
DAstormtrooper99
Drives in Mud
Postby semenza21 » Wed Apr 23, 2008 4:17 pm
Thanks!!
semenza21
Postby Cannonball » Thu Oct 23, 2008 1:42 am
When do you guys get this clank?
Cannonball
Postby Grumpfrompahrump » Thu Oct 23, 2008 12:24 pm
I got my clunking noise in my Amigo at about 60k miles. I took the write up and some Mobil One grease to a local shop that did it for me. They only charged $50.00 and it took less than an hour.
The shop showed me the Isuzu Service Bulletin on the subject that says the clunk is perfectly normal!
Steve
2000 Amigo Ironman, 3.2L Auto 4WD
1982 Cadillac Fleetwood Hearse
1927 Ford Model T Roadster w/327 Chevy
Grumpfrompahrump
Have thanks: 32 times
Postby SwedishTrooper » Mon Feb 02, 2009 10:01 pm
i know this post has been burried a bit, so i apologize for bringing it back up. my 99' trooper is having some of the symptoms that seem to be explained here.
the only time i feel a 'thud' from the rear is from a dead stop, taking my food OFF the brake. its a slight thud, but noticeable none the less.
my owners manual states that if on my information plate on the firewall, i have "G80", then it is equiped with a limited slip differencial. is this the same as a slip yolk?
i noticed the write up was for amigos/rodeos, but was wondering if this is also applicable if a trooper has the limited slip differencial.
sorry for the newbie questions. ive just gotten my first trooper about a month ago and can't stop thinking about mods and preventative maintenance that i want to do to it.
this forum is great for not only ideas, but how-to's also.
thanks for your time
mike
1999 Trooper 4x4, T.O.D.
92K miles. Update 2/11- 124K miles
SwedishTrooper
beating the dead hortse some more
Postby jallantaylor » Mon Sep 21, 2009 7:49 pm
thanks for all the great insight... I am also dealing with the clunk.
just bought a 00 passport ex 4X4 and dropped the shaft and did the grease right away - 3000 miles later it clunks again.
I am thinking about tapping for a sert - but a few things bother me about this whole thing. (1) can a one peice shaft be swapped out? (2) why does the clunk come back? (3) what physical force makes the clunk sound? - as I understand it - the slip yoke is designed to slide in and out when the suspension is moving up and down - so why does it clunk when you stop or go? (unless your shocks are junk) (4) it feels that upon stopping, a rotating mass preciptates the clunk - as in, something else stops after the vehicle stops, and same with hitting the gas. it turns (rotating mass) and clunks to engage the driving process.
I am not a mechanic, but tinker a bit for fun. this whole issue is nothing but annoying. any elaboration, alternatives, etc would be appreciated.
jallantaylor
Re: beating the dead hortse some more
Postby Neutron » Wed Apr 14, 2010 10:26 am
jallantaylor wrote:(3) what physical force makes the clunk sound? - as I understand it - the slip yoke is designed to slide in and out when the suspension is moving up and down - so why does it clunk when you stop or go? (unless your shocks are junk) (4) it feels that upon stopping, a rotating mass preciptates the clunk - as in, something else stops after the vehicle stops, and same with hitting the gas. it turns (rotating mass) and clunks to engage the driving process.
I believe the clunk is the little bit of rotation that occurs between the 2 halves of the driveshaft being amplified through the drivetrain. The grease in the spline cushions that movement, and quiets the clunk.
My rodeo has the exact same feeling you describe, making me think its a combination of dry spline and maybe some worn suspension links.
When I swap out my axle I will grease my driveshaft, and post results.
2000 Isuzu Rodeo 265/75/16 tires, brush guard, lift
1991 Isuzu Impulse RS awaiting parts for resurrection
Neutron
Super Trooper
Have thanks: 9 times
Postby tramo » Sat Jan 08, 2011 7:25 pm
Whooda thunkit......
REALLY WORKS !!!
99 Amigo - 3.2L, 4x4, Hardtop
- New fuel sender
- Manual hubs
- CD player and new speakers
- New fuel pressure regulator
- Bug deflector
- Luggage rack
- Ceramic brake pads
- Wiper relays
tramo
Drives in Mud
Re: How to fix 2nd generation Rodeo driveshaft clunk
Postby streetthumper » Sun Nov 27, 2011 12:49 am
Dont mean to bring up old threads but thanks for the info, im defiantly going to try this. I was thinking my clunk was from a bad rear end, called the junk yard and done had a whole new rear end lined up to go in but if this works im gonna save myself a couple hundred dollars! I hope this fixes it dont have the money to buy a whole new rear end. The reason i feel it was my rear end is because i dug into mine the other day and that sucker was dry as a bone no grease at all so i figured the gears had worn and were getting ready to go.
99 isuzu rodeo. 31" nexen rodain m/t tires, 3.5" lift, 2 bride low max seats in the front, k&n open air filter, more to come!
Check out my 2nd gen isuzu rodeo truck 3d project! viewtopic.php?f=12&t=58407&p=551770#p551770
streetthumper
Postby kottobahn » Sat Nov 10, 2012 11:51 am
I want to thank the person who posted this cure to the drive shaft clunk. I performed this maintenance and solved my issue. The isuzu dealer didn't even know what to do about it. Brilliant!
kottobahn
Postby radare » Sun Jan 03, 2016 10:24 pm
Fixed the images. They are now hosted on one of my long-term servers and should not go away again.
radare
Have thanks: 36 times
Postby totten » Mon Feb 15, 2016 8:11 pm
Time for me to grease the shaft also. Clunks when cold more than warm. No jerks I can see on driveshafts. I may use a injection needle to put grease in without removing shaft if I can. My two cents,Tony
2004 rodeo 4x4,3.2,auto Calmini 3" lift, Zone 2" Body Lift, 265/75/16 Bridgestone Revos. Cobra 29LTD CB,Transmission cooler,Functional hood scoop,Skyjacker shocks 8000,Swaybars removed.
totten
Have thanks: 71 times
Postby Kilroy2032 » Fri Jan 13, 2017 5:46 pm
Hi there. Could the same instructions be applied to a 1994 Trooper with an AT?
Just got mine up and finally running and noticed the clunk after letting off the brakes, too.
Kilroy2032
Has thanked: 31 times
Postby Kilroy2032 » Fri Jan 13, 2017 7:15 pm
Tad wrote:Yours is easy. It already has a grease zerk.
Tad
Thanks Tad. And it's right where there the slip yoke is then?
Kilroy2032
Previous
Return to Hall of Fame
