round headlight conversion write-up
Postby stusvend » Fri Apr 01, 2011 9:55 am
VO|TRON wrote:any ideas on why my passanger light doesnt work on high beams? bulbs are brand new and both work on low beam.
Check your wiring again. Make sure the connection where you spliced the wires together is making proper contact. Reference the other working side and make sure they match. What type of connector did you use to splice the wires?
Matt
'88 Trooper LS 2.6L- 4 cyl, 5 speed manual. - SOLD :( (Replaced by 2012 Xterra Pro-4x)
'89 Trooper RS 2.6L- 4 cyl, 5 speed manual.
'69 Toyota FJ40 Land Cruiser- 3.9L inline 6, 3 speed manual.
stusvend
Has thanked: 16 times
Have thanks: 64 times
Postby VO|TRON » Sat Apr 02, 2011 7:40 pm
I sodered(sp?) all the wires, I hope its a bad bulb cause I dont wanna have to do all that ---- over again.
For this post the author VO|TRON was thanked by:
MOZES
VO|TRON
Postby jeremy_worden » Thu May 05, 2011 2:22 pm
ok, little bit of an update. I did a HID install upgrade for my round eyes.
i cant get in to my ebay to post i link to the ones that i got, but i will edit it later, also they ran me about 40 bucks.
and installed.
the install wand the same as changing the old bulb. it took about 5 min each side. when i can i will get some night time pics posted. thanks again every one who helped my in making my post.
1995.5 isuzu rodeo LSD and snowflakes
1988 isuzu trooperII []OlllllllllllllO[] 245-75-R16, yakima load warrior basket, custom rear bumper, and an AUSSIE locker, and AISIN hubs, indy4x shackles 2" lift.
cardomain and May 2011 ROTM
Isuzu Outlaw - Bikini
For this post the author jeremy_worden was thanked by:
MOZES
jeremy_worden
Has thanked: 7 times
Have thanks: 13 times
Postby prospector1 » Sun May 08, 2011 2:23 am
I just picked up a round headlight grill and light to convert from the pick n pull. How much better is the lighting at night with the HID kit? are they way better then the stock square lights?
prospector1
Mi Amigo
Re: round headlight conversion write-up
Postby joe86 » Sun Sep 04, 2011 1:20 pm
will this conversion work on a 94 trooper as well? I like the look :)
joe86
Postby 94Rodayo4x4 » Mon Sep 05, 2011 10:24 pm
[quote="joe86"]will this conversion work on a 94 trooper as well? I like the look :)[/quote]
no, only 1st generation troopers. 84-91.
94Rodayo4x4
Has thanked: 32 times
Have thanks: 47 times
Re:
Postby Selahdoor » Mon Jan 02, 2012 12:09 am
It's a bulb. Quite like the one in your tail light. Only on steroids.
Has two filaments.
On low, one filament is lit up.
On high, both filaments are lit up.
Your high filament is burnt out on the passenger side.
-Jeff
1988 Trooper LS. 4ZE1. mua5.
Selahdoor
Forum Admin
Has thanked: 94 times
Have thanks: 165 times
Postby imamonstertruck » Mon Jul 23, 2012 5:45 pm
I am going to have to post a photo tomorrow, a few actually, but it seems this grill is not lining up like it should... anyone have problems with this?
cheers
-Ian
imamonstertruck
Has thanked: 49 times
Have thanks: 164 times
Postby IsuzuGeek » Mon Jul 23, 2012 5:55 pm
[quote="imamonstertruck"]I am going to have to post a photo tomorrow, a few actually, but it seems this grill is not lining up like it should... anyone have problems with this?
cheers
-Ian[/quote]
Lining up how? The round eye grill is pretty much a straight fit. You have to get a little creative to make sure it is held in place nicely on the outside, but everything else is more-or-less perfect.
Bart
IsuzuGeek
Have thanks: 196 times
Postby imamonstertruck » Mon Jul 23, 2012 11:14 pm
[quote="nfpgasmask"]Lining up how? The round eye grill is pretty much a straight fit. You have to get a little creative to make sure it is held in place nicely on the outside, but everything else is more-or-less perfect.
Bart[/quote]
Will post some photo's tomorrow.
cheers
-Ian
imamonstertruck
Postby imamonstertruck » Tue Jul 24, 2012 2:40 pm
here is my thread that covers my install and problem
viewtopic.php?f=1&t=63186
cheers
-Ian
imamonstertruck
Postby Swede » Tue Feb 05, 2013 6:47 pm
How are the Ebay headlights holding up? Any issues? I`m looking at a simular pair.
1987 Isuzu Trooper/Holden Jackaroo
Swede
Trail Rider
Has thanked: 21 times
Postby Swede » Sun Mar 03, 2013 2:55 pm
Image Just did mine! Love it!
Swede
Trail Rider
Postby jeremy_worden » Fri Mar 15, 2013 12:35 am
Swede wrote:How are the Ebay headlights holding up? Any issues? I`m looking at a simular pair.
nah, they are doing good. i need to take them off and clean them out, but thats it
jeremy_worden
Postby Aaronmcvay84 » Sat Aug 03, 2013 8:59 pm
I got the same headlights. Did you have a hard time getting them to fit in the lock ring? They are thinner than the stock bulb assembly.
1988 Trooper 2.6L, MUA-5. Stripped naked and sent to the trail in the sky (crusher)
1989 Trooper (known here as Blackie) 2.6L, MUA-5 speed, 2" shackle lift, rancho shocks, big brakes up front, aisin hubs etc.
"Oil. What oil? Oh no, that's not a leak its just my truck sweating from all of the rock crawling we do."
Aaronmcvay84
Trail Scout
Have thanks: 8 times
Postby KJonyx » Tue Aug 06, 2013 1:18 am
okay so, I have my round eye kit, cleaning it up at the moment but question now. I didn't want the original 7" round headlights since they are halogens. I'm looking for 2 7" lights that I can put an 8000k HID BI-xenon kit in that I have here at the house. Anyone know of a set of headlight housings that are simple and cheap? Really can't wait too put this sucker on as soon as I get it cleaned and screw tabs re-fabricated out of steel this time.
91' Trooper 4 door LS, stock power locks & power windows! 2.5" custom shackle lift, torsion bars tweaked up 1.5", blacked out rims, 31's AT mud tires, custom sound system, 2" billet spacers, 310K miles and still running strong!
KJonyx
Mi Amigo
Has thanked: 23 times
Postby Oregon RS » Sat Aug 17, 2013 12:46 am
[/quote] nah, they are doing good. i need to take them off and clean them out, but thats it [/quote]
Hey Jeremy,
I did the conversion on my (recently wrecked) RS, and am in the process of building my new-to me RS, and was thinking of upgrading to the brighter bulbs when I convert Mr. White.
Are you getting any water in those housings, or is that fine old high desert dust just finding its way in through a small gasket seam?
My main concern is the difference in rainfall between Portland Oregon and the high desert where you're located.
Mark
Totaled
Red 1989 Trooper RS
New-to-Me
White 1989 RS ( Build in Progress )
Stock Snowflakes • BFG All Terrain TA's • Aisin Hubs • 2nd Gen Rodeo Side View Mirrors • Delta 272 Cam • MagnaFlow Cat and Muffler • Yakima Bars • Home Made Cargo Basket (3/4" EMT Conduit) • and [•]||||||||[•]
Build Thread
viewtopic.php?f=1&t=71799
Oregon RS
Rodeo King
Has thanked: 24 times
Postby jeremy_worden » Sun Aug 18, 2013 12:29 pm
water, from the marker bulb hole. it just looks griddy
jeremy_worden
Postby Oregon RS » Tue Aug 20, 2013 2:57 am
Thanks Jeremy, I'll give 'em a look on line.
Totaled
Red 1989 Trooper RS
New-to-Me
Build Thread
Oregon RS
Rodeo King
Postby MOZES » Wed Apr 13, 2016 12:06 am
Okay, so question. What do you do with the marker light plugs wiring that plugged into the square headlights? Are they just not used now?
James "MOZES" Tester
1989 Trooper RS
roundy conversion
baselining in progress
MOZES
Have thanks: 5 times
Postby imamonstertruck » Wed Apr 13, 2016 12:39 am
MOZES wrote:Okay, so question. What do you do with the marker light plugs wiring that plugged into the square headlights? Are they just not used now?
Mine are set off to the side but have toyed with the thought to add a marker lamp on the fender.
Cheers
-Ian :blackeye:
1989 Trooper RS http://forum.planetisuzoo.com/viewtopic.php?f=15&t=81642&p=722882#p722882
Previous Troopers and Build Thread->http://forum.planetisuzoo.com/viewtopic.php?f=15&t=63260
imamonstertruck
Postby mustanger999 » Wed Apr 13, 2016 1:50 am
I hooked it to the led halo my lenses have.
Truth. The pill that everyone wants, but cant seem to swallow.
Planetisuzoo/Isuzu FB Groups Member map
'89 Trooper RS, 2.6 5spd, Smittybilt rear bumper Sort of build thread
'89 Trooper: 2.6 5spd, Weber 32/36, Round eye swap, 3" body lift, Sliders, Auto-Meter center cluster, Hand throttle. Build thread
SOLD '93 pickup: 2.6 mfi, 4x4, 5spd, Passport Bucket Seats, Intermittent wiper added. Build Thread: forum.planetisuzoo.com/viewtopic.php?f=15&t=72720&p=639130#p639130
mustanger999
Has thanked: 48 times
Have thanks: 79 times
Postby MOZES » Wed Apr 13, 2016 12:11 pm
Thanks guys! Placeholder for another future project then!
1989 Trooper RS
roundy conversion
MOZES
Previous
Return to Hall of Fame
