round headlight conversion write-up
Postby jeremy_worden » Thu May 20, 2010 8:12 pm
like the title says this is a wright up that i have done for the folks who are looking at doing this.
first off you need the grill, side lamps, headlights, headlight brackets, as well as the wiring connections off of the head lights, screws.
next is the tear down.
you tear down the old grill assembly
once you have that all taken apart set it all aside, dont throw any thing away.
from there you do the main light, cut the connection about 3" from the plastic
then you take the connections that you salvaged with the grill and splice them together, the color codes are the same.
black is ground, red/W yellow stripe, and red.
repeat for both sides.
next the side light is what was the hardest one.
first you have to cut the wire connections off of the lights that are on the marker lights you are replacing,
then you need to cut the end off of the new (old) marker light.
then on the marker light thats going in, you should have 4 wires 2 green/red, 1 black, 1 green/blue.
splice both the red/green. then the black is ground and the green/blue is the blinker.
then you add the connector off of the first light.
you need to take the green/red and splice to the green/red, green/blue to the green/black, and the black to black
then you can start the install. brackets then the lights.
the grill should snap into place, behind then marker lights you should have two screw holes that should let you mount to the back side.
once you have it all back together it should look like this
unless you have a grill guard then this is what it should look like.
if i forgot anything please feel free to comment, this is my first wright up.
Last edited by jeremy_worden on Mon Dec 06, 2010 3:26 am, edited 2 times in total.
1995.5 isuzu rodeo LSD and snowflakes
1988 isuzu trooperII []OlllllllllllllO[] 245-75-R16, yakima load warrior basket, custom rear bumper, and an AUSSIE locker, and AISIN hubs, indy4x shackles 2" lift.
cardomain and May 2011 ROTM
Isuzu Outlaw - Bikini
jeremy_worden
Has thanked: 7 times
Have thanks: 13 times
Postby IsuzuGeek » Thu May 20, 2010 8:31 pm
Looks good. Now I need to go look at mind and see if it has those out screw holes. I'm sure it does and I just missed it. I like the brush gaurd too. Looks cool. I saw one once at Pick & Pull but it was smashed on one side. :(
Bart
For this post the author IsuzuGeek was thanked by:
KJonyx
IsuzuGeek
Have thanks: 196 times
Postby shooter » Thu May 20, 2010 8:40 pm
Very nice write up. I just want to emphasize that the donor vehicle grille attaches differently than the 87 up grille. The 87 up grille attaches to the body with a series of clips. The 86 down grille uses screws which go through the grille into clips which are attached to the body.
The white clips on the top/front grille area, behind the yellow lens, and beneath the grille all need to be salvaged from the donor vehicle along with their associated screws.
1989 Isuzu Trooper S/ 4WD / 2.6 Litre 4 Cyl 4ZE1 Converted to Weber 32/36 Carb / 5-speed Manual (MUA5) / Warn Premium Hubs / Fancy Radio / Deluxe Intermittent Combination Wiper Switch
I'd rather laugh with the sinners than cry with the saints
Some people are like Slinkies; they are not good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
For this post the author shooter was thanked by:
KJonyx
shooter
Has thanked: 35 times
Have thanks: 150 times
Postby jeremy_worden » Thu May 20, 2010 8:45 pm
yes that is correct... sorry that i forgot to mention it... i got a set of white inserts at napa auto parts $5.00 17 count.
jeremy_worden
Postby shooter » Thu May 20, 2010 10:27 pm
jeremy_worden wrote:yes that is correct... sorry that i forgot to mention it... i got a set of white inserts at napa auto parts $5.00 17 count.
I can't recall; aren't the ones behind the yellow lenses larger than the others?
shooter
Postby jeremy_worden » Fri May 21, 2010 2:32 am
nope
jeremy_worden
Postby stusvend » Fri May 21, 2010 10:32 am
Thanks. Especially for taking so much detail in the wiring part. You confirmed what I thought I was supposed to do.
Matt
'88 Trooper LS 2.6L- 4 cyl, 5 speed manual. - SOLD :( (Replaced by 2012 Xterra Pro-4x)
'89 Trooper RS 2.6L- 4 cyl, 5 speed manual.
'69 Toyota FJ40 Land Cruiser- 3.9L inline 6, 3 speed manual.
stusvend
Has thanked: 16 times
Have thanks: 64 times
Postby Ruination » Fri May 21, 2010 12:45 pm
Can someone edit the post title to correct "write-up?" It's killing me. :lol:
1992 Isuzu Pickup w/some mods
1999 Mitsubishi Montero fully loaded
2008 Saturn Sky Redline
Ruination
Have thanks: 56 times
Postby stusvend » Fri May 21, 2010 12:49 pm
There you go. Insert as needed :wink:
Matt
stusvend
Postby jeremy_worden » Fri May 21, 2010 2:03 pm
Basejob wrote:Can someone edit the post title to correct "write-up?" It's killing me. :lol:
u marken funs at me and my book learnen....
jeremy_worden
Postby Ruination » Fri May 21, 2010 6:12 pm
I've dated a few school teachers.. so I bust everyone else's chops now.. :D
Ruination
Postby shooter » Fri May 21, 2010 8:01 pm
Sounds wright to me. I'm ah-write with it. I thank you riot good.
shooter
Postby Donner » Sat May 22, 2010 2:39 am
Very nice write-up.
I would like to add one little thing. I reccommend using shrink tube or other means to make those butt-splice connectors weather-tight. It might save you from chasing an open circuit after a couple of winters.
Butt-splices are pure evil in my neck of the woods (salted winter roads). I try to get the uninsulated kind then cover them with heat-shrink tube. :)
Donner
Have thanks: 17 times
Postby jeremy_worden » Sun May 23, 2010 2:36 am
Donner wrote:Very nice write-up.
yes... i did cover them, but forgot to mention it in the write up.... thanks
jeremy_worden
Postby Donner » Sun May 23, 2010 2:35 pm
So I guess this means I could also convert my 86 to square headlights if I can't find a round headlight grill to relapce my broken one. 8)
Or would that be blasphemy? :shock:
Donner
Postby jeremy_worden » Thu Sep 16, 2010 1:43 pm
MOVE BUMP 8)
jeremy_worden
Postby recon » Sat Jan 15, 2011 4:24 pm
:D wow excellent write up jeremy 8) recon
1995 isuzu 4x4 pickup|2.6 4cyl|5spd|3 inch body lift|2.5 inch suspension lift|33 inch treadwright wardens|indy4x hd tie rods|custom winch mount|12000 lb winch|extreme high lift jack|off road lights|front and rear aussie lockers|1.5 inch diff/crossmember drop|sway a way hd torsion bars|jeep trail rated badge|moog ball joints|moog center link|precision cv axle boots|optima battery|skyjacker steering stabilizer|tinted windows|bedliner|window rain guards|Indy4x braided brake lines|indy4x sway bar bushings|exedy daikin clutch kit|revolution 3.07 transfer case gears
Build Thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=53703&hilit=evolution+of+my+truck
recon
Has thanked: 109 times
Have thanks: 47 times
Postby 4play » Tue Jan 18, 2011 1:32 am
A great write-up!
My question is what is the main purpose/attraction from converting from square to round?
Is it looks alone? Or something more practical, like cheaper bulb or assembly replacement?
I know I need to replace the drivers side headlight assembly on my 91 troop because, at some point, the bulb was not properly replaced and the inside of the glass refuses to come clean now :evil:
'91 Trooper LS, 4x4, Auto, V-6, (4play)
'09 Ford Crown Vic (4work)
'00 Chevy 2500, XCab, LWB 4X4 (4whatever)
4play
Postby jeremy_worden » Tue Jan 18, 2011 1:35 am
the reasoning for me was the retro look of the 86 trooper. i am planing on getting a bulb conversion to a halogen bulb for better light, but mostly for the looks.
jeremy_worden
Postby VO|TRON » Thu Mar 31, 2011 2:53 pm
I am in the process of doing this right now and having my first issue. How do you mount the light buckets?
VO|TRON
Postby stusvend » Thu Mar 31, 2011 2:56 pm
VO|TRON wrote:I am in the process of doing this right now and having my first issue. How do you mount the light buckets?
They screw to the body. The holes are already there and should line right up. When you pulled the buckets, did you pull the bolts as well?
Matt
stusvend
Postby VO|TRON » Thu Mar 31, 2011 3:40 pm
nevermind i figured it out, its amazing what u can o when you think and look at the pictures. i was trying to mount the buckets to the old brackets of the square headlights. yea genuis!
VO|TRON
Postby jeremy_worden » Thu Mar 31, 2011 8:42 pm
hahaha nice, glad you got it
jeremy_worden
Postby VO|TRON » Thu Mar 31, 2011 10:56 pm
thanks for taking the time to do a wright up man, I wouldnt have been able to do it without this info.
VO|TRON
Postby VO|TRON » Fri Apr 01, 2011 12:15 am
any ideas on why my passanger light doesnt work on high beams? bulbs are brand new and both work on low beam.
VO|TRON
Return to Hall of Fame
