safety warning for you welders
Postby squatch » Fri Apr 02, 2010 10:57 pm
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 328 times
Postby Airhead rider » Fri Apr 02, 2010 11:08 pm
Wow.....I'd have never given that a thought either! Especially such a small exposure to it!
91 Trooper LS 3.1 tranplant, 5 speed
94 Trooper
91 Trooper 2.6 5-speed
Airhead rider
Have thanks: 27 times
Postby Big Bear » Fri Apr 02, 2010 11:18 pm
Read it before , but an Excellent reminder. Esp. for the DIY crowd , which I'm part of.
Dan
1990 Trooper 2.6 , 5 speed , 31" MT's
1994 Trooper LS
Big Bear
Has a Trail Truck
Postby Bob w/ a trooper » Sat Apr 03, 2010 1:01 am
Holy Bleep.
Bob
'91 2.6l manual trooper
Bob w/ a trooper
Rodeo King
Postby Madcat88/89 » Sat Apr 03, 2010 3:18 am
Gonna have to remember that.
Jim
I have opposable thumbs I WILL prevail.
88 Isuzu Trooper - http://www.cardomain.com/ride/2941780
89 Isuzu Impulse Turbo - http://www.cardomain.com/ride/2941760
Madcat88/89
Postby Smiley » Sat Apr 03, 2010 10:42 am
:shock: Yikes!
Note to self...
Grind & weld everything DRY!
Cheers!
Smiley
"I don't know what you're painting that drive shaft for... It's not like anyone's ever gonna see it" ~ Joe Berry (BigPoppa) circa 2004
"Needs more Cow Bell!" :lol:
~ 1999 Isuzu VehiCROSS..... "The VX" ~ 912s | Indy4x HD Tie Rods [>SOLD<]
~ 1998 Acura SLX................ 'The Chariot of the Goddess' ~ bone stock
~ 1998 Isuzu Amigo S......... "Bruiser" ~ MUA5 | 3"+ 3" | 912s | Nitrochargers | 33x12.50s | Lockright [>SOLD<]
~ 1998 Isuzu Rodeo S......... "Old #6" ~ 912s | Bilstein 5100s (f) / Nitrochargers (r) | 32x11.50s | 3.07s | very nicely ARB'd, Indy4x'd, and DOR'd [>SOLD<]
~ 1997 Isuzu Rodeo S......... "THUD" ~ MUA5 | 3"+ 3" | 3.07s | OME HD Leaf Springs | MWM Rock Bars | Yellow 1-pc. Drive Shaft [> SOLD <]
~ 1995 Isuzu Trooper S....... "Heart of Gold" ~ MUA5 | 912s + 1" Spacer | 3.07s | 5.38s | 35x12.50s | ARB Bumper | Snorkel | Infinite Improbability Drive
ALL OF THEM for less than the cost of one brand new SUV.............................. PRICELESS!
Smiley
Forum Admin
Has thanked: 26 times
Have thanks: 5 times
Postby Way Amigo » Sat Apr 03, 2010 1:48 pm
Off all the stuff I've done in the past without thinking about, I'm very surprised this isn't one of them. Thanks for the heads up. :shock:
93 2WD Amigo 2.3 5 speed w/AC
90 4WD Amigo 2.6, 5 speed
Way Amigo
Postby TonkaToy » Sat Apr 03, 2010 11:34 pm
That is like the perfect storm of chemical reactions. He really is lucky to be alive!
Mike M.
Richmond, VA
2007 Ford Expedition
2002 Trooper SOLD
1989 Trooper LS
Trooper wheelin video and pics:
http://www.youtube.com/watch?v=QPqIwcA14BQ
http://s621.photobucket.com/albums/tt29 ... rooper4me/
TonkaToy
Has thanked: 36 times
Have thanks: 23 times
Postby psguardian » Sun Apr 04, 2010 1:24 am
Holy Death Clouds Batman!
Can brake fluid do that with heat alone or does it need argon to mutate like that?
~psguardian
hot 2.6L build
Her Rig: '06 TrailBlazer Ext 4.0L Strait 6 (my Daily Driver till my rig is street legal)
Dae wrote:Jerry is the Chuck Norris of Isuzu's, he could build one blind folded with one arm behind his back if he had to. :lol:
PNW Zoo Facebook Group
psguardian
Have thanks: 26 times
Postby Med!c » Sun Apr 04, 2010 4:49 am
yeah man... I used to work at a pool. In the back room is where all the chems were stored. So messy.. bromine tablets.. chlorine tabelets and powder all over the floor. Someone left the the top of a hydrochloric acid bottle open. This was common with empty bottles of the stuff, as an indication for the house keepers to throw them out. Anywho, I tripped over one, all this HCL acid starts pouring out.. Just seconds. I cannot explain this! Just seconds! I flipped it back up, and as I took a normal inhalation I began suficating. I just could not breath. Everything burned. I ran out, and I started breathing the shitty indoor pool air like it was fresh air. I looked back and it was like a freaking trench war image. I had never seen actual green gas like that. Sure a few experiments here and there in Chemistry, but this was different. So I filled a bucket up with water to dilute the solution and kind of just get it to go down the drain, and I took a breath in and held it as I went in but the technique did not work well at all as fumes still went in.
And the ------ up thing is, I went inside the office on the comp to look this up as I was worried and the manager comes in yelling at me in front of everything, I tell her what happened and she didnt even care. An hour later she asked if I was alright and apologized. That day I realized I need another job and quit. But yeah.. I take these things very seriously my self. Good to know this though!
00' Trooper 4x4- V6 3.5L
5-Speed Manual Aisin AR-5
Isuzu 12-Bolt Modified LSD
Isuzu 10-Bolt Aussie Locked
BGF AT T/A KO 285/75/16
Miss my old rodeo.
Med!c
Have thanks: 86 times
brake cleaner/welding
Postby TheVetteMon » Sat Apr 17, 2010 10:15 am
Great Article! A 'flame' and anything that is coming out of a pressurized can take you out. Since seeing the NHRA 'big-guns' using brake cleaner to de-oil I use it quite often, but almost always outside. Thanks for this life saving tip!
TheVetteMon
Postby Tanman85 » Sun Apr 18, 2010 2:03 am
Look for the non-chlorinated brake cleaner, it does not contain tetracholorethylene.
-Mike
95 Trooper 3.2 SOHC Auto 220K, Spectre/DIY air intake, K&N air filter, front and rear poly sway bar bushings, Cooper Discover A/T3s LT265/75/16, Magnaflow cat, Flowmaster 50 series, 2.5" exhaust, removed factory exhaust restrictors, Superwinch hubs, fuel injectors serviced by RC Engineering, PCV catch can, SS brake lines, JET Performance ECU, Hayden electric fan, B&M trans cooler, 150 AMP Quality Power Alt, OME 919s, KYB Monomax shocks, HD Tie Rods
Tanman85
Has a Trail Truck
use
Postby TheVetteMon » Sun Apr 18, 2010 1:18 pm
Got Ya .. thanks for the reply
"Fuel-Eaters" ..
2k Rodeo LSE (bought new-wifes ride)
'99 Ford Super Duty 250 7.3 power stroke
'78 Chev short bed stepside p/u 350/400 turbo
'73 Vette (bought new)
Jet Boat
John Deere 4500
TheVetteMon
Postby lummoxmind » Mon Apr 26, 2010 2:39 am
When I was in the Boy Scouts we used to use a mix of brake cleaner, brake fluid, and pool chlorine tablets in a cast iron pan to start campfires for ceremonies. When put in the proper permutation, the old timers almost knew to the second when it would combust. It made a cool effect for the younger kids. It was definitely nasty stuff and you wouldnt want to mess around with it.
"Failure is always an option"
2002 Rodeo LS V6
lummoxmind
Trail Rider
Postby N law » Fri Sep 10, 2010 1:19 pm
Very interesting. I learned a lesson about welding after cleaning with brake cleaner. I was using flux core so I think I luckily avoided this particular problem, but I had cleaned off a part of a frame and some of the vapors from the cleaner were still lingering inside and POOF a hugh flame shot out and scared the crap out of me. I guess its good I learned that brake cleaners and welding don't mix before I got the argon/CO2 tank!
99 VX
96 Rodeo Build thread
1975 FJ40
69 Beetle
84 Westfalia
70 VW bus turned camper
86 VW Diesel Golf
07 Frontier V6 6 speed
1999 4Runner Limitee- wife's
2004 Genuine Stella Scooter
N law
Has thanked: 17 times
Have thanks: 62 times
Postby Med!c » Mon Oct 18, 2010 5:12 pm
There are alternatives that are safer. At advance auto they sell a brand called wearever. The brake fluid does decent job and isnt chlorinated. The main ingredient is heptane, CO2, isopropanolol or ethanol. I accidently took a whip of this stuff through my nose and dropped whatever I had in my hand. I did some research on it, and fortunately I'm going to be okay. I feel like if I had gotten a chlorinated brake cleaner instead, I'd be in the hospital . It was just by chance that I got this product.
Miss my old rodeo.
Med!c
Postby Ekholm1997 » Sat Apr 09, 2011 3:14 pm
WOW!!! Great post. That's one I will have to store in the memory banks.
1997 Isuzu Rodeo 4WD
3.2L 6VD1, 5-speed , 3" Suspension lift, 1" Body lift, 33X12.50-15 Dick Cepek Mud Countrys, Vision "Soft 8" 15X8 wheels, Superwinch Premium hubs, DuraSolid Mini-Spool, Flowmaster exhaust, AG flood lights, Trail Rated badges, custom painted tow hook.
Build thread http://forum.planetisuzoo.com/viewtopic.php?f=15&t=59551
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
WOW--What a Ride!
"One day, your entire life will flash before your eyes, make sure its worth watching!!"
Ekholm1997
Has thanked: 24 times
Have thanks: 40 times
Postby bzmotoninja83 » Sun Jul 24, 2011 11:35 pm
i had a can of brake cleaner, chlorinated or not, this escapes me. but antways, i was under a car, glasses on, spraying the inside of a honda motor. i figured, i got my saftey glasses and im not right under it, so im safe. well, the wind shifted slightly and, one tiny droplet, like a nano droplet hit my eyeball. i blinked and thought i was ok untill, instantaniously my eye revolted and swelled shut. ran into the house and turned the sink on, grabbed the sprayer and tried to flush my eyeball out for 15 minutes. it was swolen the rest of teh day, like rocky balboa.
saftey first, after checking thrice
02 lancer ES "Extra Slow" gettin a 02 eclipse block and evo VIII head. How's that for Frankenstein?
97 RODEO-custom light bar, 16'' snowflakes, aisin hubs, cb, and ummm
btw some one once toldd me
"CAPS LOCK IS CRUISE CONTROL FOR COOL"
" As much as I'd like to pay for your tools, I think I like my toolbox more...... It's free and I can see what's really being done"
bzmotoninja83
Rodeo King
Re: safety warning for you welders
Postby lagwagon » Fri Sep 30, 2011 11:40 am
Wow..... this post may have just saved my life
The parts store sells 2 different forms of CRC Brake Cleaner, one's a red can and the other is a green can
They were sold out of the green one (non-chlorinated) so I picked up the red.
It doesn't dry as well, but it sure does a good job on cleaning
Anyway, I was about to go out and work on welding up a bumper/hitch :shock:
'84 Chevy K5 Blazer (M1009), 6.2 Diesel
'89 Chevy Suburban, 6.2 Diesel
lagwagon
Drives in Mud
Postby Black99Amigo4WD » Mon Nov 07, 2011 4:22 pm
Phosgene gas killed thousands in WWI, I am amazed they do not make you sign a waiver like at the drug store, to buy this stuff. :shock:
Black99Amigo4WD
Trail Rider
Has thanked: 31 times
Have thanks: 6 times
Postby 94amigocamo » Mon Sep 17, 2012 10:38 pm
one word of advice if your ride has a computer "disconnect" your battery
94amigocamo
Postby Breacher » Sat Dec 15, 2012 12:19 am
scary stuff. One reason I bought a plasma cutter instead of using a cutting torch is the safety issue, now I will be looking at the carb and brake cleaner stuff as something to just not weld around.
Breacher
Postby 94amigocamo » Sat Dec 15, 2012 10:01 pm
evidendtly you are a newbie to welding.... but thanks for warning the newbies...all
flammable materials should be stored in a safe and secure area if anyone needs any tips about welding, cutting or fab.I've been at it for over 40 years.
94amigocamo
Postby yenkoz28 » Sun May 19, 2013 11:34 pm
Also you need to wear a respirator/SCBA if welding on galvanized steel and some exotic alloys too. They can do a similar thing and produce a toxic gas when welding.
1990 Trooper II
terra low tcase gears
2.6L turbo
4.77 gears
aussie lockers
Indy4x pro elite lift
big brake upgrade
32 inch tires
yenkoz28
Rodeo King
Have thanks: 10 times
Postby batvette » Mon Nov 30, 2015 2:27 pm
94amigocamo wrote:evidendtly you are a newbie to welding.... but thanks for warning the newbies...all
I think the point of the articls was that this guy had a pretty good amount of experience but using a product not intended for the job created a situation that was not expected and a danger far greater than anything he had been taught.
1995 Passport V-6 2wd 5spd.
Solar powered ventilation & sound system w/custom kickpods and 15's:
http://s353.beta.photobucket.com/user/batvette/library/passportstereo
batvette
Has thanked: 8 times
Have thanks: 16 times
Return to Hall of Fame
