AISIN Hub Rebuilding
Postby ZuCruTrooper2 » Tue Apr 08, 2008 9:03 pm
Are the o-rings and gaskets used on the Zu hubs the same as the Yota hubs? Ideally I'd like to get these on soon and it would be easier and faster if I could pick them up at the dealership...
I couldn't find any info on the internet regarding the differences.
EDIT 10/21/08:
I'm updating this post so that all information in this thread is current.
The following parts will work: (Toyota part numbers)
43532-60010 Dial o-ring
43531-60010 hub cover gasket
This WILL NOT work:
43422-60010 Flange gasket. The mounting pattern on Toyota trucks is vastly different compared to the pattern on our Isuzu trucks.
You can also go to a junkyard, find a Toyota truck, remove the 6 10mm head bolts and pull that whole cap/dial assembly and install it in your Isuzu AISIN hub body. You can also do the opposite (though highly unlikely as the Zus are far rarer than Yoda AISIN hubs).
Last edited by ZuCruTrooper2 on Wed Oct 22, 2008 12:19 am, edited 2 times in total.
91 Trooper 2.6/5 -- ATX AX198 WITH 265/75/16 BFG KO2 -- Bilstein Shocks -- Indy4x T-Bars
ASE Certified Master Automobile Technician & L1 Advanced Specialist
Certified Professional--This isn't a hobby--it's a job.
For this post the author ZuCruTrooper2 was thanked by:
steve600cc
ZuCruTrooper2
Postby onetouch » Tue Apr 08, 2008 9:32 pm
I don't know for sure but I going to guess probably not on the gasket and maybe on the o-ring.
This article http://www.off-road.com/offroad/article ... ?id=399668
doesn't address your specific question but it does indicate that the Aisin hub for the Isuzu is different from the rest of the pack as far as bolt pattern, the dial and such.
You might cruise over to the yota forums.
Maybe one of those guys knows for sure.
Jim
Red-1 89 Trooper, 2.6, 5 speed, bunch of stuff.
Red-2 91 Trooper, 2.8, 5 speed, acquiring stuff.
If you can read this thank a teacher - and if it's in English thank a soldier.
onetouch
Postby ZuCruTrooper2 » Wed Apr 09, 2008 12:47 am
Thanks Jim,
I've read that article about three times today, I'm excited to have my first set of Aisins.
I'll post over on TundraSolutions and resurrect my account there...
Now what colors am I going to paint it??? suggestions?
Also, what would cause a nice burning rubber smell from the rear right tire? Nothing catching on the exhaust.... only on that side. I did have the brakes done about 15,000 miles ago. Stuck piston/e-brake? How would I check those?
Will a bit of ATF on the o-ring make it easier to turn than if I put, say, grease on the ring?
ZuCruTrooper2
Postby Gary » Wed Apr 09, 2008 2:36 am
I think the dials are identical. I used Toyota gaskets on my Aisins. They were about half the price of gaskets from my local Isuzu dealer. I didn't change the o-rings, so I can't comment on those.
Gary
89 Trooper, 2.6, 5 spd, Aisin manual hubs. Rancho 5000's. 31" BFG ATs, 1" lift. Delta cam, LSD, 8000# Champion Winch
Gary
Has thanked: 2 times
Postby onetouch » Wed Apr 09, 2008 3:16 am
Gary wrote:I think the dials are identical. I used Toyota gaskets on my Aisins. They were about half the price of gaskets from my local Isuzu dealer. I didn't change the o-rings, so I can't comment on those.
Excellent.
That's what I love about this forum.
Someone throws out a question.
Someone else throws out a best guess.
The next guy throws out his experience in at least part of the solution.
Next thing you know some guy chimes in with the missing piece of the puzzle. :wink:
I've learned more about these ol trucks from folks on the forum than all my manuals combined.
Jim
onetouch
Postby ProBMXer1313 » Wed Apr 09, 2008 10:18 am
Excellent.
Jim
Alright alright, I used the Toyota o-rings in my Aisins, they are identical to the old ones.
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
5" Suspension Lift, Calmini Kit w/ HD Track Bar, OME 919 Coils, 2" Coil Spacers,
Custom 3" Body Lift, 33x12.5-16 Super Swamper Boggers, Sliders, Bumpers, Aisins, Optima D31M
http://www.cardomain.com/ride/601748
ProBMXer1313
Trail Rider
Postby ZuCruTrooper2 » Wed Apr 09, 2008 10:32 am
Cool, thanks for the info. This makes it much easier.
ZuCruTrooper2
Postby ZuCruTrooper2 » Wed Apr 09, 2008 10:50 pm
Some part no's in case someone needs them:
o-ring 43532-60010
flange gasket 43422-60010
hub cover gasket 43531-60010
will stop by TSM tomorrow and see if those will work
ZuCruTrooper2
Postby onetouch » Wed Apr 09, 2008 11:34 pm
Let us know what you find out.
Jim
onetouch
Postby ZuCruTrooper2 » Thu Apr 10, 2008 10:37 pm
My dealership has great prices on the gaskets (and in stock) but wants $5.10 each for the o-rings. Will see what happens with that.
Also, someone once said the Zus don't have a spring and ball bearing, but mine sure as hell does. Well, a spring at least. Will pick up two 1/8" ball bearings tomorrow. Trying to find an o-ring that fits without going to the dealership is my next goal.
ZuCruTrooper2
Postby SLipKnoTer106 » Tue Jul 15, 2008 12:30 am
Excellent.
Jim
yea really!!!!!i am buying asin hubs right now thx to you guys
1988 Trooper S 2.6L 5 speed (1995 Rodeo engine)
1989 Trooper XS 2.6L auto (dropping 2.8L in it)
1989 Trooper RS 2.6L Auto (my DD)
1989 Trooper S 2.8L 5 speed (stock)
2007 Toyota FJ Cruiser Bushwhacker fender flares, and 33"s <3
2012 Kawasaki KLR650 crash bars, and custom luggage rack and bags from Wolfman Luggage
SLipKnoTer106
Postby ZuCruTrooper2 » Tue Jul 15, 2008 2:03 am
Couple words of advice:
The base rings 43422-60010 will not work on our rigs. They are different, and much larger. Pattern is different and unusable. O-rings will work however, same with cap gaskets.
Get the right o-ring the first time, it makes the difference between a usable dial (pass. side) and needing channellocks to turn the knob (driver's side). Spend the $5.
ZuCruTrooper2
Postby shooter » Thu Jul 17, 2008 11:46 pm
I got my O-rings from http://www.trademotion.com/partlocator/ ... eid=214001
for 2.79. I ordered 21.00 worth of stuff and my shipping was 7.50. Took 2 days.
1989 Isuzu Trooper S/ 4WD / 2.6 Litre 4 Cyl 4ZE1 Converted to Weber 32/36 Carb / 5-speed Manual (MUA5) / Warn Premium Hubs / Fancy Radio / Deluxe Intermittent Combination Wiper Switch
I'd rather laugh with the sinners than cry with the saints
Some people are like Slinkies; they are not good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
shooter
Has thanked: 35 times
Have thanks: 150 times
Postby ZuCruTrooper2 » Sun Oct 05, 2008 6:18 pm
Just a quick update on interchangeability:
The entire cap assembly from a Toyota hub will work in place of the Isuzu parts. You can find a Toyota pickup at the yard, unbolt the 6 10mm head bolts, pull the cap/dial/springs/clutch etc (top part of the hub) all out as one piece and stick it on your Isuzu hub body. The opposite will work as well.
The caps are identical, the hub bodies are the problem point for interchangeability. However, the "spacer" and very bottom brass part of the Yota should work on the Zu as well, since the internal splines on the hub bodies are identical. The only differences are the outside of the hub body (Yota has a larger mounting surface, bolt holes farther apart) and the splines for the CV shaft.
Hope this helps someone out there. I picked up a nice looking set of a Yota to replace the "ugly" parts on mine.
ZuCruTrooper2
Postby justwork » Mon Oct 20, 2008 4:25 pm
Just bought a set on Ebay and will be doing something similar with mine. Thanks for all the info!
Chris
Cherry 1991 Trooper LS. Gone. 3.4L V6 conversion, 2.5" exhaust, MUA5 Transmission, Aisin hubs, stainless brake lines, Independent lift shackles, Surco basket rack, all sitting on 235/75R15 BFG AT's
justwork
Postby Ditchdoc » Wed Jan 07, 2009 7:04 am
Subscribed, I should be installing three pair in the next few months, I got the one's for my 92 and 93 Troopers, Still trying to find some 24 spline one's for my 86 Trooper.
Peter
90 Trooper Stock 93k original miles
90 Trooper LS SAS Trail Pig
85 VW Vanagon
Ditchdoc
Postby Turkey » Fri Apr 08, 2011 10:11 am
I made my own cap gaskets with sheet material from the parts store. I measured the old ones and made a drawing. Just print this file out at 100% and use it as a Template. http://home.comcast.net/~cushdavi/troop ... perhub.pdf
1988 Trooper SE, 4ZE1 engine, Auto Trans "Rosey" aka "The little Red Mule"
Turkey
Drives in Mud
Re:
Postby kperras » Mon Oct 31, 2016 2:38 pm
ZuCruTrooper2 wrote:Some part no's in case someone needs them:
o-ring 43532-60010
It seems these are Toyota part numbers. Anyone have a lead on the correct Isuzu/Aisin gaskets? I can't seem to find these anywhere.
94 Trooper LS 4x4 3.2 DOHC 5 Speed Manual - 112k miles, Daily driver.
kperras
Re: AISIN Hub Rebuilding
Postby ddomino » Mon Oct 31, 2016 6:02 pm
I've bought these ones link.Perfect fit.
1998 Isuzu Trooper
3.5L 6VE1
Manual transmission
ddomino
Postby kperras » Thu Jan 26, 2017 2:12 am
I couldn't find the gaskets so I had to trace them out myself.
FYI the steel detent ball is a 1/4" ball. Any suspension tuning shop should have these are they are a common size for detent balls. The ball+spring is also available from www.marlincrawler.com.
All finished up.
kperras
Postby SRN » Sat Jan 28, 2017 1:49 pm
I work for an AISIN dealer now and I can put together a complete "rebuild kit" for both hubs that would include:
x2 Dial O-rings
x2 Hub cover gaskets
x2 Detent kits
Cost would be $24.
I'm also checking with AISIN to see if there is an interchange for the hub to wheel gasket that I'm missing in their parts list.
If there is enough interest, I can get the parts coming in.
Stephen Nielson
stephennielson.com
SRN
Super Trooper
Have thanks: 16 times
Postby Fox » Mon Apr 10, 2017 3:38 pm
I actually need the stamped steel ring that retains the large kick out spring.
As well as the bearing that holds the center splined barrel in place.
Thats why I have had go on mine...
Fox: the official Non-Forum Troll
Have a question? Things I have first hand experience in.
'91 Amigo : fresh 2.6L 4ze1 . Hybrid rhb5 Turbo . Delta 260 camshaft . 59.5" Wide Track & Big brake front suspension . BJ flip&space . Lokka's front/rear . 31" BFG M/T Km2
I machine parts. BJ spacers, EGR plates, Alignment shims, etc.
Fox
Super Trooper
Has thanked: 8 times
Have thanks: 10 times
Return to Hall of Fame
