95.5-00 Trooper Keyless Entry Programming
Postby Tad » Fri Aug 20, 2004 5:44 pm
This is from SB98-13-L004. I believe this applies to all 98-2001 Troopers and Rodeos. This is verbatim from the TSB:
INITIAL REMOTE PROGRAMMING
This procecdure erases all exsisting transmitters codes and programs only one remote to the system. To program additional remotes, see Adding Additional Remotes. Perform these steps as quickly as possible.
Step: Operation: Confirmation
1: Close all doors
2: Open the driver's door
3: Insert key in the ignition
4: Turn key to ACCESSORY then OFF 3-times, in one-second intervals
5: Close and open the driver's door 2-times, in one second intervals. door pin switch may be toggled instead.)
6: Turn the key to ACCESSORY then OFF 5-times, in one-second intervals.
7: Close, then open the driver's door. (Door pin switch may be toggled instead.)
8: Press the lock button of the remote being programmed.
9: Press the lock button of the remote. RESPONSE: The doors will lock and unlock 1-time.
ADDING ADDITIONAL REMOTES
This procecdure is perfromed after intial remote programming. Perfrom this procedure for each remote. Perfrom these steps as quickly as possible.
1: Close all doors
5: Close and open the driver's door 2-times, in one second intervals. (door pin switch may be toggled instead.)
6: Turn the key to ACCESSORY then OFF 3-times, in one-second intervals.
7: Close, then open the driver's door 1-time. (Door pin switch may be toggled instead.)
CHECKING NUMBER OF PROGRAMMED TRANSMITTERS
This procedure indentifies how many remotes are programmed to the security system. Perform these steps are quickly as possible.
1: Close all doors
5: Close and open the driver's door 2-times, in one second intervals. (Door pin switch may be toggled instead.)
7: Close andopen the driver's door. RESPONSE: The doors will lock and unlock 1-time for each remote programmed.
TURNING CHIRP CONFIRMATION ON/OFF
This procedure is for turning the Arm/Disarm confirmation chirp ON or OFF. All steps must be followed carfully. It may take several attempts to sucessfully perform this procedure. Perform these steps as quickly as possible.
1: Close all doors
3: Insert key in the driver's door lock.
4: Turn key to lock-center-unlock (Left-center-right) 3-times, in one-second intervals
6: Turn key to lock-center-unlock (Left-center-right) 3-times, in one-second intervals
7: Close and open the driver's door. RESPONSE: The doors will lock and unlock 1-time.
95.5-97 Troopers:
Note that the "box" referred to is usually located directly under the steering wheel/dash area. It is black, about 4x4 inches, and likely fastened under or near the steering column. Get your head down by the pedals and look up to see it.
-- START --
Assuming this is the original keyless system, there is a white label on the top of the box. The label is covering over the hole. (We usually access the box by removing the small cover in the left area of the lower dash panel and using a long screwdriver.)
Push around in the middle of the label and tear the paper thru the hole. Inside there is a square yellow button.
Key on, key off, push and hold the button until you hear two tones or the horn beeps.
Release the button and momentarily press the "lock" icon on the remote. You'll hear a confirming tone or beep.
Key on and off again. Try it to see if it works.
Keep in mind nothing will arm or lock if a key is in the ignition switch while you're testing.
Tad
Site Admin
Has thanked: 121 times
Have thanks: 95 times
Postby greg5 » Tue Oct 12, 2004 7:50 pm
I GOT IT, I GOT IT, I GOT IT! Thanks so much fellas. With my 97 Rodeo I had to simply turn the key ON, press and hold the reset button on the unit until the alarm beeped twice. (the security light comes on steady then flashes twice) Make sure the driver's side door is closed (or toggle the light button) then press the remote lock button and that was it! The doors locked and unlocked with the new remote. I feel as if I accomplished a miracle. Now how do I program additional remotes?
greg5
Postby NYCoffroading » Fri Nov 05, 2004 10:22 am
ummm maybe i did somethig wrong but it just didnt work :? I followed the instruction that Tad gave us and I also look it up inthe shop manual CD (said exactly the same thing...) toward the end there was no response of lock and unlocking of door and the remote still stay un-program help? :oops:
99 Trooper S, Yokohama Geolandar H/T-S, Tokico Trekmaster R/T, K&N Drop-In
NYCoffroading
hey
Postby tb10 » Wed Feb 02, 2005 11:53 pm
it didn't work for me, but I currently have a remote...
do you have to start fresh and program both remotes?
I have a 99 Troop
tb10
Postby greg5 » Sun Feb 27, 2005 9:51 pm
I would start from fresh by resetting the unit underneath the seat. After resetting the unit, it was on from there. Just make sure all doors are closed. It worked like a charm for me. Good Luck!
greg5
Postby greg5 » Wed Mar 09, 2005 10:25 pm
I forgot to mention that I had to turn the key to "on" instead of accessory. However I aquired an additional remote and I can't get it to program. It has the same FCC number however it was used on a 1996 model, I wonder if the year has anything to with it? I have a 1997.
greg5
Postby 2000Trooper » Wed Mar 16, 2005 12:05 pm
Can someone verify that this remote: FCC HYQ1512R will work on a 2000 Trooper?
Thanks
Jaime
2000Trooper
Have thanks: 5 times
Postby 2000Trooper » Fri Mar 25, 2005 3:42 pm
FYI.
FCC HYQ1512R works with 2000 Trooper. Ordered from ebay seller and programmed with no problems.
Jaime
2000Trooper
Postby NYCoffroading » Tue Mar 29, 2005 11:23 am
HOW DO U RESET THE UNIT UNDER THE SEAT????
NYCoffroading
Postby 2000Trooper » Tue Mar 29, 2005 12:29 pm
When i did mine, i did not have to reset the unit under the seat.
Jaime
2000Trooper
Postby NYCoffroading » Wed Apr 06, 2005 3:48 pm
mine just wont respond when i try the procedure :?
NYCoffroading
success w/ '99 Rodeo
Postby tcowan » Wed Oct 19, 2005 2:57 pm
These directions worked on my Rodeo but not without some practice. The exact steps came boxed with the remote. My first 4 or 5 tries were too slow, I slept on it, and then the next day tried it faster...and by memory at that point after having gone through it so many times.
Don't open and close the door...just press the black toggle button until the dome light goes out. you can have one finger of your left hand on the toggle and your keys in the ignition with your right hand. While doing this procedure I couldn't help but imagine the engineers laughing as they created these steps.
The directions are a bit incorrect, it's not ACCESSORY to OFF, as there is no "OFF"...it actually reads "LOCK" on my truck.
Taylor
tcowan
Postby okpilot » Sat Feb 24, 2007 7:43 pm
ok, i have a 99 Trooper. ive tried the instructions to progam the remote. i am not able to get into the programming mode. i go through the cycles and the locks dont cycle. anyone have any clue???? thanks in advance
bob
okpilot
Keyless Entry
Postby bendorfold » Sat Mar 24, 2007 5:14 pm
This worked on my '96 Trooper S
Remote p/n's 2-90101-711-0 & 2-90191-701-0
FCC ID:BAB237131-013
CANADA 2024 K1431
"Use it up. Wear it out. Make it do. Or do without." War Advertising Council: May, 1944
"It is better to keep silent and be thought a fool than to speak and remove all doubt." - maxim
mine - 1989 Trooper, 2.6L, 5-spd Manual, 170,742 miles, Stock - SOLD
my son - 1992 Trooper, Auto, DOHC, 225,000 miles (362,102 km), Stock -Still Good
mine - 1996 Trooper, 5-spd Manual, SOHC, 163,849 miles, Aisin Manual Hubs - Totaled
Isuzu mechanic during 1988-1992 Model Years
bendorfold
Location: near, but not in, Philadelphia, Pennsylvania USA
Have thanks: 11 times
Postby Waylander » Wed Jul 04, 2007 8:36 pm
Does anyone know if those instructions will work on an 02 Rodeo?
Waylander
Postby shawnhwarner » Wed Mar 19, 2008 1:55 pm
sweet. worked on first try! the manual made it sound way more complicated... thankfully we have the veterans on this site.
1999 Trooper 4x4
165k
shawnhwarner
Drives in Mud
Postby ZOMGtrooper » Wed Apr 02, 2008 5:12 pm
On 95.5-97 Troopers how do you make the chirp for arming and disarming turn on or off?
'91 Trooper 2.8l SE 290+k Second owner since '99
'95 Toyota Land Cruiser 198k 3x locked
'97 Acura SLX 229k Totaled :(
'00 Isuzu Trooper S 175k 3.5L TOD For Sale
'05 Subaru Impreza WRX STi 27k
ZOMGtrooper
Postby tOnKaTrAcKeR » Sat Oct 18, 2008 8:51 pm
ZOMGtrooper wrote:On 95.5-97 Troopers how do you make the chirp for arming and disarming turn on or off?
i'd like to know this too as I would like to have my 96 Chirp
Past Isuzus:89 Amigo XS~95 Trooper S~96 Trooper SE~97 Trooper LS~97 Rodeo S~00 Rodeo S
Currently I have a 94 Rodeo S, 91 Suzuki Sidekick JLX and a 92 Daihatsu Rocky SX
tOnKaTrAcKeR
Trail Scout
Postby Pinenut » Thu Apr 02, 2009 6:25 pm
I hate the horn chirps as well. Can this be turned off? On another car you can hold the lock and alarm button for 5 seconds and it would toggle, can you do it on the Trooper somehow?
______________________________________
1998 Trooper Limited Edition
Triple Digit Mileage (168+)
OME 912 Coils + 1" Spacers
OME Nitrochargers Front and Rear
265/75 16 Mickey Thompson BAJA ATZ Tires on Incubus 511 Wheels
Flowmaster Super 44 Off Road Muffler with 2.25 Pipes and Jones Exhaust Resonator
_______________________________________
"It's a Rock, Get Over It!"
Pinenut
Super Trooper
Postby 4cfed » Sun Nov 15, 2009 8:09 pm
how do i program an aftermarket starter in my 94 troop? i bought it with the kit installed and the guy said it worked when i bought it but i cant get it to work (i changed the battery when i bought it). it says i have to turn off the factory anti-theft system? how do i go about that and would my 94 have the reset in the same place??
96' grand cherokee LMTD exhaust, CAI, 265's
90 volvo 744tic mbc(set at 15psi),straight pipe,k&n,IPD springs
99' rodeo 5spd. stock
4cfed
Postby Tad » Sun Nov 15, 2009 9:34 pm
The 94 has a different system. It never had a remote. The factory system is pretty simple and is tied into the power door locks. Unlock it with the key and it turns off the alarm. You'll need the manual for the aftermarket system in order to program it.
-Tad
Tad
Site Admin
Postby 4cfed » Sun Nov 15, 2009 9:54 pm
dammit.. i dont have the manual........
4cfed
Postby Cavmedic » Wed Jan 20, 2010 6:39 pm
i just did mine the other day worked just fine it took me a couple of times to get it right but both my remotes work now.. thanks :)
JP U.S. Army Cavalry 84-05 (Ret)
90 Isuzu Amigo Superwinch hubs 4.3 V6 5 Speed 33x12.5x15 lifted -Trail Truck
90 Isuzu Trooper 2.6 5 Speed Aisin hubs, Rear Aussie locker
99 Chevy Suburban 4x4 stock -Hunting/Tow Rig
Cavmedic
1998 Trooper Keyless Remote Programed... Sucessfully!!!
Postby Texasbudman » Thu May 13, 2010 10:27 am
Finally!!!! It only took like a hundred tries... the other link didn't seem to work... but there is a TYPO is you have to take it to ON... NOT ACC...
It took me a few tries once I figured that out...
The black box for the keyless entry on the 98 is against the engin wall just between the brake and the fuse box, but higher up... no green button that I saw... or pressed... just follow the directions, but to ON, and NOT acc...
And I did the hokey pokey... it was pretty fuckin frustrating... but a lonely moment of glory... I basically had to memorize the motions, then find this post... Oh Yeah!!!!!!!!!!!!!
Thanks and I hope this helps someone else... 8)
1998 Trooper V6 Auto 4x4 (Performance); JVC KD-S100 w/Bongiovi DPS; Kenwood-Sport Series: KFC-1662S (front) & KFC-1062S (rear)... to be continued...
Texasbudman
Postby Cali_drvr78 » Wed May 19, 2010 3:26 pm
I just bought a 99 Trooper and replaced the batteries on the remote. If I press the lock button it chirps for about 5 seconds and does nothing. If I press the unlock button it does absolutely nothing but the panic button works. I tried what the first poster says and it wont work. On the ign. switch it has "lock, off, ACC, and ON" is there another step I am missing...please help.
Cali_drvr78
Return to Hall of Fame
