2nd Gen Trooper Monster IFS Build Thread - 35's & Locker
ASIN
Postby TrooperPR » Wed Mar 04, 2009 10:57 pm
From what vehicle are the manual hubs? who sells the discos? 8)
TrooperPR
Postby lorenzo816 » Wed Mar 04, 2009 11:10 pm
Mi gente, Busque por favor.
Usted puede comprar todo que usted necesita de Independent4x.com
lorenzo816
Has thanked: 82 times
Have thanks: 55 times
Postby tbecktold » Thu Mar 05, 2009 2:10 am
Is usted too formal? Posible solamente 'necesitas'?
I've downgraded to just lusting after regular cab 4x4 Pickups.
tbecktold
Postby jcochrane » Fri Apr 17, 2009 8:36 pm
looks awsome its got me wishin
97 trooper 92.024miles 3.2l auto lockers 2in up on t bars 31s and hella fun aka po lil tink tink-76 chev k5 ricky sanders 383 "450 hp" munci 4 speed corp 14 bolt rear custom corp 14 bolt front 40x17x15 aka the beast<<<sold :(
jcochrane
Postby -Deleted- » Mon Nov 30, 2009 5:28 pm
:D wow what a great trooper.mine will be simular between now and the next 15 to 16 months 8) neo
-Deleted-
Postby mdocod » Tue Dec 15, 2009 9:58 am
wow, very interesting read and a great build.
The most interesting thing for me is seeing that it would appear that one can swap the "longer" upper control arms from later model isuzus onto the older ones. I didn't think this was possible but now that I see the pics I'm thinking that this might be my best option to get my front end to run with proper alignment and better handling. I have a 95 rodeo with the short arms (4 bolt upper ball joint). I've seen plentiful quantities of isuzus in salvage yards around here, I should be able to pull the half-shafts, lower joints, and UCA and get my front end a little wider. I think wheel spacers in the rear should work fine as well. Very cool information here.
Thank You,
Eric
95.0 rodeo, 3" lift, trooper front suspension/axles/tie-rods, 1.25" diff drop, terra-low 3:1, Warn premium manual hubs, custom rear drive-shaft, 235/85-16 Duratrack, ~240 billion miles and counting,
mdocod
Postby Cavmedic » Wed Jan 13, 2010 12:04 pm
awsome build great looking trooper :cheers:
JP U.S. Army Cavalry 84-05 (Ret)
90 Isuzu Amigo Superwinch hubs 4.3 V6 5 Speed 33x12.5x15 lifted -Trail Truck
90 Isuzu Trooper 2.6 5 Speed Aisin hubs, Rear Aussie locker
99 Chevy Suburban 4x4 stock -Hunting/Tow Rig
Cavmedic
Postby Camiel » Wed Jan 13, 2010 12:45 pm
mdocod wrote:wow, very interesting read and a great build.
Thank You,
Eric
You can't swap the control arms from the later models (3 bolt) to the older models (4 bolt) :!:
The upper control arm isn't a straight bolt over!
There are 3 IFS wides used through the years:
Trooper:
1981-1991 4 bolt upper balljoint
1991-1995 3 bolt upper balljoint (1.5" wider each side)
1995+ 3 bolt upper balljoint (1" wider than the 1991-1995 models)
Rodeo:
1991-1995 4 bolt upper balljoint
1995-1998 3 bolt upper balljoint (1.5" wider each side)
1998+ 3 bolt upper balljoint (1" wider than the 1995-1998 models, but totally different, R&P steering etc.)
The swap you saw here is the swap from the early 3 bolt model, to the later 3 bolt model Trooper.
The control arms of the 4 bolt models are less width as the 3 bolt models.
So the bolt holes on the chasis won't line up.
I can take some pics if you want :wink:
Camiel
Camiel
Has thanked: 2 times
Postby -Deleted- » Wed Feb 10, 2010 12:42 pm
here is the buildup thread on my humble trooper 8) neo
http://forum.planetisuzoo.com/viewtopic.php?t=36807
-Deleted-
Re: 2nd Gen Trooper Monster IFS Build Thread - 35's & Locker
Postby Strongway » Sat Oct 04, 2014 3:30 pm
Thanks,for the info,I just bought a 95 2 gen,,to my daugther and she was looking to build a proyect on it,,and I'm no mechanic,,so your proyect was perfect for her,,will keep you posted for further assistance
Strongway
Postby muddingrodeo » Tue Jan 13, 2015 1:23 am
That was a fine write up. I love your trooper and it gives me something to shoot for.
98 Isuzu rodeo 4x4 4" lift 32" tires all black ( mudding truck)
98 Isuzu trooper 4x4 4" lift (fixing transmission)
02 Isuzu trooper 4x4 parts car( or may fix up)
Yamaha Kodiak x 3 (the kids like mud too)
muddingrodeo
Postby totten » Mon Nov 23, 2015 10:47 pm
Great work and thanks for pictures. Tony :mrgreen:
totten
Have thanks: 83 times
Re:
Postby BigSwede » Tue Nov 24, 2015 10:26 am
Camiel wrote:
mdocod wrote:You can't swap the control arms from the later models (3 bolt) to the older models (4 bolt) :!:
Trooper:
The quoted post is 5 years old, but I thought I would correct this information.
All 92-02 Troopers use the same upper ball joint. In 95 (in USA) they went to wider upper control arms to achieve the wider track.
Lower ball joints are the opposite story. in 95 they went to a longer lower ball joint, and all 92-02 use the same lower control arm.
BigSwede
Has thanked: 15 times
Have thanks: 251 times
Postby PhilD » Tue Nov 24, 2015 6:43 pm
Regarding using the bedliner spray in the wheel wells and elsewhere: does it work better than undercoating spray? Thanks.
PhilD
Drives in Mud
Postby Bushcreature » Mon Mar 14, 2016 7:02 am
Amazing build, I have a wide track petrol Jackaroo (Aussie version of Trooper) rolling shell and was going to put a diesel in it but there is so much that needs to be swapped out I'm just going to pull the parts off and put them under a standard track Jackaroo and this post gives me some more ideas.
BC.
Bushcreature
Postby BigM35 » Fri Oct 28, 2016 5:45 pm
What size bolt / nut did you use to secure the transfercase to the front drive shaft? The part that I circled in red?
BigM35
Previous
Return to Hall of Fame
