Torsion Bar HowTo
Torsion Bar HowTo
Postby Tad » Sun Jun 13, 2004 6:55 pm
To lift the front of your IFS (independent Front Suspension) Isuzu, you will be "Cranking up" your torsion bars. Joe wrote a short set of instructions to get you on the right track. Please take a look at them.
My general rule of thumb is that 4 turns = 1 inch. This does vary. Be sure to measure as you go to ensure that the result is a level truck. Also, after lifting the truck, you will need an alignment.
The writeup is at:
http://www.planetisuzoo.com/articles.ht ... Adjustment
-Tad
Tad
Site Admin
Has thanked: 121 times
Have thanks: 95 times
Postby Vampiro » Fri Jul 16, 2004 10:24 am
i'll take these report to lift 2 more inches my trooper :twisted:
Trooper '89 2.3 RS: 4wheel Disk Brakes, r/lsd, 5" Lift, MSD, 4-1 Header + Dynomax, NX, Monster Tach, Full Sound, Mudzilla 33x13 And BF 325/60AT, Garmin, IPF 968, BJF, Diff-Drop, Sport Seats, lots more not shown...
Vampiro
Postby dq386 » Tue Nov 16, 2004 5:18 pm
does this lift the front or rear of the vehicle? I've noticed my backend is higher on one side than the other, but the frontend seems to be OK.
1991 Trooper V-6 "The Box"
dq386
Postby bigpoppax2 » Wed Nov 17, 2004 9:05 am
This is just for the front but it will affect the rear. Check your rear springs, you may have a broken spring in your leaf pack.
Good judgment comes from experience, and a lot of that comes from bad judgment.
bigpoppax2
Forum Admin
Have thanks: 14 times
Postby htioki » Sat Dec 18, 2004 2:05 am
Hi, I'm a newbie here. I'm planning to purchase a 90 pickup 2wd from a friend and would like to lift it a bit. Do the pickups have front torsion bar suspension as well? How high can I lift with just adjusting the torsion bar?
thx.
htioki
Postby bigpoppax2 » Sat Dec 18, 2004 9:42 am
It should be the same. You can get about three inches out of the front. It's a good idea to flip the ball joint from the top of the a-arm to the bottom to fix alignment issues. There is also a ball joint spacer available.
For the rear an extended shackle and add-a-leaf should get you three inches.
Joe
bigpoppax2
Forum Admin
torsion bar lift
Postby Tonto95 » Tue Feb 01, 2005 1:07 pm
How will this affect my front axles on my 4x4. I drive my truck alot and in real bad rain storms (I live in Houston - its a swamp) I will use 4 wheel high all the way to the office. I have never had a problem but am worried about what this will due to the axles. Should I consider a body lift instead?
1995 Honda Passport (Rodeo) 4x4 custom intake
Tonto95
Postby bigpoppax2 » Tue Feb 01, 2005 5:15 pm
You can do a body lift, but it will take a lot longer to install if you are going to do the install yourself. If it were me I'd do the suspension lift first and then if you wanted more do a body lift.
As far as the front cv's yes if you lift it a full three inches you will wear your cv's and cv boots more. But you can install manual hubs to where you are not turning the cv's other than when you are in 4wd.
But, yours should have the auto hubs which would do that anyway. The 98 and up Zu's have the drive flanges that keep your front axles turning all the time, 2wd or 4wd.
In your case if you use 4wd high a lot, then maybe a body lift is in order. What size tire are you trying to fit?
Joe
bigpoppax2
Forum Admin
Postby Tonto95 » Wed Feb 02, 2005 9:44 am
I am trying to fit 32 11.50 tires and am worried about the cv's. What type of life are we talking. My truck has at least five year old axles and I use 4 wheel high at least 3 to 4 times a month with zero problems. If I just have to replace them once every year or two then I am not as worried. I am worried about changing them 2, 3 or 4 times a year. That is just too much money and work.
Tonto95
Postby mcpcola » Tue Apr 05, 2005 10:38 pm
ok i have done this lift and have yet to have an alignment but my question is the front tire now lean a little at the top will the alignment be able to straighten them out
mcpcola
Postby rondi » Tue Apr 05, 2005 11:13 pm
yes......this is what an alignment does. It corrects the off camber adjustment from this /--\ to this l--l
It also will correct caster and toe.
Camber is the inward or outward tilt of the front tires as viewed from the front. Inward tilt is negative, outward tilt is positive. Camber is used to distribute load across the entire tread. Improper camber makes the tire wear on one edge, and causes the vehicle to pull to the side that has the most positive camber
Caster is the fore or aft slope of the steering axis. The steering axis is a line drawn through the upper and lower ball joints of the knuckle. Positive caster is when the bottom of the steering axis line is in front of the tire's contact patch. Zero caster is when the steering axis is at 0o. Positive (shown) caster ensures good stability, helps maintain straight-ahead direction and promotes steering wheel self-centering. Too much positive caster causes hard steering, excessive road shock and shimmy.
Toe is the side-to-side difference in distance between the front and rear of the front tires. If the distance is closer at the front, it's called toe-in. If the difference is closer at the rear, it's called toe-out.
'99 2WD Rodeo
3" Performance Accessories BodyLift, 3 1/2" Valley Spring Works Rear Coil Lift, 4" Tbar Crank
Custom Rock Sliders
Fabtech FTS9330 3-Position Performance Shocks
32x11.5 Mudstar M/T's on 15x7 Snowflakes
rondi
Postby mcpcola » Fri Apr 08, 2005 4:26 pm
My cv axles are toast so i am going to replace them but i am worried that with my 33's and the torsion bar lift it my be to much on the axles. so i am going to lower the front differential here soon to help correct the cv axle does any one with the torsion bar lift have 32's or bigger and 4x4 how has your axles held up?
mcpcola
Postby Tad » Fri Apr 08, 2005 5:08 pm
I'm running 34s now. No wheeling on them yet, but I've had 33s for a few years now on 1st and 2nd gen axles and haven't broken a CV yet.
If you are careful, you'll be fine or unlucky. The boots on the other hand are another story. 150k mile old boots that are then lifted will often tear. Replacement isn't "hard" all thing considered, but I'd rather not do that job ever again. It's messy and awkward.
-Tad
Tad
Site Admin
Postby wildcat » Sun Jul 17, 2005 6:08 am
I've been running 33's with the torsion bars cranked for about a year and a half now with no problems and I do wheel it.
Soon going to be running 35". But then I also have a Toyota doner axle if all goes wrong. :lol:
1991 Isuzu Trooper II
2.6L 4 cyl.
Champion 80000lb winch
33/12.5/15 Mickey Thompson Baja Claw
wildcat
Drives in Mud
Postby detailsbydan » Wed Jan 21, 2009 3:08 am
Hey guys, Im looking into 1998 and newer rodeo's and passports. :D I would like to run 31's with some room to flex, do the newer rodeos and passports have torsion bars up front? :? i have seen that one guy at least was running 31's with a bit of trimming on a newer passport, but he didnt mention torquing up his bars. Also, what does anyone know about the OME springs for a couple of inches of lift? ive seen a few numbers thrown out there but dont know which is which... I look forward to lots more posting here in the next month or so once i can get my new toy! Thanks for any help out there... :wink: -- Dan
detailsbydan
Re: Torsion Bar HowTo
Postby lasher242 » Sat Jun 25, 2011 10:37 pm
Tad wrote:To lift the front of your IFS (independent Front Suspension) Isuzu, you will be "Cranking up" your torsion bars. Joe wrote a short set of instructions to get you on the right track. Please take a look at them.
The writeup is at:
-Tad
Cranking up the torsion bars...Will it effect how the truck rides? Meaning is it a stiffer set up?
96 Rodeo S
Native Texan living the island life in Puerto Rico!! Man you gotta love being able to go to the beach/swim all year long..woohoo
lasher242
Postby bigpoppax2 » Sun Jun 26, 2011 8:45 am
Yes, it will ride more like a truck. It feels better to me. So long as you don't adjust them too far. The newer trucks 98 and newer, can be adjusted further than the older ones with less ill effects. This is all due to the longer a-arms on the newer models.
Joe
bigpoppax2
Forum Admin
Postby Trooper King » Sat Jul 16, 2011 8:35 am
interesting info 8)
Trooper King
Has thanked: 49 times
Have thanks: 10 times
Postby scottj » Sun Sep 04, 2011 12:32 pm
It seems the original writeup mentioned above is gone. I found a cached copy in the Wayback Machine, though:
http://web.archive.org/web/200707122253 ... es.htm/117
scottj
Super Trooper
Postby Turnturn » Wed Sep 07, 2011 6:50 am
Regarding adjusting your torsion bars to raise your vehicle.....
1) If you're doing this to raise your vehicle purely to make it look "better" or for pure ground clearance then read no further.
2) If you're doing this to improve your vehicles off road ability then here's an aspect that I haven't seen mentioned yet. I once purchased an Isuzu Mu (Amigo, in the USA) that had been jacked up in the front. While it looked good I was never happy with its performance compared to my other Mu's (I have 3). What I found was that it had been raised so far that it was actually detrimental to articulation. It had virtually no downward travel left before it hit the "extension" bump stops and was incapable of being compressed into its "compression" bump stops, thereby reducing front wheel travel from what is available from standard. I improved its articulation by lowering it a bit. I'm of the opinion that articulation is just as important, maybe more important, than ground clearance, in a lot of situations. Just my 2c worth.
Turnturn
Postby MyIsuzuIsMyLambo » Fri Jan 20, 2012 12:19 pm
How do i measure the adjustment
MyIsuzuIsMyLambo
Postby BigSwede » Fri Jan 20, 2012 12:28 pm
I just eyeball it. Try to get too precise and you'll drive yourself nuts. The exact height will vary some each time you stop depending on how the suspension settles out.
If you must measure, use a fixed reference point like the frame.
BigSwede
Has thanked: 14 times
Have thanks: 249 times
Postby psguardian » Fri Jan 27, 2012 1:13 pm
I would use drop weights (string & a fishing sinker) from matching frame points. Crank until even, drive a week & re-measure, adjust if needed.
~paguardian
psguardian
Have thanks: 26 times
Return to Hall of Fame
cron
