CO2 tank Howto
Postby Selahdoor » Sat Jan 15, 2011 4:33 am
A refigerator compressor, when set up as an air compressor, can usually do 1000 lbs or more in pressure.
Takes a while to fill a tank, but it will do the pressure...
-Jeff
1988 Trooper LS. 4ZE1. mua5.
Selahdoor
Forum Admin
Has thanked: 96 times
Have thanks: 165 times
Postby N law » Mon Jan 17, 2011 1:51 pm
I picked up a CO2 tank at an estate sale yesterday for $17.50 with a small (up to 60 psi) regulator! I don't think its been pressure tested since 92!!! They had 3 more and a Helium tank. Two of the CO2 tanks were about 5' tall.
It has Coke stickers around it; does anyone know if AirGas will exchange it without much hassel? I have another one that my buddy and I "won in a game of chance" that looks like it was last tested in Feb 2006. I'm gonna try to take them in and switch them out for minimal costs.
99 VX
96 Rodeo Build thread
1975 FJ40
69 Beetle
84 Westfalia
70 VW bus turned camper
86 VW Diesel Golf
07 Frontier V6 6 speed
1999 4Runner Limitee- wife's
2004 Genuine Stella Scooter
N law
Has thanked: 17 times
Have thanks: 63 times
Postby BigSwede » Mon Feb 14, 2011 7:53 pm
I'm putting a CO2 system together...got a 20 lb. tank because they are only a couple bucks more to fill than a 10 lb...too cheap to pay the premium for a smaller tank. Got a high flow fixed pressure regulator from, of all places, a Toyota dealer in Texas. Got a fire extinguisher bracket from Grainger. Got a good hose from Sears (not as cheap as HF but I had a gift card). Now all I gotta do is get it mounted securely...definitely don't want that tank crashing around in my rig in the event of a rollover or a traffic accident.
BigSwede
Has thanked: 16 times
Have thanks: 253 times
Postby Selahdoor » Tue Feb 15, 2011 1:50 am
BigSwede wrote:I'm putting a CO2 system together...
Pictures !!
-Jeff
Selahdoor
Forum Admin
Postby BigSwede » Tue Feb 15, 2011 4:29 pm
I have all the pieces but that's all I have so far...once I get it installed I'll try to take some pics. Snow is melting today so maybe soon...
BigSwede
Postby N law » Fri Mar 11, 2011 4:46 pm
I went to get two tanks switched out today. No questions asked at AirGas. They were awesome and it cost 12.23 per tank. I even got a pretty aluminum one.
For a regulator, I came across the HF one that has a pressure gauge and a flow gauge. Its usually 39.99 but I found coupon for $19.99. The gauge says it goes up to 315 psi...but that doesn't mean the regulator will allow even up to 150psi through it. I don't know, $20 it might be worth it to try.
If so, I'd have $35 or so in the whole thing!
http://images.harborfreight.com/hftusa/ ... ges/86.jpg
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Sun Mar 13, 2011 3:55 am
Works WAY better than I thought it would.
Went to HF and picked up the regulator for $20. Also got some quick connectors for $3. Went home to slap it all together and realized that the output for the regulator was 3/8" instead of 1/4". I ran back over to HF (2 miles maybe) and picked up a reducer fitting (#93964) for $.97. The male-male piece that came as the output had a pin hole on one end and a ~3/16 hole on the other. I drilled the small end to match the large and put the output back in with the reducer and quick connects.
It was awesome! I tore an extra engine down today while it was on the tailgate of my truck and it worked very well. I ran an impact and an air ratchet on and off for a few hours. Then I aired up a leaking tire.
Worked so well that when a buddy came over to help with the engine, he thought it was amazing. Since I had 3 20# tanks and 1 80#, I decided to give him a 20# and the coupon for the regulator.
For $21 (already had my hose and tank), you can't beat it!
Post pictures tomorrow
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Mon Mar 14, 2011 2:33 am
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Re: CO2 tank Howto
Postby BigSwede » Tue Sep 13, 2011 11:48 am
Hey Tad, I know this was 7 years ago or so, but how did you strap down your tank? I have a 20 lb tank because they are so much cheaper to fill on a per pound basis, and got a fire extinguisher mount for it, but getting the mount bolted down tight (lateral support is the biggest challenge) was difficult at best, and I am not thrilled with the result. I am trying to decide what to do, go to a smaller tank (which are a lot more expensive to fill on a per pound basis) that might be easier to secure, or go away from CO2 altogether...or come up with a better way to carry the tank. Any thoughts would be appreciated. This is for a 95 Trooper.
BigSwede
Re: CO2 tank Howto
Postby Tad » Wed Sep 14, 2011 6:44 am
I strapped mine down with short ratchet straps. With my cargo storage unit in place I only had to worry about vertical movement so it strapped to the back left corner cargo hook. Without it I had a strap that I attached to the trim under the speaker area back there with a metal backing plate. I still used the vertical strap as well. The 20lb tank is nice because it is much cheaper to fill and easier to find places that will fill it.
-Tad
Tad
Site Admin
Has thanked: 121 times
Have thanks: 95 times
Re: CO2 tank Howto
Postby BigSwede » Wed Sep 14, 2011 9:32 am
Thanks...what kind of backing plate did you use? Was it on the trim, bolted through to the structure? A pic would be swell... :)
BigSwede
Re: CO2 tank Howto
Postby Tad » Wed Sep 14, 2011 12:38 pm
I used a piece of strap, just behind the trim. Better would have been to the structure, but I did run the two screws that used to hold the cargo cover through the ratchet strap with fender washers. I don't have a pic as I sold that truck. Now I use the single ratchet strap over the top and the cargo storage unit to keep it contained.
-Tad
Tad
Site Admin
Re: CO2 tank Howto
Postby MOZES » Sun Apr 01, 2012 3:26 pm
Could those of us who havent seen this setup get a couple of pics please??
MOZES
Have thanks: 5 times
Re: CO2 tank Howto
Postby Selahdoor » Mon Apr 02, 2012 9:35 pm
Tad wrote:Here's a 5lb setup:
The cornelius regulator:
-Tad
I'd like to get an oxygen tank, and setup a regulator like that.
Maybe someday.
-Jeff
Selahdoor
Forum Admin
Re: CO2 tank Howto
Postby BigSwede » Tue Apr 03, 2012 9:29 am
This is the regulator I got, high flow fixed pressure, and relatively cheap:
http://www.trdparts4u.com/scripts/prodV ... duct=-7165
I am thinking of downsizing the tank. The 20 lb is cheaper to fill on a per pound basis, but the tank is too big to stow easily, and too tall and heavy to easily lash down securely. Now I know why 10 lb systems are more popular. Or I may go away from CO2 altogether, haven't decided really.
BigSwede
Previous
Return to Hall of Fame
