Cooper ST MAXX
What fits and What performs
Cooper ST MAXX
Postby squatch » Sun Jan 08, 2017 2:26 pm
Some pics of my new Cooper ST MAXX load range E. These are a hybrid between an AT and a MT tire. So far I like them.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 319 times
Re: Cooper ST MAXX
Postby jokeray69 » Sun Jan 08, 2017 6:08 pm
Sweet looking Tire might have to look into those
jokeray69
Re: Cooper ST MAXX
Postby reran » Wed Jan 11, 2017 12:37 pm
Mark,
Good looking tire! Also, looks good on your tow truck. I read some reviews that mentioned this tire tends to wander on the road when new. Have you found any truth to those reviews? Other than those reports, the tire seems to do well in everything else and most likely my top choice when it comes time to buy a set of tires for my 94 Trooper. Please continue to let us know your thoughts when you get some more miles on these tires. Thanks!
Leland
"As slowly as possible, as fast as necessary."
"Do what you can, with what you have, where you are." Theodore Roosevelt
89 Trooper, 2.6L Turbo, AW 30-80LE
90 Spacecab LS 4wd, 2.6, 5spd
94 Trooper SE, 3.2 DOHC
Image Image
reran
Has thanked: 8 times
Have thanks: 19 times
Re: Cooper ST MAXX
Postby squatch » Sat Jan 14, 2017 9:18 am
So far so good. The weight of the camper has increased the noise a little. But still not bad.
They are heavy!
squatch
Re: Cooper ST MAXX
Postby squatch » Mon Jan 16, 2017 10:09 am
These are E load range. I just cranked the air pressure up a bit. 50f/55r it seemed to help all way around.
squatch
Re: Cooper ST MAXX
Postby Lifelikeworm » Tue Jan 17, 2017 1:49 pm
I just installed a new set of 265/70R17 Cooper Discoverer ST MAXX tires on my 1989 Trooper. At 60 PSI I have had no issues but I am experimenting with tire pressures to see what feels the best. So far they are riding smoother than the previously installed BFG Rugged terrains.
Lifelikeworm
Has thanked: 2 times
Re: Cooper ST MAXX
Postby Lifelikeworm » Tue Jan 17, 2017 1:56 pm
here is a picture... I am interested to see how the 10 ply tire behaves when aired down off road.
Lifelikeworm
Re: Cooper ST MAXX
Postby squatch » Thu Jan 26, 2017 3:51 pm
Why on earth did you use an E load tire on a 1st gen. If it weren't for the camper it would be overkill on my pickup. C rating is plenty HD for a 1st gen. These things are HEAVY. I'll bet it bogs the life out of your 4 banger. The V8 in the truck feels the weight.
60 psi is way too much for that light truck, More like 40 is about right. Tire pressure in E rated is related to load carried. To get the right pressure I weighed my truck and emailed Cooper with the axle weights.
squatch
Re: Cooper ST MAXX
Postby Lifelikeworm » Thu Jan 26, 2017 6:06 pm
these tires are 7 lbs lighter a piece then the old one so the 4 cylinder is doing just fine. I have been experimenting with tire pressure. 45 PSI has been the sweet spot so far.
Lifelikeworm
Re: Cooper ST MAXX
Postby BigSwede » Thu Jan 26, 2017 11:14 pm
squatch wrote:Why on earth did you use an E load tire on a 1st gen. If it weren't for the camper it would be overkill on my pickup. C rating is plenty HD for a 1st gen. These things are HEAVY. I'll bet it bogs the life out of your 4 banger. The V8 in the truck feels the weight.
While I agree that C load rating is plenty, it is getting hard to find C tires any more, at least in the brands I am interested in.
BigSwede
Has thanked: 14 times
Have thanks: 246 times
Re: Cooper ST MAXX
Postby squatch » Fri Jan 27, 2017 2:55 pm
Thanks Swede, I really hadn't thought about this aspect. Historically I run flotation sizes on my trucks. They are most all C rated. I was looking for E rated for the pickup so didn't even notice. I just checked and these tires only come in C on 4 sizes. All are flotation sizes.
http://us.coopertire.com/Tires/Light-Tr ... -MAXX.aspx
I think the manufacturers are trying hard to replace most all C rated LT's with P metric car tires.
squatch
Re: Cooper ST MAXX
Postby Lifelikeworm » Sat Jan 28, 2017 1:47 pm
I bought these tires based on budget and availability. I have had all the different load ratings on both of my troopers with mostly positive results. P rated sidewalks are a little thin and I have had to do some trail side tire repairs I don't think would have been necessary otherwise.
Lifelikeworm
Re: Cooper ST MAXX
Postby squatch » Sat Jan 28, 2017 2:20 pm
Yep just replaced the P metrics on mine with these. I normally run LT C's on my Zu's. No issues. Don't trust P metrics off the street or for heavy hauling.
squatch
Return to Wheels & Tires
