Lug pattern
What fits and What performs
Lug pattern
Postby Ogresmash » Sun Dec 18, 2016 4:03 pm
Whats the lug pattern/spacing on an 01 rodeo lse?
Ogresmash
Re: Lug pattern
Postby JoeIsuzu » Sun Dec 18, 2016 9:36 pm
Ogresmash wrote:Whats the lug pattern/spacing on an 01 rodeo lse?
The entire internet seems to be in agreement that it's 6x139.7 (mm). ;)
Jack
Original owner, 1983 Isuzu P'up LS Diesel. Engine overhauled by JLEMOND. Ready for new paint now!
1994 Isuzu Amigo 2wd
IsuzuPup.com
"There are no dumb questions"?! Maybe not...
but there are smart ways to ask. Old, but classic:
How To Ask Questions The Smart Way
JoeIsuzu
Has thanked: 73 times
Have thanks: 75 times
Re: Lug pattern
Postby Ed Mc. » Sun Dec 18, 2016 10:58 pm
Yes, it's the standard old Chevy/Datsun/Toyota 6-lug x 5.5" bolt pattern used for years until the mfr's got crazy and changed the bolt center diameter.
If you're looking for replacement wheel(s), you must ensure that the center hole is at least 108mm (4.25") in diameter or it won't fit over the hubs.
Here's a pretty cool wheel cross-reference site:
http://www.roadkillcustoms.com/hot-rods ... z3JOjzx6kZ
And I stumbled up on this site which is neat 'cause it shows what years had what style of wheels, with diameter/width info:
http://www.finishlinewheels.com/ISUZU/RODEO/2001/
HTH..........ed
'90 3.4 Troop LS;
Yes, I am a Trooper-Holic!!!
Keep On Troopin' !
Ed Mc.
Have thanks: 202 times
Re: Lug pattern
Postby egagnon086 » Mon Dec 19, 2016 7:30 am
My 02 rodeo sport had 100mm openings for the hub on the OEM wheels.
egagnon086
Has thanked: 51 times
Have thanks: 87 times
Re: Lug pattern
Postby Ed Mc. » Mon Dec 19, 2016 2:52 pm
egagnon086 wrote:My 02 rodeo sport had 100mm openings for the hub on the OEM wheels.
Was that a 2WD? Otherwise they must have changed something on the later models.
'90 3.4 Troop LS;
Keep On Troopin' !
Ed Mc.
Re: Lug pattern
Postby egagnon086 » Mon Dec 19, 2016 3:26 pm
No both were 4wd
egagnon086
Re: Lug pattern
Postby geoffinbc » Thu Dec 22, 2016 3:15 am
The late modes with slip on rotors used unit bearings and did not have the big hub with drive flanges or locking hubs. They should fit most common wheels.
geoffinbc
Has thanked: 8 times
Have thanks: 321 times
Return to Wheels & Tires
