285s rubbing Trooper....cut or lift?
What fits and What performs
Postby ducktrooper1 » Mon Dec 12, 2016 12:14 pm
I recently bought new BFG AT Ko2's and they're big and wide..and they rub, unlike my previous pizza cutters. Even though I have about a 2" lift, they're still rubbing inside lower wheel wells when turned sharply. I removed the front mud flaps, and they still rub. It's been years since I raised torsion bars and I don't want to buy new shocks and springs right now....so what are my options? How much would I have to further lift torsion bars to gain about .5 to .75" of wheel clearance from the lower wheel well? Or, would I be better off cutting some of the plastic overfender and inside flaps/protection. Thanks.
99 Trooper S, 4.77s, ARBs, ARB bullbar, M8000 w/Amsteel, OME 4" lift, IFS Lights, Rancho 9000xs, Aisins, BFG KO2s 285/75/16, custom sliders, K&N/Magnaflow custom, Indy 4x SS lines, Indy 4x disconnects, DOR diff drop, Hayden cooler.
ducktrooper1
Re: 285s rubbing Trooper....cut or lift?
Postby BigSwede » Mon Dec 12, 2016 1:11 pm
You have stock wheels? Shouldn't be rubbing with 2" lift.
You can hammer down the seam at the back of the wheelwell... at least that is what I did to fit 35s.
BigSwede
Has thanked: 14 times
Have thanks: 250 times
Postby ducktrooper1 » Mon Dec 12, 2016 1:40 pm
I do have stock snowflake wheels and I think given the age of my vehicle, the lift may have settled a little lower over the years. Tires aren't rubbing much but they are touching. What kind of hammer do you suggest for hitting the seams...like a 3 lb metal hammer? Thanks.
ducktrooper1
Postby BigSwede » Mon Dec 12, 2016 2:28 pm
Okay, the snowflakes are zero offset wheels IIRC. The stock 99 Trooper wheels have more backspacing and would not be rubbing with 285/75s.
As far as hammers, yeah I use a 3 lb, but whatever works. You'll have to remove your liner to get at the standing seam, probably have to cut your liner too.
Or just live with it, and let 'em self-clearance :)
BigSwede
Postby ducktrooper1 » Mon Dec 12, 2016 5:02 pm
Well, I do have my old wheels still, so that's an option. Would another half to 3/4 " lift on the torsions do the trick in your opinion? I know I'd have to get realigned but I need it anyway.
ducktrooper1
Re: 285s rubbing Trooper....c. ut or lift?
Postby LT1coupe » Mon Dec 12, 2016 11:59 pm
It's easy & free to crank it up a little & see. I mounted 285's on stock wheels & had no rubbing even at stock height for normal driving
1995 Isuzu Trooper S Manual 33's, mild lift
LT1coupe
Postby ducktrooper1 » Tue Dec 13, 2016 6:02 pm
It must be the snowflake wheels and added width of the 285s as Big Swede says bc I had no problem with 255/85/16s' on these wheels before.
Does anyone remember what one full turn of the torsion bar bolt equals in height? I seem to recall that one turn equaled 1/4" in height.
ducktrooper1
Postby totten » Sat Dec 17, 2016 8:20 pm
You are right. 4 turns =1"inch of lift. I say add 2 " BL to Trooper. :idea:
totten
Have thanks: 81 times
Return to Wheels & Tires
Users browsing this forum: Google Adsense [Bot] and 3 guests
