Rodeo 2001 4WD
What fits and What performs
Rodeo 2001 4WD
Postby beckhydro » Wed Nov 30, 2016 11:26 am
I have 32x11.50R15/C 113R tires , I need to buy new wheels , can someone please tell me what is best size all specs or suggest wheels please? I have 3 inch lift kit installed.
Can someone confirm that these wheels will be the best fit?
AR1725884B 15" x 8" 6x139.70 20 5.29 SATIN BLACK 108 2000 lbs $98 1425002SB
beckhydro
Has thanked: 2 times
Re: Rodeo 2001 4WD
Postby gwana66 » Thu Dec 01, 2016 12:25 pm
Those wheels will fit that tire size well, probably the closest to stock offset you will find. Bolt pattern and center bore are correct. You can find them cheaper than that, though. Google the part number.
Even the hubs are manual now.
gwana66
Has thanked: 12 times
Have thanks: 198 times
Re: Rodeo 2001 4WD
Postby beckhydro » Thu Dec 01, 2016 12:31 pm
Thank you so much, Do you think I will have to MOD fender well?
beckhydro
Re: Rodeo 2001 4WD
Postby gwana66 » Thu Dec 01, 2016 5:32 pm
Probably. If the tires are really 32" in diameter or larger, they will probably rub a little on the bottom rear of the front fender while turning. Mine are 30.6", I have almost as much lift, and I can barely fit my finger between the tire and the fender flare with the wheels turned.
gwana66
Re: Rodeo 2001 4WD
Postby Rodeo814 » Wed Dec 21, 2016 7:06 pm
Whats the biggest set of BF Goodrich KOs you can run with a size 16 wheel, 3" body lift and trimming? (trimming as much needed to fit the largest tire.
2000 Rodeo 4WD 3.2 V6 (133K)
4.10 Gears factory LSD
OME 912 springs, Rancho9000XL shocks, HD torsion bars, HD lower links, Calmini Upper Control arms
BGF KO2 285/75R16
Yakima Road Warrior Rack
Rodeo814
Re: Rodeo 2001 4WD
Postby egagnon086 » Wed Dec 21, 2016 10:32 pm
If you don't care about how much you trim then likely 315/75s, or a set of 305/70s.
egagnon086
Has thanked: 53 times
Have thanks: 92 times
Re: Rodeo 2001 4WD
Postby Rodeo814 » Wed Jan 04, 2017 6:59 pm
egagnon086 wrote:If you don't care about how much you trim then likely 315/75s, or a set of 305/70s.
Thinking of running 285/75/16 BF KO2 AT.
thoughts on that?
BGF KO2 285/75R16
Rodeo814
Re: Rodeo 2001 4WD
Postby egagnon086 » Wed Jan 04, 2017 8:27 pm
You will have to trim to fit anything over a 31. But should have to worry about hitting the frame or anything like the with 285. You might need spacers or negative offset wheels for that wide a tire.
In all those sizes you will want to regear, your truck will not like it with 4.10s.
egagnon086
Return to Wheels & Tires
cron
