Snowflake correct lugs and lug nuts size?
What fits and What performs
Postby Tamar » Tue Oct 25, 2016 8:05 pm
I bought some used Snowflake 15" rims. I'm stripping off the clear coat and getting ready to have them mounted.
They did not come with the lug nuts. I have a 1989 Trooper 4 door manual with auto locking hubs. It came with the basic steel 15" rims. The trim that came with my truck has a flange around the lugs. When you put on a lug nut you first put on an aluminum spring washer, washer then lug nut.
I'm wondering do I need to change the studs? Do I need different lug nuts?
1989 Isuzu Trooper-S - 2.6 - 4 Door - 4 Wheel - 5 Speed Manual - French Vanilla with Beige Interior
Tamar
Has thanked: 4 times
Re: Snowflake correct lugs and lug nuts size?
Postby Tamar » Tue Oct 25, 2016 8:35 pm
Do you need to use the spring washer and washer on the snowflakes or just a beveled lug nut?
Tamar
Postby gruff54 » Tue Oct 25, 2016 8:49 pm
Pretty sure I used beveled lug nuts on mine. Can't remember whether the steelie lugnuts will work. Spring washer and washer not necessary. The snowflake center cap is attached with 3 machine screws from the back side of the wheel.
Mike
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54
Has thanked: 33 times
Have thanks: 56 times
Postby Ed Mc. » Wed Oct 26, 2016 2:51 am
You're gonna want a set of "mag wheel" lug nuts, as the lugs will be exposed. Snowflake wheels take a beveled lug nut.
Thread size M12-1.50, around 35mm length. Keep in mind the lug nut needs to be long enough so that the wheel stud won't bottom out on the closed end.
Here's a selection of lug nuts at Rockauto to take a look at:
http://www.rockauto.com/en/catalog/isuz ... g+nut,7676
HTH..........ed
'90 3.4 Troop LS;
Yes, I am a Trooper-Holic!!!
Keep On Troopin' !
Ed Mc.
Have thanks: 207 times
Return to Wheels & Tires
