Biggest tires for my amigo
What fits and What performs
Postby Talim » Sat Sep 24, 2016 10:17 pm
I bought a 99 amigo. What's the biggest tire i can put withoutmuch modification/lift? Thanks!
Talim
Re: Biggest tires for my amigo
Postby egagnon086 » Sun Sep 25, 2016 7:54 am
245/75-16 or a 265/70-16 depending on whether you want height or width. Regardless you will need to remove the factory front mud flaps to fit anything bigger than stock.
I have almost 6.5" of lift and 32s still scrub without trimming, if you don't mind cutting sheet metal than 33 can be had without much modification. Try to stay under 11.5" wide tires on stock rims.
egagnon086
Has thanked: 55 times
Have thanks: 98 times
Postby Talim » Sun Sep 25, 2016 4:46 pm
Thanks for the info. I am leaning towards 265/70-16. I'll keep your advice in mind. :)
Talim
Return to Wheels & Tires
