2000 Rodeo LS 4 inch suspension lift. biggest tire size?
What fits and What performs
Postby rodeooffroad4760 » Sat Sep 03, 2016 12:53 am
Need to know if I can run 33x12.5 or maybe 35x12.5 with my 4inch lift. Do I need to put 2 inches on the body? What do I need guys? Truck is also for sale for the right offer. It's flawless for a lack of a better word. It does not go off road and gets put away for winter no rust no leaks. I can send pictures to emails if interested. Thank you. Let me know about the tires.
rodeooffroad4760
Re: 2000 Rodeo LS 4 inch suspension lift. biggest tire size?
Postby egagnon086 » Sun Sep 04, 2016 7:59 am
32s without cutting, regardless of suspension or body lift. I have 2" body lift and 4" of suspension and 32s are all you can really fit without cutting the fenders. The more wheel offset you have the worse it gets from my experience.
egagnon086
Has thanked: 53 times
Have thanks: 92 times
Postby Hack » Sun Sep 04, 2016 11:04 pm
A 4" suspension lift is extreme on these trucks. Do to the extreme angles, you are going to go through CV axles unless you have a drop dif and do a ball joint flip. Moreover, with that much lift you'll be maxing out the t-bars and have very little spring left in the suspension. You are going to have a horrendous ride and feel every crack in the road.
Mario
Hack
Has thanked: 7 times
Have thanks: 128 times
Postby egagnon086 » Mon Sep 05, 2016 7:59 am
Agreed with everything Hack said. My rig is heavily modded to retain a nice ride, dif drop, HD t-bar, and calmini UCAs.
1998 Amigo S chassis/ 2002 Rodeo sport body - April 2016 ROTM -"Meego"
- "Meego" Build
-3.2 DOHC V6 5-spd 4x4
- 4.56 gear swap, Lokka front locker, Powertrax No-slip rear locker
- Calmini winch bumper w/ Custom Skid plate, Custom Rear Bumper, Custom heavy step bars, 9500# winch w/ synth. rope
-Moog CC784 coil springs, Skyjacker 7000 shocks, Calmini UCA's, JD bent link, Indy4x heavy Torsion Bars, Custom Thor bros adj. HD lower links and track bar, Removed Sway-bars F&R, s/s brakelines all around, 2" Z-O body lift
- soft-top/OEM hard top & Rally top, 265/75-16 Cooper Discos AT3 on Snowflakes.
- Cobra WX18II in-dash CB radio/ 4' Firestik Setup
- Future mods: Revo Gears
1994 Trooper S- 3.2 sohc V6 5-spd 4x4
- 94 Trooper
-poly SB bushings
- 245/75-16 Cooper Disco AT3s on Snowflakes
- Future mods: Moog CC812 springs
Gone but not forgotten:
1998 Amigo S - 3.2 dohc V6 5-spd 4x4 - sold
1993 Trooper LS - 3.2 dohc V6 auto 4x4 - sold
1988 Trooper - 2.3 L4 5-spd 4x4 - sold
1986 Trooper - 2.3 L4 5-spd 4x4- sold
1991 Trooper - 2.8 V6 5-spd 4x4 - Sold
egagnon086
Postby Ernie » Sun Oct 02, 2016 10:43 pm
Hi everyone, I have a Isuzu Rodeo 2001 LS V6 Automatic not a 4x4, just regular.
The tire size is 245/70 R16 and I want replace them with 245/75 R16, will this be an issue?
I was told that if I do this I must also replace a ship??? but they did not explian further.
Ernie
Postby egagnon086 » Mon Oct 03, 2016 7:47 am
Should work fine, you may need to remove the front mud flaps but that should be it.
egagnon086
Postby Ernie » Mon Oct 03, 2016 10:36 pm
Thank you, good night.
Ernie
Return to Wheels & Tires
