THE "Wide vs. Skinny" info post
What fits and What performs
Re: THE "Wide vs. Skinny" info post
Postby Psychomidgit » Sun Feb 17, 2013 4:39 pm
Being in AK I've found that skinny works best for me. I only run BFG TA KOs on the trucks I've had and hardly have issues on ice.
88 Isuzu Trooper II LS w/ 2.6L, Undergoing Drive/Powertrain Rebuild
91 Honda CRX Dx w/ B16A JDM Swap, Rear Disc Conversion, JDM Front End, JDM Rear Interior
13 Chevy Cruze LT RS w/ 1.4L Turbo, Trifecta Tuned w/ Forge BOV, All amber lights changed to white, shifter swapped and interior done with green accents, all silver interior pieces repainted in a Mercedes metallic silver.
88 LS Build Thread
viewtopic.php?f=15&t=68173
Look at this before "converting" to HIDs
http://www.danielsternlighting.com/tech ... d/HID.html
Psychomidgit
Trail Scout
Has thanked: 15 times
Have thanks: 6 times
Postby Storz » Fri Jun 14, 2013 7:36 am
I'm a big fan of pizza cutters
2000 Rodeo 3.5L MUA5
Storz
Trail Rider
Have thanks: 9 times
Postby break19 » Mon Nov 04, 2013 8:38 am
What I -like- is the wider tire. Plus, the last time we have -any- snow was about 3 years ago. It must've snowed for 6 hours. No accumulation. None. Ground was too warm.
With that being said, I run 255/70/R15s on my "Suzy" and I like the way they look. Yea.. 15" wheels. 9.5" wide rims. The wheels were on it, when I got it, but it was running 235/55/R15s then. Much lower stance that I liked, so I went to a tire shop, and had them match the O.D. of the original spare as closely as they could.
Yes, apparently, my '95.5 came with 15" wheels.
Mud Dawg. 1995.5 Rodeo 3.2 V6, auto, 4x2, +200k miles.
Hers: 2006 Buick Lucerne CXS, 3.8 V6, auto
break19
Drives in Mud
Postby NE_farmhand » Tue Apr 15, 2014 12:13 am
I've been mulling this over in my head. If I could find the proper rims I could swap the Amigo over to 238/85-16s to match the Dodge (at least on tire size) and hopefully get a little better fuel mileage, but the 31X10.50's work so well, I hate to take the chance of losing the mud and snow capability.
I like the BFG AT-T/A's on it. Probably put them on the Dodge too.
NE_farmhand
Postby gb89amigo » Tue Apr 15, 2014 8:59 pm
NE,
You could find some 16" snowflakes w/o too much difficulty and mount some 31X10.50X16 on them! Same lightweight type of wheel, tire diameter would be the same so would not negatively alter gas mileage. The center caps are the same for 15" vs 16".
Cheers,
GB
'89 Amigo XS RWD, 4ZE1, MUA5, HC6 (Rear Wheel Drive, 2.6L Fuel Injected, 5 spd trans f/ 2.6L and up, 4.56:1 differential 2WD/4WD)
Future: Install the "Big Brake" upgrade, so I don't break things! . Acquired '95 V6 Passport/Rodeo front rotors (11.04") and assemblies. Need to pull G80/LSD rear from '92-'97 Trooper.
'90 Amigo 4WD, Parts car
More FUN!!! :)
gb89amigo
Has thanked: 49 times
Have thanks: 116 times
Postby Ripah28 » Wed Apr 16, 2014 9:11 pm
My two bits-skinny always wins
96 trooper
4" susp lift
285 guard dogs
HD tie rods
..................NO ROAD NO PROBLEM
Ripah28
Trail Scout
Postby NE_farmhand » Wed Apr 16, 2014 10:36 pm
Snowflakes???- OK, never mind, I found another post about them, that's what's on mine.
The 235/85r16's are a touch taller than the 31x10.50's.
And I've already got 2 new 31's on it.
I need to find how to change my info on here.
NE_farmhand
Postby COYOTE102076 » Fri Jul 18, 2014 9:42 pm
I still think 1) SOMEONE else needs to make a 31x10.50 besides BFG, (Hint hint Goodyear DURATRAC!!! ) and 2) I so wish they would make a 35X10.50 Radial tire! LOL
-==Kevin J.
1994 Trooper "The Phoenix": given to my 16 year old son
My Rides: 1) 2005 Volvo XC90 Turbo 2) 2004 Mercedes Benz S500 3) 1988 Jeep Comanche Pickup
COYOTE102076
Has thanked: 75 times
Have thanks: 35 times
Postby paulevans76 » Sun Jul 20, 2014 2:40 am
COYOTE102076 wrote:I still think 1) SOMEONE else needs to make a 31x10.50 besides BFG, (Hint hint Goodyear DURATRAC!!! ) and 2) I so wish they would make a 35X10.50 Radial tire! LOL
Interco Super Swamper SSR - 35x10.50 ;)
And pretty much every A/T comes in a 31x10.50 :drunken: including the duratrac. Maybe you meant 33?
Has thanked: 74 times
Have thanks: 81 times
Postby -88- » Sun Jul 20, 2014 4:09 am
I bet he still meant the 35x10.50.....a size i too would love, and very aware of the swamper.....we wish someone else made a 35x10.5 that didn't cost an arm a leg and a testicle.
Have thanks: 103 times
Postby paulevans76 » Sun Jul 20, 2014 2:56 pm
-88- wrote:I bet he still meant the 35x10.50.....a size i too would love, and very aware of the swamper.....we wish someone else made a 35x10.5 that didn't cost an arm a leg and a testicle.
Everything costs about that much these days. My brother had a set of those swampers on his trooper - we just got lucky and found someone selling a set used in good shape for a fair price.
If y'all really want one, you should ask the tire companies if they will make one. I'm sure there are lots of dudes in other makes and models who would like a bigger radial pizza cutter option.
You can also always go for the michelin xl's and xzl or xml or whatever they are in a 36x9/16 or 38x11/16, but those are big, heavy --- military tires.
Postby -88- » Mon Jul 21, 2014 12:26 am
Meh so-so. I mean swamper while a great tire is already a very proud company and they have the 35 & skinny on lock as pretty much the only source.....but compare a more common 35x12 or something....swamper can be beat handily on price 100-150 less a tire, and still a very comparable tire. Not even big sizes...my 265/70/r17's an odd size, but not extinct...nor all that big. I went kelly tsr safari, the ssr would've been close to another 100bux each tire....& at that point for what? Just the name I've loved the tsrs so far, the need some more snow/ice testing but this is tx.....but chocolate pudding mud up to the rockers and able to work her out. Thin soupy mud just digs down to traction, thick clay like mud where your just kinda on vasoline over hard soil she's slipped, but Nothing beyond expectations & still god. Hard rock, loose rock, slick rock, pavement all good. I suspect they'll wear far better then the ssrs on pavement too......i mean only complaint they could self clean a little quicker/better from the thicker/stickier muds. I gotta get a good spin on'em to really clean them out....
don't get me wrong a name means a lot, & i do respect the hell out of most companies with a heritage, but it's gotten absurd how much they think their name is worth. John deere, harley, interco, case (knives)....i mean I love & respect most of them....but 10-50% more then a comparable company/product for just the name?
tangent sorry....back on topic. Your right we're not the only guys out here that would love something in a 35x10.5....Toyatos, nissans, explorers, tons of vehicles would do well.....but all together we're MAYBE 10% of the market....the companies know where out here, but it would seem not worth their time. I still intend to ask around when I get closer, also pondering importing, in the lands of these trucks these sizes are plentiful...military tires are an option, but as you said weight will be a major concern....atleast my current tire needs (2.6) but my next need (3.2) they may be more viable..... and finally it costs an odd wheel size again but 315/70/r17's depending on manufacturer, actual factual measurements tend to be 34.5-35.5 tall, tread widths usually 10-11.5 inches wide, and section widths 11-12.5 inches wide....all manufacturer pending again, but probably the best/closest/most optional rte for getting a 35x11ish tire....
Postby paulevans76 » Mon Jul 21, 2014 5:26 am
Specialty tires will typically always bring a premium. I'm sure Interco charges a lot for certain sizes because they make less of them, and in order to cover their costs and make a profit, they have to charge more for the tires themselves. BFG and Goodyear cost more because they have a reputation for high quality, but they are sometimes cheaper in certain sizes because they move a huge volume. Name is part of it though, sure.
Pitbull tires started because off road enthusiasts wanted another option. They might be open to a pizza cutter size in their lineup.
I just remembered that Mickey Thompson used to carry a 34x11.50 and a 35x11.50 in the baja belted tire. I always wanted a set of thosein the 34x11.50 for one of my old IFS troopers, but they are discontinued now. You'd have to find some old stock, and they'd probably be older than 5 years past their DOT date by now. Desert rat has ONE of the old 35's, and everything else on the net looks kinda scammy.
Postby paulevans76 » Mon Jul 21, 2014 10:00 am
PS - just happened to glance at the Intero cosmetic blems page (http://www.intercotire.com/news-article.php?article=1) and saw this:
Description: XSSR-40R SSR
Quantity Available:5
Price: $255.00
Still pricey, but about $100 cheaper per tire than from 4wheel parts.
Postby Ripah28 » Mon Jul 21, 2014 5:01 pm
35. 10.5 r16 all the way!!!
96 trooper
4" susp lift
285 guard dogs
HD tie rods
Ripah28
Trail Scout
Postby COYOTE102076 » Tue Jul 29, 2014 11:22 am
paulevans76 wrote:And pretty much every A/T comes in a 31x10.50 :drunken: including the duratrac. Maybe you meant 33?
DOUHHHH!!!!!!!!! :oops:
YEP!!! I MEANT 33X10.50
-==Kevin J.
COYOTE102076
Postby muddingrodeo » Wed Jan 14, 2015 12:29 pm
I'm pro fat. I would think that would get you better traction and you could run less psi in your tire.
98 Isuzu rodeo 4x4 4" lift 32" tires all black ( mudding truck)
98 Isuzu trooper 4x4 4" lift (fixing transmission)
02 Isuzu trooper 4x4 parts car( or may fix up)
Yamaha Kodiak x 3 (the kids like mud too)
muddingrodeo
Postby Psychomidgit » Thu Apr 02, 2015 3:03 am
Depends, the wider tires distribute weight more which reduces traction, depending on the surface you're driving on. It's not always best to add surface area to your tire's footprint. A lot of guys up here from down south find this out the hard way because they think "the bigger the better" and end up sliding off the road and into a ditch on the side of the highway.
88 LS Build Thread
Psychomidgit
Trail Scout
Postby IsuzuGeek » Thu Apr 02, 2015 11:53 am
Unless you are doing deep mud or snow, skinny 100%.
Bart
IsuzuGeek
Have thanks: 197 times
Postby paulevans76 » Thu Apr 02, 2015 4:40 pm
I'd rather have more surface area for crawlin, but something nice and skinny to dig in on slick hill climbs. 12.50 is a good middle ground width for 33+ tall tires, IMO. I'd love a few sets to play with depending on where I'm going. A q78/16 (35.5x11) or something like that for muddy trails and climbs, and a big fat 36-38 x 14.50 for rocks.
Postby spike » Wed Feb 08, 2017 5:29 pm
There is a recent trend in cycling to go with wider tires due to their reduced rolling resistance. This seems counter-intuitive, but the contact patches [and science-y tests] prove it.
I wonder if the same principles apply to our vehicle tires?
As for me, I prefer the aesthetic of skinnies, but prefer the air-down-ability, terrain-wrap, floatation, rim protection of a slightly wider aspect ratio tire.
spike
Postby H22hybridcivic » Fri Mar 10, 2017 9:14 pm
Well my other ride is a 92 Honda Civic VX. It had 4.5 inch wide tires on it from the factory and we called those "pizza cutters " too. Or u can run the budget skinnies at the drag strip. ( the doughnut spare tires)
1991 Isuzu PU 2.3L carb, 5spd mostly stock, Nissan rims and bigger tires 200k+miles--Sold
1998 Isuzu Trooper, 3.5L(only 1qt/tank!!!), 4L30E, custom 3/16" skid plates, OME rear springs & T-bar crank. home made roof bars, led flood lights on roof front and rear, added several power outlets, boxes in the rear for camping fold into a bed, and fits my Indel TB31a fridge
1992 Honda Civic HB, b16, teg suspension,
2011 Kia Sorento-EX 2.4L auto 6spd, the wifes car. F'N pass door handle wont open from the outside, and its a pita to take it out!
H22hybridcivic
Has thanked: 2 times
Postby H22hybridcivic » Fri Mar 10, 2017 9:17 pm
Sooo with fat tires I can haul fat chicks ??? J/k
H22hybridcivic
Postby gb89amigo » Sat Mar 11, 2017 10:43 pm
H22hybridcivic wrote:Sooo with fat tires I can haul fat chicks ??? J/k
Well, usually "fat chicks" are still very fluffy and relatively light as in less than a pound. Any other type of "fat chicks" could jog alongside, vastly and eventually improving their overall health, vigor, and longevity! Even with skinny tires, they still would be rated to not only support the vehicle attached to, but the rated passenger weight, unless of course, the very, very morbidly obese. HTH
H22, you were kidding, right? If not, I'm looking for bigger eggs!
Cheers,
GB
More FUN!!! :)
gb89amigo
Postby alabamaoverland » Wed Apr 05, 2017 8:20 pm
I like the tall, skinny look. I think I am going to go with 235/85r16's when I get new tires. First post!
alabamaoverland
Has thanked: 7 times
Previous
Return to Wheels & Tires
