THE "Wide vs. Skinny" info post
What fits and What performs
Re: THE "Wide vs. Skinny" info post
Postby alabamaoverland » Thu May 04, 2017 3:19 pm
I cannot decide on 235/85r16's 10 ply or 265'75r16's 4 ply. Both cost about the same for the Falken Wildpeak at3w, but the 265's weight 3.1 lbs/tire less. Would the weight benefit outweigh the rolling resistance for gas mileage and ride?
Is the off road traction significantly better with the 235's in North Alabama? Dirt trails, rocks, and some mud?
2000 Green Isuzu Trooper 4x4
alabamaoverland
Has thanked: 8 times
Postby paulevans76 » Thu May 04, 2017 4:44 pm
I can't imagine it would be a significant difference either way. If the 265's are a lighter load range, they would probably ride a bit nicer vs the stiffer 235's. May or may not a hindrance off road. How wide are your wheels? Are you going to be carrying a ton of gear?
Has thanked: 92 times
Have thanks: 87 times
Previous
Return to Wheels & Tires
Users browsing this forum: Bing [Bot] and 1 guest
cron
