LT 245/75R16 Firestone Destination A/Ts *pics added!!*
What fits and What performs
Postby Dae » Wed Feb 18, 2009 10:17 pm
Sorry, not much time to search cause I need to get these ASAP, due to wheel problems.
Anyways... Im going to be getting my OEM Isuzu wheels back because new wheels are too expensive locally, and I cant wait for it to be shipped.
What size Revo's will fit on the stock 16x7 wheel?
What size should I get?
I want to do none to minimal trimming. Will 265/75 R16's work?
Thanks in advance.
Dae
Has thanked: 2 times
Have thanks: 27 times
Postby reran » Wed Feb 18, 2009 10:36 pm
Yep, 265/75x16 will work.
"As slowly as possible, as fast as necessary."
"Do what you can, with what you have, where you are." Theodore Roosevelt
89 Trooper, 2.6L Turbo, AW 30-80LE
90 Spacecab LS 4wd, 2.6, 5spd
94 Trooper SE, 3.2 DOHC
Image Image
reran
Has thanked: 8 times
Have thanks: 19 times
Postby Smiley » Wed Feb 18, 2009 11:16 pm
reran wrote:Yep, 265/75x16 will work.
...but might require some fender trimming.
The fender openings are pretty snug on 2nd Gen Rodeos.
Cheers!
Smiley
"I don't know what you're painting that drive shaft for... It's not like anyone's ever gonna see it" ~ Joe Berry (BigPoppa) circa 2004
"Needs more Cow Bell!" :lol:
~ 1999 Isuzu VehiCROSS..... "The VX" ~ 912s | Indy4x HD Tie Rods [>SOLD<]
~ 1998 Acura SLX................ "d`Bus" ~ bone stock
~ 1998 Isuzu Amigo S......... "Bruiser" ~ MUA5 | 3"+ 3" | 912s | Nitrochargers | 33x12.50s | Lockright [>SOLD<]
~ 1998 Isuzu Rodeo S......... "Old #6" ~ 912s | Bilstein 5100s (f) / Nitrochargers (r) | 32x11.50s | 3.07s | very nicely ARB'd, Indy4x'd, and DOR'd [>SOLD<]
~ 1997 Isuzu Rodeo S......... "THUD" ~ MUA5 | 3"+ 3" | 3.07s | OME HD Leaf Springs [>SOLD<] | MWM Rock Bars | Yellow 1-pc. Drive Shaft
~ 1995 Isuzu Trooper S....... "Heart of Gold" ~ MUA5 | 912s + 1" Spacer | 3.07s | 5.38s | 35x12.50s | ARB Bumper | Snorkel | Infinite Improbability Drive
ALL OF THEM for less than the cost of one brand new SUV.............................. PRICELESS!
Smiley
Forum Admin
Has thanked: 26 times
Postby Dae » Wed Feb 18, 2009 11:27 pm
Thanks guys.
So if my "friend" wanted to go with the next tire size down from 265/75 R16, because he doesnt want to trim. What size would that be?
Dae
Postby Gizmo42 » Thu Feb 19, 2009 1:55 am
With stock wheels probably the only trimming needed would be the seam inside behind the plastic insert. Then just use a heat gun to soften and reshape the plastic. I know 30's fit (245/70-16) I think 31's might be a bit tight but may work ok on stock rims without trimming. Might have to lose the front mud guards though.
--Dave
Gizmo42
Have thanks: 132 times
Postby Dae » Thu Feb 19, 2009 3:24 am
Thanks guys. Im pretty sure I figured it out.
Dae
Postby Ramblin Fever » Thu Feb 19, 2009 3:25 am
Stick to the 265/75 R16's....BUT get the LT - C ply load rating if you can.
The P265's are too soft for off-road, but doable if those are your only option.
I love my Revo's....I have the 32" c-ply's
Post pics when you get em....the 265 width will fit just fine.
If you're not comfortable with the 265/75's then get the 265/70's rather then the 245's
'97 Rodeo 3.2L V6
KC Fogs; Brushguard;
Yakima loadwarrior;
Maxlife/K&N
197k strong
Ramblin Fever
Have thanks: 59 times
Postby Dae » Thu Feb 19, 2009 4:00 am
I will post pics for sure. If I end up having to order them. It may take a week or two to come in.
I am still going to still get my stock wheels back, even though the tires suck.
I do not want my wheels to continue rubbing on my upper ball joint.
Dae
Postby Ramblin Fever » Thu Feb 19, 2009 4:04 am
What size are you going with?
'97 Rodeo 3.2L V6
Yakima loadwarrior;
Maxlife/K&N
197k strong
Ramblin Fever
Postby Dae » Thu Feb 19, 2009 4:14 am
265/70's :oops: . I dont have the right equipment to do trimming, even minor ones, so I will just settle.
Dae
Postby Ramblin Fever » Thu Feb 19, 2009 4:23 am
It's alright.....nothing wrong with that size. Should fit without any need for trimming and will fill out your wheel well quite nicely.
You can safely run that size at 38-42psi with GREAT results.
'97 Rodeo 3.2L V6
Yakima loadwarrior;
Maxlife/K&N
197k strong
Ramblin Fever
Postby Dae » Thu Feb 19, 2009 4:35 am
Thanks for the info. I really appreciate it. I will update when the time comes.
Dae
Postby nig » Thu Feb 19, 2009 6:23 am
Different sort of truck I know - but I am running 265/70 Bridgstones on 16x7 rims and they work great. they are pretty close to exatly the same diameter and width as my 31" Buckshots on 15" rims - so if you can run 31x10.5x15 then the 265x70r16 size will fit with no problems
2009 D-Max 4x4 dual cab tray top ute - 4JJ1-TC 3 litre intercooled turbo diesel
nig
Postby Dae » Sat Feb 21, 2009 11:36 pm
Looks like this wont be happening anytime soon :cry:
I just got my stocker wheels back from my uncle. And just my luck.
BAND NEW tires 245/70 R16, about a month old on it.
So its good and bad news, cause I wanted to up them soo bad.
At least my wheel rubbing problem is fixed :D (freaking Nissan wheels)
Alignment here I come. $69.99.
At least I know what im going to end up getting when I wear these down.
I will make sure of that :wink:
Dae
Postby Ramblin Fever » Sun Feb 22, 2009 12:54 am
Replace them anyway and sale the ones on the wheels.
'97 Rodeo 3.2L V6
Yakima loadwarrior;
Maxlife/K&N
197k strong
Ramblin Fever
Postby Dae » Sun Feb 22, 2009 1:12 am
Ramblin Fever wrote:Replace them anyway and sale the ones on the wheels.
Thats just it. Who would buy these? Lol. The population around here is like 180,000.
I REALLY want them soo bad. No one has it locally so id have to get it from tirerack.
That would take about 4-5 weeks to get here. And im planning on leaving in late May or June to WA, with the truck.
So I may just get them when im out there.
Cause I know I will need new wheels, when I get the new paint job.
Dae
Postby Dae » Mon Apr 19, 2010 1:49 am
So since my truck is finally out here in the states. I now can get "any" tire that I want easily. But since im no longer employed because I am going to be a full-time college student my funds are kinda on the low.
I made my mind up and want to get the Bridgestone Revo 2's. Bridgestone has a $100 check card for you if you buy 4 new tires. Now i cant make my mind up on the size. Main concern is MPG's, since I dont want to be paying alot more on gas than I really have to.
245/70's (stock)
same MPG's and no calculation adjustments. but it will look weird to me cause it doesnt fill my wheel wells right since the small lift.
265/70's
slightly bigger than stock. not sure how much MPG loss (shouldnt be too much).
265/75's
alot bigger than stock. a little more strain on the drivetrain. and requires trimming. not sure how much MPG loss.
So I want to go with the 265/75 tires, if it means I wont sacrifice drivetrain performance and too much MPG's. Any input would be great. :D
Dae
Postby Oyaji_Jon » Mon Apr 19, 2010 2:59 am
I had the same exact truck as you (color and all), and the first thing I did after driving it off the dealer lot was go to Firestone and buy the Revo 2's in 265/70/16. I had them installed on the factory steel wheels and never regretted that decision. I put MANY miles on those tires in wet/dry/snow conditions and absolutely loved them. The guys at my Firestone were cool. They took my brand new (off brand) dealer installed tires off, made a phone call to another dealer, pre-sold my tires for $100 and gave me the credit on my Revos. I think my store was an exception instead of the rule, but maybe you can try to talk to them and see what they'll do. Good luck.
-Jon
Oyaji_Jon
1990 Trooper
Oyaji_Jon
Trail Rider
Postby Dae » Mon Apr 19, 2010 4:11 am
Thats awesome! Were there any issues with rubbing? Any trimming required? Im just gna score them at the discount tire a few blocks away from me.
Dae
Postby Ramblin Fever » Mon Apr 19, 2010 10:08 am
Dae - I have the 1.5 gen rodeo with the 265/75 revo's; I haven't lost any mpg on the truck since new, in fact; the truck's original tire size was 225/75 16's.
In town, during spring/summer, I can average 17-19mpg with the automatic; on the highway, with no load (i.e. no boat trailer), I can average anywhere from 19-23mpg, wind depending.
I once attempted to put 245/70's back on the truck just to see if it made a difference in overall power, etc. truck looked funny with the mild lift, and honestly, the only slight power difference was noted at getting on the highway.
I've ran 265's on 16x6 wheels before with no issues; however, I'm now running them on 16x8 wheels.
'97 Rodeo 3.2L V6
Yakima loadwarrior;
Maxlife/K&N
197k strong
Ramblin Fever
Postby Dae » Mon Apr 19, 2010 5:26 pm
Thanks for the info Ramblin Fever. Do you happen to remember your MPG figures with the stock sized tires?
Dae
Postby dman4486 » Mon Apr 19, 2010 5:40 pm
Dae wrote:Thanks for the info Ramblin Fever. Do you happen to remember your MPG figures with the stock sized tires?
I also have the gen 1.5 and stock tires for mine were 245 70 16 which is what are still on it.
last tank I got 18.8 mpg city.
-Darren
GET YOUR PLANETZOO STICKERS HERE: http://forum.planetisuzoo.com/viewtopic.php?f=1&t=38212&hilit=planet+isuzoo+sticker
1996 Honda Passport EX up 3" on 285 75's (33's) http://forum.planetisuzoo.com/viewtopic.php?f=15&t=38631&hilit=dman%27s+passodeo
-Now with Onboard AIR! http://forum.planetisuzoo.com/viewtopic.php?f=15&t=38631&start=225#p746416
2012 Audi A3 2.0T 6MT
2007 Honda Shadow 583 w/ mods
1973 Ford Maverick(drag) <--- It has been decided that this motor will go in the Passport when my SOHC blows up.
dman4486
Has thanked: 4 times
Have thanks: 14 times
Postby Oyaji_Jon » Mon Apr 19, 2010 9:51 pm
Dae wrote:Thats awesome! Were there any issues with rubbing? Any trimming required? Im just gna score them at the discount tire a few blocks away from me.
No trimming or rubbing, whatsoever...
I ran around with 2001 Trooper springs in the rear. The truck had a slight rake because I never cranked the front up. I towed trailers A LOT with that rig, and as soon as I put the load on the hitch, the rear would level out. The Trooper spring rate was perfect for pulling my 16' bass boat or the multi-state uhaul pulls I made 3 times.
Oyaji_Jon
1990 Trooper
Oyaji_Jon
Trail Rider
Postby Dae » Tue Apr 20, 2010 12:54 am
Why are 245/75's Revo 2's cheaper than all the other sizes I want? Heres what I got from discount tires site for pricing
245/70/16 $135
245/75/16 $126
265/70/16 $148
265/75/16 $169 or $200 for LT's
Is there a big difference between 245/75's and 265/70's? I would be saving about $88 if I go with the 245/75, and only sacrifice 0.1" in tire size. Anyone care to help me understand?
Dae
Postby Ramblin Fever » Tue Apr 20, 2010 1:46 am
Dae - the gas mileage on my truck has never changed, even when new with stock tires.
As for the difference of the 245/75's versus the 265/70's, the 265's will look a tad wider, but the 75's will take on a very slight taller appearance.
On my truck with 8" rims, it's very noticeable between the 2 width's; on 6" rims that I had before, it was not as noticeable.
Make sure you get LT tires, irregardless of the size you choose. You really want to get the C-load rating or 6-ply's; they will last quite a bit longer then the P-rated tires. They will also have a deeper starting tread depth, and better for off-road use.
'97 Rodeo 3.2L V6
Yakima loadwarrior;
Maxlife/K&N
197k strong
Ramblin Fever
Return to Wheels & Tires
Users browsing this forum: wordfan and 3 guests
