I think we need a chart
What fits and What performs
Re: I think we need a chart
Postby 01StormTrooper » Sun Nov 10, 2013 3:00 am
Hello all. I am sure there is a thread on here jam packed with pictures. However, this thread states that I can run 285/75r16 on my trooper without a lift. Will someone post/repost their pictures here. Thanks I purchased my trooper less than a week ago and I have been very impressed with its performance so far but the 245/75 look awful imo in those wheel wells.
01StormTrooper
Postby Ripah28 » Wed Mar 19, 2014 11:39 am
good on the chart ya helped a lot of folks out I bet......................01 stormtrooper...........there ya go 285s with no lift ........all the of those pics are before I did coils and a crank
96 trooper
4" susp lift
285 guard dogs
HD tie rods
..................NO ROAD NO PROBLEM
Ripah28
Trail Scout
Have thanks: 9 times
Postby masona7 » Thu Jun 05, 2014 10:49 am
I was looking at the chart and I was wondering how much things change based on rims. I have a 2002 Isuzu Rodeo V6 5-speed that I recently picked up and I want to do it up right; functionality and looks. I want to run 32 inch Falken Wild Peaks, a good all-terrain since it's my daily driver. I also ordered 15 inch rims, I think they look better but they're 15x8; which I think is an inch wider than stock rims. They came in 3.5 backspacing, which I figured would give me a little extra to avoid trimming, but they're special order and it'll take 6-8 weeks. The 3.75 backspacing is kept in stock, are the others worth the wait or should I just go with the 3.75?
masona7
Postby zimm » Mon Feb 09, 2015 7:10 pm
the lack of a backspacing column on the chart is fatal. most trucks ive had interfered on the frame at lock, and 15 mm of negative offset would cure the issue for the next size up tire. i dont know about troopes though, and really cant glean that from the chart.
zimm
Have thanks: 6 times
Postby paulevans76 » Tue Feb 10, 2015 5:44 pm
I think specific amounts of body and suspension lift are really important. If you crank up your torsion bars 3", your tire is still going to travel back up into the fenderwell the same distance as if you had no lift. With a body lift, you are moving the body away from the centerline of the suspension travel range of motion, and you can probably "use" the full range of motion with a larger tire better than you would with just a torsion bar crank suspension lift. A combination will likely provide enough of the best attributes of both to give you a more useful setup overall.
For this post the author paulevans76 was thanked by:
superswire
Has thanked: 61 times
Have thanks: 76 times
31x11.50-15s Lift/No Lift? 2001 Rodeo Sport
Postby bjlindsey » Tue May 12, 2015 9:58 pm
31x11.50-15s Lift/No Lift? 2nd Gen Amigo
Anybody running this setup? I'm looking for the most tire width for sand, least amount of trimming. Eyeballing 15x8 Sendel S13s w/ -20mm offset and TRXUS STS 31x11.50-15LTs. Trying to figure how bad they will rub just due to the width and if a lift will help or make it worse. Any issues w/ 15 in wheels on a 2nd Gen Amigo? Gonna buy everything online and don't want to have to ship it back!! TIA!!!
Edited Title!
bjlindsey
Postby Fox » Tue May 12, 2015 10:34 pm
31" x 10.50" x 15" BFG Mud Terrain KM2's: 1991 Amigo XS: Ford Ranger Add-a-Leaf + Gabriel Airshocks. Front has ball joint flip and spacer with the torsion bars cranked. Stock wheels, no spacers.
download/file.php?mode=view&id=23869
Fox: the official Non-Forum Troll
Have a question? Things I have first hand experience in.
'91 Amigo : fresh 2.6L 4ze1 . Hybrid rhb5 Turbo . Delta 260 camshaft . 59.5" Wide Track & Big brake front suspension . BJ flip&space . Lokka's front/rear . 31" BFG M/T Km2
I machine parts. BJ spacers, EGR plates, Alignment shims, etc.
For this post the author Fox was thanked by:
bjlindsey
Fox
Super Trooper
Has thanked: 8 times
Have thanks: 10 times
Postby bjlindsey » Thu Jun 18, 2015 5:35 am
FYI... 275/70 16s on 8" wheels with -6 off set needs trimming with no lift!!!!
http://www.discounttire.com/dtcs/wheels/mb_wheels/product/submitProductSize.do?r=AZEINT%7Cpc%7C85234&pc=49393
bjlindsey
Postby PHeller » Mon Jun 29, 2015 3:52 pm
Curious about 15" wheel swaps on 2nd Gen Troopers.
It sounds like a 15x8 wheel with 4" backpacking (-12) should clear the calipers.
With this wheel 15x8-4", on a stock Trooper 2nd Gen, what's the largest tire possible that won't rub?
1997 Isuzu Trooper 3.2L V6 - 5spd Aisin AR-5 - 182,000 Miles - Bone Stock
PHeller
Postby Off-Road_Panda » Tue Jun 30, 2015 4:46 pm
98 Rodeo 2nd Gen (2.2l 2wd :( ). 31x10.5r15 all stock and torsion bars cranked. Just put the new tires on last night. Front fenders needed a tiny trim on the lower inside corner on both sides( I rolled the fender a bit and cut the plastic off). just need to go hit the trails and test them out :twisted:
Off-Road_Panda
Postby Theo » Sat Jul 11, 2015 10:01 am
I know this has probably been covered but...I have 91 Amigo with the vin code for 31x10.5 from factory. Stock wheels and no lift aside from tbar level and bilstien shocks (sway bars removed) and soft bump stops. Trails I run are very tight and so I steer lock to lock constantly and using full articulation provided by the Amigo. If I switch to 32x11.5 will I have any rubbing that minor trimming wont fix. I don't want frame rub or anything that would limit steering or wheel travel. Also, will the offroad performance gains really that great from gaining 1 inch height and 1 inch width? I have been happy with my 31 mud terrains and don't want to effect steering or wheel travel. Any input would be appreciated. Theo
'91 Amigo
'14 Frontier Pro4X
Theo
Postby heckcreek » Tue Jul 14, 2015 8:06 pm
I think we should start a new section for early and late 1st gens due to the track width. My white 86 has 31x10.50x15's on stock 6 or 6.5 inch Isuzu alloys with 3.75" backspacing and the tires rub in the front under full lock and rub in the rear under moderate flex. My black 86 has 245/75/16 Treadwright Guard Dogs that measure out right at 31" tall mounted on 16x8 wheels with 4.5" of backspacing and these tires do not rub at all. Here is a picture of the White 86.
And the Black 86
For Sale 1986 Isuzu Trooper Diesel- Factory diesel swapped for n/a c223 out of a pup, 5 speed. Mods, 31x10.50's, JVC Stereo, and other mods to come.
Wrecked and Sold- 1985 Isuzu Trooper Turbo Diesel- 3rd Gen Rod truck with little rust, A/C, and Power Steering. Only mods so far are Eagle Alloy 16x8 bullet holes with 4.5" BS and 245/75/16 Treadwright Guard Dogs.
heckcreek
Postby truelion07 » Wed Oct 07, 2015 9:18 pm
This is a great idea. I am currently researching what I can run on 16"x8" rims without lifts.
truelion07
Postby truelion07 » Thu Oct 08, 2015 9:49 pm
Anyone know if 265/70R/16 tires will fit on 16x7" wide rims on 2nd gen
Isuzu Rodeo without the need for lifts?
Know of anyone running this setup?
truelion07
Postby bjlindsey » Fri Oct 09, 2015 4:40 am
I think they would rub. My 275/70-16s on 16x8 -6 offset wheels still rubbed the rear of the front fenderwell pretty bad even after the Indy 4x4 3" lift.
bjlindsey
Postby truelion07 » Fri Oct 09, 2015 8:37 am
This chart will be even more helpful if we list metric measurements as well as the standard. And no everyone has the money or wants to do a lift, but need to figure out how big or fat (I'll quote gwana66 here -- 'pool float' style fatness) we can go on tires and rims.
truelion07
Postby gwana66 » Fri Oct 09, 2015 10:20 am
I do appreciate the chart, but real-world results need to include the tire brand and model (tires vary wildly),the wheel offset (I've seen +38 to -10 between stock and aftermarket), and if it rubs, where it rubs. I know that a 245/75r16 on a stock 16x8 +38mm rim does not rub anywhere, and it looks like I have about 1" before contact with the back corner of the front fender with the wheels turned and the mudflaps removed. I seem to still have plenty of clearance to the frame at full lock. I'm going with 265/70r16, which is almost the same diameter as a 245/75, and just 20mm wider. It should be close. If I have to bash a body seam, I will. Will know for sure next week. I have also read that Amigo front fenders have more of a flare than Rodeos and may clear a larger tire, but I haven't verified this.
Even the hubs are manual now.
gwana66
Have thanks: 186 times
Postby novakhun » Fri Nov 20, 2015 4:20 pm
for me even with 1.5" front lift 31" cobra tires doesn't fit in when steering. (amigo 2nd)
Opel Frontera B 2.2TD 2003 Short Y22DTH, 2" lift, Dragon Winch 12000lbs, 245/75 16" Yokohama Geolander G012 AT
novakhun
Postby gwana66 » Fri Jan 22, 2016 2:00 pm
gwana66 wrote:I do appreciate the chart, but real-world results need to include the tire brand and model (tires vary wildly),the wheel offset (I've seen +38 to -10 between stock and aftermarket), and if it rubs, where it rubs. I know that a 245/75r16 on a stock 16x8 +38mm rim does not rub anywhere, and it looks like I have about 1" before contact with the back corner of the front fender with the wheels turned and the mudflaps removed. I seem to still have plenty of clearance to the frame at full lock. I'm going with 265/70r16, which is almost the same diameter as a 245/75, and just 20mm wider. It should be close. If I have to bash a body seam, I will. Will know for sure next week. I have also read that Amigo front fenders have more of a flare than Rodeos and may clear a larger tire, but I haven't verified this.
Forgot to update this. Kumho Road Venture AT51's 265/70R16 on stock 16" +38 wheels do not rub on my 2nd gen Amigo. There is only about 1/2" of clearance to the bulge in the back of the wheel well with the steering wheel turned, so I think this is as big as you can get with no trimming of at least the plastic liner. It would not clear with the mudflaps. I have about 2.5" of lift in front, but I don't think it matters in this case.
gwana66
Postby PPCLI-JIM » Tue Apr 05, 2016 12:57 pm
This is a gen 1 Trooper II (88) with 15 Toyota rims running 31x 10.5 on it just a random pic to help show wheel and arch spacing
97 Rodeo AKA the Pavement Princess.Maybe ill just keep it fairly stock but more capable ... And the 88 Trooper II Christine viewtopic.php?f=15&t=86504
The wild Infantryman is never truly happy in a domesticated role, though they may act like it with their stories of deployments past and the suffering they have endured.
PPCLI-JIM
Trail Rider
Has thanked: 30 times
Postby Luis95LS » Sat May 21, 2016 9:57 pm
1995 Trooper LS (Red) with 3" lift and 255/70R18 on 18x8 Nissan Titan wheels. Hubs bored out to fit.
2002 Trooper S (White) with 3" lift and 255/70R18 on 18x8.5 aftermarket wheels for Chevrolet Tahoe. Hubs bored out to fit.
1995 Trooper LS - 3-1/2" lift w/32" tires. Diff drop, HD tie rods, Bilstein shocks. (Soon DOHC heads) Smittybilt bumper
2001 Trooper S - 3-1/2" lift w/32" tires. HD tie rods, Bilstein shocks
2006 GMC Yukon SLT - 2" lift 33" tires.
Motorcycles, 2005 and 2006 SV650 naked, heavily modified. 2007 Suzuki GSXR1000 streetfighter superbike.
Luis95LS
Trail Rider
Have thanks: 8 times
Postby BlueMilk » Mon Jul 18, 2016 11:00 am
Can confirm. Gen 1 Rodeo/Passport fits 265/75R16 tires with no trimming required. Pictured is my rig so far, with Kumho Roadventure AT51 tires mounted in P265/75R16.
1995 Honda Passport: Bone Stock
Planned Upgrades: Torsion beam crank, Calmini/Indy4x longer shackles
BlueMilk
Postby sirwizpl » Wed Aug 31, 2016 4:51 am
What tires will fit Trooper Magic 91 (short) with 2" lift, now i have 235/75/R15 and rims with 0 offset?
sirwizpl
Postby mmceorange » Sat Nov 12, 2016 4:00 pm
'94 Amigo
3" suspension lift
3" body lift
Aftermarket 15" wheels (don't know backspacing but more than stock, as well as wider)
32x11.5 r15 Cooper Discoverer SST tires
No trimming, No rubbing.
mmceorange
Previous
Return to Wheels & Tires
