I think we need a chart
What fits and What performs
Re: I think we need a chart
Postby shaggydoink » Tue Aug 21, 2012 7:19 pm
The guy I purchased my 91 Trooper from threw in an extra set of wheels/tires that he said was from "another year Trooper" (he didn't know what year exactly). They're nice Goodyear Wrangler GS-As, one looks like it's never been driven on! The tire chart lists:
1st gen Troopers (and Trooper II's)
no lift- 33x10.50x15
Confirming that this means that 30 x 9.50 R15's will be no problem with no lift? i.e: this lists the MAX size that fit without a lift? Thanks in advance!
Has thanked: 726 times
Have thanks: 377 times
Postby Selahdoor » Wed Aug 22, 2012 6:05 pm
shaggydoink wrote:Confirming that this means that 30 x 9.50 R15's will be no problem with no lift? i.e: this lists the MAX size that fit without a lift? Thanks in advance!
Yes.
-Jeff
1988 Trooper LS. 4ZE1. mua5.
For this post the author Selahdoor was thanked by:
Selahdoor
Forum Admin
Has thanked: 94 times
Have thanks: 165 times
Postby shaggydoink » Wed Aug 22, 2012 6:16 pm
Rock on, thanks Jeff - appreciate it!
Postby Moses » Wed Sep 19, 2012 5:24 pm
First, this chart is awesome and saved me a major headache. Second, how much of a difference will it make if I was using a 15" wheel on a 1st gen with no lift, as opposed to a 16" wheel? I wouldn't think it would be an issue really. The wheel back spacing is the same.
1993 Isuzu Rodeo 4X4 3.2L V6 - Daily driven.
1996 Honda Civic - Crushed. If I can't have it no one can.
2008 Mazdaspeed 3 - Gone.
2009 Mazda 3 - Wrecked by the wife. Gone.
Moses
Trail Rider
Have thanks: 7 times
Postby Moses » Wed Sep 19, 2012 6:06 pm
Just to clarify, I just ordered a set of 31x10.5R15. They should fit my 93 Rodeo 4x4 without a lift, right?
Moses
Trail Rider
Postby Moses » Thu Sep 20, 2012 5:14 pm
Disregard my previous posts. 31x10.5R15 fit a 93 Rodeo 4x4 perfectly. No rubbing, no cutting or bending required. Looks great too.
Moses
Trail Rider
Postby spinixguy » Sun Nov 04, 2012 10:37 am
I can verify that yokohama geolander ats 265/70r16's will fit a stock 2001 rodeo sport. I had to remove the front mud flaps though. It barely rubs on the passenger side. I might be able to take a hammer to it but I figured it would just be easier to remove the flaps for a few months until the tire wore down a little.
01 Rodeo Sport 3.2L
91 Trooper 2.8L - sold
spinixguy
Rodeo King
Postby outoway » Sun Dec 02, 2012 2:37 am
Ok, Just checking to see if I'm getting this correct.... if 32-11.5 R16 (265/75R16) w/no lift- , then the skinnier 235/85 r16 (31.7x9.3/16) should fit as well. (1st Gen Rodeo)
95 Rodeo 3.2 autoshmatic ... mod to come!
outoway
Postby wranglah » Wed Dec 12, 2012 5:38 pm
so, just to clarify, if i look at the chart in regards to maximum tire size, it says for the second generation Amigos:
3 inch lift-305/70R 16 (33x12.50r15)(trimming required)
so, my question is, I am planning on installing a independent4x.com 3" lift kit in the next few weeks and will be purchasing new tires as well so if i use the above info than a 305/70/16 will require trimming with a 3" lift, but I plan on using a 265/75/16 tire......so will i need to do any trimming for that size as it is smaller than the 305?
wranglah
Has thanked: 2 times
Postby hitman92499 » Tue Jan 22, 2013 5:08 pm
1998 Rodeo, 3.2, 5 speed, 4x4 won't clear 31's without removing mudflaps and factory running boards (if you have them like I do.) Not sure if this has been brought up or not, but I tried fitting them on because I got a whole brand new set for next to nothing...but no go. :( Ended up sticking with stock tire size: 235/75R15 Cooper Discoverer AT/3...love them.
hitman92499
Postby corey5988 » Fri Feb 08, 2013 11:36 pm
You guys think I'd be ok with a 285/75-16 on a 4.5" BS / 0 offset wheel with no body lift? It's a '96 Rodeo and I'd make shackles and crank the bars to suit.
corey5988
Postby jeff5150 » Mon Mar 11, 2013 7:16 pm
ok, i have read this entire post and it is filled with great info... but i have a question. i was given a set of 265/75/16 wrangler rt/s about 50ish% tread left. as of now i have no lift(2000 rodeo 4wd), but will be doing either trooper springs or ome913 and torsion crank in the near future. i have no plans of taking these tires off road til i get the lift but im in a situation that i have to put them on now. bad ball joints did the current tires in but i did get over 50k out of them. i know i have to do some trimming, thats no big deal, but will i be able to run these without the lift and with trimming for the time being? all highway/city/interstate til its lifted. some help asap is greatly appreciated as i have to mount these either tomorrow or saturday.......
thanks!!!
jeff
silver 2000 rodeo ls 4x4
Global Moderator
www.easttnbikers.com
jeff5150
Postby bbast » Tue Mar 19, 2013 12:32 am
ok as usual i am late to the dance. i jst got turnd-on to the tire list and saw the linkd pix. hella great job! i feel lik i can mke bettr choices and be more informed when shoppin for tires, especially @ shops. i seem to wnna go w/ wht the sales person is spewin/pushin and now can be more proactive in wht "I" want. thanx to the posters for the work and info u put into this.
bbast
Has thanked: 19 times
Postby superswire » Sat Mar 23, 2013 4:28 am
I dont know if it even helps at all but im running 33x12.50-15 on a 94 rodeo with just about 2" of lift, stock steel wheels and only rubbing is just a little on the power steering box but ive adjusted my steering end stops to prevent that, prob run 35s with no front bumper as stiff as the damn front end is on this thing, i want my cushy, flexy trooper back !!!
1999 vx, magnaflow, k&n drop-in, ome coils, 2" diff drop, rancho 9x, Darlington bump stop extensions, tones hidden hitch, reese basket on facory Yakima bars, mb razors w/ 33x12.50 Hercules M/T. (Currently undergoing a heart transplant because she seized up on me)
1999 rodeo ls, mua5, Moog cc784, Reese basket, 31x10.50 and some stickers !
Past zu's: '92 migo, '95 troop, '93 rodeo, '97 passport.
superswire
Has thanked: 29 times
Postby Storz » Tue Jul 30, 2013 8:12 pm
Anyone know if a 2nd gen Rodeo will clear 235/85/16 (32x9.5) tires with just a 1.5" coil spacer in back, and matching Tbar crank? I really want to run this set up as I don't want a lot of lift, but want to run those tires....
2000 Rodeo 3.5L MUA5
Storz
Trail Rider
Have thanks: 9 times
Postby Kable » Sat Aug 24, 2013 3:50 pm
Wanna link this image to the chart?
1993 Rodeo 4wd S Auto - LT265/75/16 - 10 Ply Nexen MT - Direct Bolt On - Alot Of Clearance Left - 16x7.5 Snowflakes.
Kable
Postby zudorf » Sat Aug 24, 2013 5:39 pm
I have recently procured a full set (5) of 16" snowflakes. What is the maximum tire size I can use without rub at stock height?
Thanks in advance. :)
Tim
1988 Trooper II SE daily driver and hobby viewtopic.php?f=15&t=68526
I want my last words to be,"Hey, y'all, watch this!"
Namaste.
zudorf
Has thanked: 76 times
Have thanks: 79 times
Postby Kable » Sat Aug 24, 2013 5:45 pm
zudorf wrote:I have recently procured a full set (5) of 16" snowflakes. What is the maximum tire size I can use without rub at stock height?
Play with this before jumping to a size. Dont go by year, make model. Look below it and enter the tire size you have right now.
http://www.1010tires.com/Tools/Tire-Size-Calculator
For this post the author Kable was thanked by:
zudorf
Kable
Postby Kable » Sat Aug 24, 2013 5:49 pm
The other link will tell you how much you can expect the speedo to be off and alot of other good info. See this thread for pics of what your asking.
http://forum.planetisuzoo.com/viewtopic.php?t=39756
Kable
Postby zudorf » Sat Aug 24, 2013 6:49 pm
Well, that was fun. If we all followed the 3% rule, we'd be riding around on stock tires. Oh well, looks like 265/75/16's are in order. Just wish I knew how big I could go without rubbing.
Tim
Namaste.
zudorf
Postby Kable » Sun Aug 25, 2013 6:06 am
zudorf wrote:Well, that was fun. If we all followed the 3% rule, we'd be riding around on stock tires. Oh well, looks like 265/75/16's are in order. Just wish I knew how big I could go without rubbing.
Once you do find the tire size use this link as it will tell you a bit more info plus ride height increase.
http://www.willtheyfit.com/
Remember if you rub on the street then your tire may become permanently stuck when it flexes offroad ;)
Example
Kable
Postby zudorf » Sun Aug 25, 2013 7:36 am
After a little more research, I learned that going with 245/75/16 or 70/16 will optimize my mileage and road performance. My rig is mainly a work truck. I don't do much off-roading. The 4WD is used for the snow and occasional steep, washed out, dirt road. When I grow up, I'll build one for the trails.
Tim
Namaste.
zudorf
Postby Kable » Sun Aug 25, 2013 8:23 am
zudorf wrote:After a little more research, I learned that going with 245/75/16 or 70/16 will optimize my mileage and road performance. My rig is mainly a work truck. I don't do much off-roading. The 4WD is used for the snow and occasional steep, washed out, dirt road. When I grow up, I'll build one for the trails.
What size do you currently have on it. Did you see my thread in the General area
Kable
Postby zudorf » Sun Aug 25, 2013 8:44 am
I've got 31x10.5x15's on it right now. Not the tire for optimum mileage and/or performance. I've got a certificate for 4 new tires from the Yokohama plant here in Salem that I won at a golf tournament. Don't want to waste that opportunity. Guess I'll be ordering the 245/75/16 Geolanders on Monday.
Haven't seen that thread yet. Going to check it out now.
Tim
Namaste.
zudorf
Postby CeeKay » Wed Sep 04, 2013 2:25 pm
Still no info for the Pickup, I see...
Is it safe to guesstimate the 4x4 90's P'up based on 1st gen Rodeo numbers? Reading the old build thread by Little Gray, it would seem 32" on snowflakes with no lift fit with no problems... Sort of wondering if 1" (33's) would cause problems...
- CK
'94 Isuzu P'up 4x4 =Build Thread= :D
'90 Isuzu P'up 2x4 =Mini-truck project, forever a project= :)
'92 Isuzu P'up 2x4 =Sold many a year ago=
Isuzus aren't few because they're junk; Isuzus are few because they're so damn good!
- Rutherford B. Hayes
CeeKay
Return to Wheels & Tires
