I think we need a chart
What fits and What performs
Postby FillsTrooper » Wed Feb 02, 2011 11:23 pm
RustyZu wrote:Just looking at my stock Gen1 trooper...can it really fit 33's? Without rubbing? I'm throwing my 31's from my Toyota on the Trooper today... getting 33's on the Yota.
The 1989 and earlier must be different than the 1990-91 first gens Because
33s will not fit without trimming and hammering the body. That is if you want to turn the wheels with out catching the floorboard and would like your your rear suspension to flex.
I do not consider the tires to fit if they only don't hit the fenders when driving down a flat road with the wheels straight.
1990 Trooper: Owned for 12 years but it sat for almost 7 recently upgraded indy shackles, bushings, bumpstops, shocks, extended SS brakelines. New ball joints, bearings, CVs, manual hubs... and looking for tires.
FillsTrooper
Postby Bikesrcool » Thu Feb 03, 2011 1:17 am
i have a 4 1/2 lift on my 1st gen rodeo and 31's are like big enough i could prob get 32's but no way 34's
Bikesrcool
Postby RamAirZ » Fri Feb 04, 2011 5:56 pm
Bikesrcool wrote:i have a 4 1/2 lift on my 1st gen rodeo and 31's are like big enough i could prob get 32's but no way 34's
Bigpoppa runs 34x10.50's but he's running about 5" suspension and 3" body lift as I recall.
Current: 2004 GMC Sierra- slightly modded, baja style :twisted:
2002 Isuzu Rodeo Sport- 3.5 swap, 3.5" lift, 32's, LED pods, custom exhaust
Previous: 1999 Isuzu Vehicross/1997 Isuzu Rodeo/ 1995 Honda Passport
RamAirZ
Have thanks: 27 times
Postby rwhockey29 » Wed May 04, 2011 6:27 pm
if it helps, ive got a 92 trooper 4x4. 3" body lift, stock suspension, and it fits 35x12.50x15's. the wheels are aftermarket, i need to measure the backspacing and width tonight
1988 Ramcharger: 5.2, 4x4, 4spd.
1992 Trooper: DOHC 3.2, 4x4, auto.
rwhockey29
Postby joeisuzu? » Wed Jun 22, 2011 7:38 pm
Can anyone answer the question will a 265/75-16 BF Mud T/A on a stock wheel fit a second generation Passport with a 3" lift with no trimming? What it I used spacers? If not on a stock wheel what size wheel/offset combo should I look for? A local guy has these tires on Craigslist practically for free.
1999 Honda Passport 4x4
Stock for Now!
joeisuzu?
Postby littlegray » Wed Jun 22, 2011 10:06 pm
I installed 265/75/16 BF KM2 tires on my 1992 Pickup (same as rodeo) with no lift on stock 16" snowflake wheels. They don't rub anywhere even at full flex - no trimming.
1992 Isuzu Pickup - 3.1L V6 - 5 Speed - 4WD : Revenge Fab Winch Bumper + Rear Tube Bumper + Sliders + Exo/Rack, Warn m8000 + Wireless Controls + Amsteel Blue Sythetic, Yellow Top, CB w/ weather, Alpine Deck w iPod, BFG KM2 33x10.5s, 15" Snowflakes, Matching Spare w/ Custom Tire Carrier, Thule Rack w/ bike carrier, Diamond Plate Tool Box, ARB RTT, ARB Compressor, 4.56 Gears, ARB Locker Front & Rear, OME Springs/Shackles/Bushings/Shocks, Sway-a-way Torsion Bars, Ball Joint Flip, SS Brake Lines, Big Brake Upgrade, Ball Joints/Bearings/Seals/rotors/pads, HD Tie Rods, Exedy Clutch, Revolution 3:1 tcase gears - Build Thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=53023
http://www.gitout.com - Off Road Enthusiasts
littlegray
Trail Scout
Postby joeisuzu? » Wed Jun 22, 2011 11:48 pm
I dont think there's a problem on 97 and earlier trucks, but the second generations appear to be the problem.
Stock for Now!
joeisuzu?
Postby chuffer » Mon Jul 25, 2011 2:52 pm
I don't know how much traffic this sub-forum gets so I also posted this as a new topic:
I know that the chart says, "yes," but can I really run 33x1050s on a Gen I Trooper with no rubbing even at full flex?
I measured and the tires will fit in the wheel wells front and back. I am not too worried about power or speed otherwise I wouldn't own a Trooper II in the first place.
What does worry me is wheel-travel and rubbing when driving offroad. I think the back should be fine, but the front looks like it might be tight. So, with the steering at full lock and the LCA on the bump stop, do 33x1050s rub?
Also, what size rim (width and backspacing) are folks using for this tire size?
Thanks in advance.
chuffer
Has thanked: 48 times
Have thanks: 112 times
Re:
Postby holger » Wed Sep 14, 2011 2:39 pm
Please add the Axiom information to the chart:
235/75-17 - no lift, no trimming (31" tire); this is the largest tire that can fit without trimming;
255/75-17 - 4" lift, lots of trimming (plastic and metal) (32.5" tire); anything larger would require a body lift.
Oleg
Axiom 4WD 2004
ARB front locker; No-Slip rear; bent rear flexible links; TC coils, 2" spacers; extra long shocks; adjustable track bar; IronMan torsion bars; etc
holger
Has thanked: 30 times
Have thanks: 42 times
Re: I think we need a chart
Postby Ian1006 » Sat Oct 01, 2011 1:45 am
Maybe make a note on the first gen Rodeo part that a Passport will not fit the same size tires as the rodeo in the front and back due to the fender flares without trimming them.
97 Honda Passport EX Auto to Manual Converted
G80 Dana 44
TreadWright Guard Dogs 265/70/16 on Snowflakes w/ matching spare
Sensa-trac shocks
Aisin Manual hub conversion
Lifted 2 inches front / add a leaf and custom shackles for 3 inches rear
DIY tie rod protectors
5W40 Rotella T6 / Wix filters
Build thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=51622
Ian1006
Have thanks: 11 times
Postby ScrapTrooper » Mon Oct 17, 2011 2:30 pm
I dont know if i have back spacing? can someone explain this so i can tell.
I have a 95 passport and put a 2" lift kit on it.
My cousin in law has some tires hes gonna sell me (cuz hes now going with 35's) and I would like to know if they will fit and if not what has to be done to make em fit.
They are 32x11.50x15
Thanks all!
ScrapTrooper
Postby jon90troop » Mon Oct 24, 2011 11:54 pm
I think Im about to try 33x12.5's on a 1st gen. trooper with a 2 1/8" lift. after market rims (not sure on the back spacing) Ill let you know. :D
1990 trooper, 4ZE1 2.6l mfi, 5 speed manual MUA5, rear shackels, about 3" suspension and 3" body lift, 35's on 15x7 eagles. Gas guzzlin four banger!
jon90troop
Have thanks: 8 times
Postby Mahogan » Sat Dec 10, 2011 2:22 pm
Re:
Unread postby holger » Wed Sep 14, 2011 2:39 pm
Does anyone know if a 245/70 - 17 will work with, no rub, no trimming, no lift, no mod? (30.5" Tire, 9.8" tread width) on stock 2002 Axiom wheel.
Spec Chart Here:
http://www.generaltire.com/tires/Grabber-ATsup2-sup
Thanks
Mahogan
Postby holger » Sat Dec 10, 2011 5:49 pm
Mahogan wrote:Does anyone know if a 245/70 - 17 will work with, no rub, no trimming, no lift, no mod? (30.5" Tire, 9.8" tread width) on stock 2002 Axiom wheel.
it may fit but nobody tried, I guess.
Oleg
Axiom 4WD 2004
holger
Postby RedStar » Wed Jan 04, 2012 8:41 pm
Spec Chart Here:
Thanks
It will work, it's the size I currently run.
Roll Tide
'03 Isuzu Axiom - 156K miles (All Black, Everything) - Sold
http://forum.planetisuzoo.com/viewtopic.php?t=52383
'05 Nissan Xterra Off Road Edition - 75K miles (Wifes)
'00 Jeep Cherokee XJ Sport - 101K miles
http://forum.planetisuzoo.com/viewtopic.php?f=14&t=72965
RedStar
Postby 91Suzu » Wed Feb 01, 2012 1:27 pm
Well, if it's any constilation (consolation), I don't have a lift on my '91 Amigo and I'm running 33x12.50R15 mud terrains on my factory Snow flakes and just had to remove the rubber/plastic bumper side covers, cut along the straight edge under the marker light and cut that stuff in front of the tire and trim back the fender towards the cab. She doesn't rub, even when I'm climbing hills and off roading, unless I flex her all the way. (I cut the bump stops so now if I bottom her out she rubs) but if you leave the bump stops normal, you won't have any rub. I drive daily with them 33's on 'er.
So we could add that to the chart if anyone is interested.
1988 Chevy S10 Pickup - modded 4.3L, 10,000lb winch up front, 6,000lb rear with tow package (((Beaten up pretty bad... :( )))
1991 Amigo, 5-speed 4x4, custom mount baja lights, small lift, trimmed fenders, 33.5x12.50R15 mud terrains on the stock rims (No rub amazing enough), stage two racing clutch (Winch and more lights to come) (Working on new paint job) NOW ADDED: Ford Bronco Shocks front and rear, 1" lift and new ball joints, tie rods, bushings...Roof mount lights to come in the next couple weeks.
91Suzu
Super Trooper
Postby 91Suzu » Wed Feb 01, 2012 1:28 pm
Members Rides - '91 Amigo 4x4 5-speed
And you will see what I'm talking about. The rear panels were cut ONLY because there was just sooo much rust eating away at it. So I cut the rust off. xD
91Suzu
Super Trooper
Postby RedStar » Sat Feb 04, 2012 10:26 pm
Anyone ever try a 255/70/17 on an Axiom? May have a decent lead on a great used set, just not sure they'll fit.
Roll Tide
RedStar
Postby holger » Sun Feb 05, 2012 2:05 am
RedStar wrote:Anyone ever try a 255/70/17 on an Axiom? May have a decent lead on a great used set, just not sure they'll fit.
I doubt it will work without cutting. My guess is that it might work so-so on pavement, but it will heavily rub the wheel wells when the front tires articulate on the trails, especially in turns.
Oleg
Axiom 4WD 2004
holger
Postby NastyBoyToothless » Wed Feb 08, 2012 11:24 pm
Hey guys ,
The chart needs to be upgraded because a newbe like me cant dicyper what i need for my first gen 88 trooper II
thank you in advance
NastyBoyToothless
Postby 24fan24-7 » Thu Feb 23, 2012 12:30 pm
So before I pull the trigger I just want to make sure I have this right. I know offset makes a difference but, I want to do a 3" Independent 4x4 rear lift, crank the t-bars and use 265-75-16 on my factory 1999 Honda Passport wheels (16x7). Please give me some input. I've got no problem pounding the inner liner but, do not want to trim the fenders. I know I can probably us 265-70-16 but the tires are'nt as readily avaialble as the 75's.
1999 Honda Passport
Stock Now, Lifted Later
24fan24-7
Postby NastyBoyToothless » Wed Apr 04, 2012 8:40 pm
hey i think we need some kind of convertion charts on out charts because i have a first gen trooper II and never heard of those tire sizes
NastyBoyToothless
Postby Selahdoor » Wed Apr 04, 2012 8:49 pm
NastyBoyToothless wrote:hey i think we need some kind of convertion charts on out charts because i have a first gen trooper II and never heard of those tire sizes
This is what you need.
http://www.dakota-truck.net/TIRECALC/tirecalc.html
-Jeff
1988 Trooper LS. 4ZE1. mua5.
Selahdoor
Forum Admin
Has thanked: 96 times
Have thanks: 165 times
Postby gcwhitewater » Thu Jun 07, 2012 8:35 am
Didn't want to cross post so I am deleting this :) .
1999 Trooper; all stock DD
1990 Trooper; 2.6, 5spd...project to complete with my son
1986 Trooper; 2.3, 5spd (impulse buy)
gcwhitewater
Rodeo King
Postby blackohio » Tue Jul 10, 2012 12:03 am
'95 trooper RS, will if fit 32x11.5x15 on chevy 6-bolt wheels?
blackohio
Drives in Mud
Return to Wheels & Tires
