I think we need a chart
What fits and What performs
Postby Jaybird » Fri Feb 08, 2008 5:03 pm
of what width and size tires will go with what amount of lifts for each truck. like the 32-11.5r16 are max size for a first gen rodeo with no lift and no rubbing. so heres a timplet of different trucks and different lifts so if anyone knows what will work before rubbing gets into it put it on there.
ALL TIRE SIZES LISTED HERE WILL FIT AS SAID WITH A RIM THAT HAS A 3.75 BACK SPACING
1st gen Rodeos
no lift- 32-11.5 R16 (265/75R16) http://i115.photobucket.com/albums/n319 ... 2stock.jpg
1 inch-32-11.5 R16 (265/75R16)
2 inch-33/10.5 R 16 (255/85R16) http://i115.photobucket.com/albums/n319 ... C00941.jpg
3 inch-34x10.5r16
4 inch-
5 inch-
6 inch-
2nd gen Rodeos
no lift- 265/70/16 (31 X 10.50 X 16)
1 inch-265/75/16 (32 X 10.50 X 16)(trimming required)
2 inch-265/75/16 (32 X 10.50 X 16)(trimming required)
3 inch-305/70R 16 (33x12.50r15)(trimming required) http://i115.photobucket.com/albums/n319 ... hlift2.jpg
4 inch-285/75/16 (33 X 11.50 X 16)
5 inch-285/75/16 (33 X 11.50 X 16)
6 inch-34x10.50x15
1st gen Amigos
no lift-32-11.5 R16 (265/75R16)
3 inch-34x10.5 (may require trimming depending on rims)
4 inch-
5 inch-
6 inch-
2nd Gen Amigos (Rodeo Sports)
no lift-265/70/16 (31 X 10.50 X 16)
6 inch-34x10.50x15
1st gen Troopers (and Trooper II's)
no lift- 33x10.50x15
1 inch-
2 inch-
3 inch- 35x13.50r15
4 inch-
5 inch-
6 inch- 35x13.50r15
2nd gen troopers
no lift- 285/75/16 (33 X 11.50 X 16)
1 inch-
2 inch-
3 inch-
4 inch-
5 inch-
6 inch-315/75-16 (35 X 12.50 X 16)
Lets see if we can complete this list.
Image Image
Jaybird
Have thanks: 10 times
Postby trooper4me » Fri Feb 08, 2008 5:38 pm
thats a great idea. I wish I could help a little more but I'm only running stock right now. It will solve a lot of the "what size tire can I fit" threads. :D
www.authenticphotograph.com
'94 Trooper 3.2 Auto DOHC...RIP
'88 Trooper 2.6 5 spd
'70 Toyota FJ40
trooper4me
Super Trooper
Postby strongcones » Fri Feb 08, 2008 6:59 pm
Most larger tire sizes will need some cutting of material from the wheel well also, so you'll want to include that factor in your chart.
My 265/75/16's fit with OME 913 rear coils. Some call 913's a 1" lift, others call it a 2" lift, I'd say it's closer to 2".
So, 2nd gen rodeo, 2" lift fits 265/75/16 (some trimming required).
2000 Rodeo S, 3.2 V6, 4WD, 5spd, 98K, OME 913's, OME Nitrochargers, 265/75/16 Dueler Revos, [email protected] cone, AISINs, Poly swaybar bushings, Detroit Truetrac helical LSD, Everworks rock sliders
strongcones
Postby Gizmo42 » Fri Feb 08, 2008 9:02 pm
It also depends on the wheels. An aftermarket wheel with 3.75" back spacing might require trimming but a 4" back spacing might not. A stock wheel might only need trimmed inside the wheel well where as an aftermarket one might need the fender trimmed as well.
I know Mikes '01 rodeo needed trimming inside the wheel well as well as some trimming of the bottom of the fenders and front bumper to fit 32x11.50-15 on aftermarket wheels with 3.75" backspacing and 3" lift.
--Dave
Gizmo42
Have thanks: 132 times
Postby Jaybird » Sat Feb 09, 2008 12:01 am
alright, the list is coming along. thats great. I think we can make another chart for what will fit with no lift but trimming too. and thanks to whom ever has been updating my original chart. thats going to make it alot easier to read when someone looks at it. thanks again for the help guys. I hope to see it completed one day.
Image Image
Jaybird
Postby trooper4me » Sat Feb 09, 2008 12:32 am
just a suggestion, how about making the type of vehicle text bold or something so it makes it a little easier to see. :D
'70 Toyota FJ40
trooper4me
Super Trooper
Postby squatch » Sat Feb 09, 2008 1:13 am
Also make the list conservative for those who don't want to cut or rub.
My experience 1ST GEN TROOPER....15'x8" wheel with 3.75" or 4" back spacing=31x10.50x15....stock or 32x11.50x15....with 1.5"-2" lift.
2000 2ND GEN TROOPER w factory flares....15"x8" wheels with 4.5"-4.75" backspacing(some 15" wheels won't clear rear brake calipers)=32x11.50x15....with 2"lift. Should be legal with flares(tread doesn't extend past flare, sidewall maybe a little)
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
For this post the author squatch was thanked by:
woodsman1st
squatch
Has thanked: 66 times
Have thanks: 321 times
Postby RodeoRed » Sat Feb 09, 2008 2:37 am
2nd gen rodeo, 3" lift = 33x12.50r15 with trimming
(Former owner of a) '99 Rodeo 3.2 V6 A/T w/ 8" lift, 4.77's, Aussie Locked Rear
33" TrXus MT's, trailgear sliders, pacer flares
CB, superwinch 8000 lb & custom bumper,ProComp lights, custom rack, dents...
http://www.cardomain.com/ride/2231794
RodeoRed
Postby MarkB.NV » Sat Feb 09, 2008 3:19 am
Fabulous, just fabulous!
I'm just a stocker for now, but I do appreciate the documentation plan.
Great idea...
MarkB.NV,
Tan 1986 Trooper, 2.6 / 5 speed, 173K mi.
http://forum.planetisuzoo.com/viewtopic.php?f=15&t=101538
White 1984 Trooper, 1.9 / 4 speed, 89K mi.
http://forum.planetisuzoo.com/viewtopic.php?f=15&t=85764
Sold ... Silver 1990 Trooper, 4 cyl, 5 speed
Sold ... Blue 1989 Trooper, 4 cyl, 5 speed
MarkB.NV
Has thanked: 59 times
Have thanks: 133 times
Postby Jaybird » Sat Feb 09, 2008 4:47 pm
alright. I will do the bold on the names. also I will get the rest of the info put in. I was going to try to make this conservitive so if anything up on the list is going to require any trimming I will put it on there that it requires such or if you know the tire size that will fit I will put that on there. Thanks for the help guys. Im hoping this thread will make it alot easier for everyone to find what they need a little easier when it comes to tires. And for the rim issue, I was going with the factory rim set as the mark of what to look for on tires. I will continue on this list and try to make it easy for everyone to read. I will try to make the rim issue a part of it too so I will work on that as well and try to make that part just as easy to read.
Image Image
Jaybird
Postby Jaybird » Sat Feb 09, 2008 5:02 pm
Ok, new changes have been made. tell me what yall think as well as what you think will fit or not fit. Thanks again for the help on this.
Image Image
Jaybird
Postby ztwenty4door » Sat Feb 09, 2008 5:53 pm
I rub on the frame with my 32x11.50's at full lock
95.5 Isuzu Rodeo,5 speed,39K original miles,3.2 V6,32x11.50 Super Swamper TSL SX,WAI
ztwenty4door
Rodeo King
Postby isuzufool » Sat Feb 09, 2008 9:56 pm
that's probably because super swampers are almost always true deminsion, where all other tire manufacturers like goodyear run a little smaller than what is printed. ie 31" tires are usually at most 30.5" even new, except interco tires.
'89 pickup, 2.6L with .040 over pistons, MUA5 tranny, calmini header, custom air intake, 2.5" exhaust, 3" lift, stock axles, 33" regal trailblazers, aussie lockers, 217k miles and counting, 80k on engine
'88 Trooper II LS, 2.6L automatic (still a work in progress)
'05 F-150 crew cab 5.4L V-8 with custom exhaust and SCT Livewire tuner/monitor :-)
'00 Rodeo LS, 3.2L automatic
CV shafts are made for breaking, right?
isuzufool
Postby Bansil » Mon Feb 11, 2008 7:38 am
how about 33x12.5x15 mud tires (not swampers)
-1" of lift 1st gen amigo,modest fender trimming on rear of front fenders :twisted:
just thought I'd spice it up on a monday :P
La Tortuga...the bus
http://www.skoolie.net/forum/viewtopic.php?f=9&t=12570
The Turtles' site
http://www.cardomain.com/ride/505863/1998-isuzu-rodeo/
My Amigo build "Lowrider"
viewtopic.php?f=1&t=18800&hilit=lowrider
nfpgasmask wrote: I think it looks like a robot penis, but then again, I have a sick mind.
:) Bart
Bansil
Have thanks: 66 times
Postby dsrtrat » Mon Feb 11, 2008 7:43 pm
stock height running 255/55r18 chrome isuzu rims
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety (Benjamin Franklin 1759
'02 Rodeo LS 3.2 4wd,pw,pdl,6 way pds, moon roof, ISC suspension,31" tires w/18" chrome rims and bars (chrome package),in-dash 6 disc changer, tint
dsrtrat
Postby Jaybird » Tue Feb 12, 2008 7:33 pm
Haha bansil, I dont think many people will want to go with that. and for the 18 inch rims, I really havent ever seen a rodeo besides yours dsrtat that has them so idk if Im going to apply this to the chart.
Image Image
Jaybird
Postby Ramblin Fever » Wed Feb 13, 2008 1:32 am
FYI - to add to your growing chart...I saw a 1st generation Rodeo with NO lift running 285/75 R16's, I actually stopped the guy at a red light to ask him personally.
Looked SWEET!
'97 Rodeo 3.2L V6
KC Fogs; Brushguard;
Yakima loadwarrior;
Maxlife/K&N
197k strong
Ramblin Fever
Have thanks: 59 times
Postby mr_spicoli » Wed Feb 13, 2008 2:29 am
I have 265/75 with Trooper springs (should be similar to 913s) and no trimming. I did have to get creative with a BFH and a prybar, but never once cut into the metal. :D
2000 Rodeo LSE (gone) :(
2010 Pathfinder LE
mr_spicoli
Postby eggman » Wed Feb 13, 2008 7:47 pm
Ok, this might be a silly question, but alas I am a noobie (to this board anyways). What are the year breaks for the 1st and 2nd generation of Rodeos, Troopers, and Amigos? Could this be added to the list as well?
Thanks.
96 Rodeo w/V6 Auto....stock...for now
79 IH Scout II 392 EFI, Auto, 36 SS, winch, FS axles, tube doors, 38 gallon fuel tank
eggman
Postby Jaybird » Wed Feb 13, 2008 9:44 pm
1st gen rodeos and amigos are all models up to 97. 2nd gens are later on. as for troopers, 1st gens are up to 91 or 92. 2nd gens are later on.
Image Image
Jaybird
Postby slow96z » Tue Feb 19, 2008 3:01 pm
99 Trooper fits 315/75-16's with 6" of lift. Only rubs in reverse under accelleration, and just barely then.
99 Rodeo, bone stock for now.
slow96z
Trail Rider
Postby Jaybird » Wed Feb 20, 2008 7:32 pm
thanks man. list is updated. anyone else know what tires can fit what lift?? we still need to finish up the first gens quite a bit. and the second gen troopers.
Image Image
Jaybird
Postby Jaybird » Fri Feb 22, 2008 1:58 am
New update for list. there were the tires I was going to get before I just got fired tonight because I wanted to celebrate my friends 18th bday and wanted to go early. Apparently everyone else I work with can do whatever they want and leave early with bs reasons and the one time I want to after a year and a half of never calling in sick and never asking to leave early this is what I get. Apparently this is what I get for doing my job.
Image Image
Jaybird
Postby RodeoRed » Fri Feb 22, 2008 9:52 am
this should be a sticky/hall of fame
here is an idea - for each listing think we could have a link to a pic of a truck running the same set-up?
may be a bit of work but would be very helpful i am sure
RodeoRed
Postby Jaybird » Fri Feb 22, 2008 7:49 pm
alright. I can work on that. whats your truck running?? I will put a pic of it with the size you have (sence its your idea, it sould only be your truck). umm, I can use ztwenty4door's rodeo for the stock size. and thanks for saying this sould be in the hall of fame.
Image Image
Jaybird
Return to Wheels & Tires
