Looking for 16x7 steel wheels with zero-offset - suggestions
What fits and What performs
Postby dma251 » Fri May 19, 2017 12:20 am
I think I want to try the Buckshot P78-16 mudders on my 89 trooper rs, so I will be needing to replace the wheels. I would like to try to find steel wheels of the "expeditionary" style. Lots of little holes around the ring... Essentially a spare-tire wheel. My concern is getting the correct offset. I like the look of the toyota tacoma spare wheel, and it's the correct 16x7, 6x5.5, but I understand they have a positive offset that will narrow my track-width. I have a rootop tent and need all the track-width I can get, which I really liked about the stock 15x7 snowflakes wide stance.
What vehicles might have a steel 16x7 6-lug spare wheel with zero offset? There's three great junkyards nearby, and tomorrow I might be hunting for wheels...
dma251
Re: Looking for 16x7 steel wheels with zero-offset - suggest
Postby dma251 » Fri May 19, 2017 1:04 am
These are the Gateway Buckshot p78-16 mudders on 16x7 steel rims. Think I might just buy a new set of these from summit and be done with it.
dma251
Postby gruff54 » Sun May 21, 2017 7:43 am
Sounds like the wheel that came on the early Troopers. Not sure of the width or offset. Think they call them 9 hole. The original spare on my son's '88 or '89 'Zu pickup is that wheel. Someone on the site offered up a set for sale not too long ago. No link as I didn't bookmark it. :( Will those tires have any clearance issues?
Mike
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54
Has thanked: 33 times
Have thanks: 56 times
Postby gruff54 » Sun May 21, 2017 7:48 am
Here ya go. hth
viewtopic.php?f=2&t=105297
Mike
gruff54
Postby aa79912 » Thu May 25, 2017 10:32 pm
mike I know for a fact Jerry has set..i had asked jerry for a set he had the round holes and I was looking for the slotted ones...give him a shout
aa79912
Has thanked: 4 times
Postby dma251 » Fri May 26, 2017 2:09 am
Unfortunately those are 15", and I'm looking for 16x7. I'm still looking...
dma251
Postby gruff54 » Fri May 26, 2017 6:26 am
Guess I need to pay a little closer attention. :? How about a 6 lug mini-mod trailer wheel? They usually have zero offset. Not sure if they're available with a 7" width. 6", yes.
Mike
gruff54
Postby gruff54 » Fri May 26, 2017 6:33 am
Yep, no offset but only 6" width. Available in silver or white. https://www.nueratrailerparts.com/trail ... -16x6.html
Mike
gruff54
Postby dma251 » Sat May 27, 2017 6:15 pm
Good idea! I'll check that out. I could try galvanized for the ultimate in function at the expense of form, cuz they sure aren't pretty. Thanks for the suggestion!
dma251
Postby dma251 » Sat May 27, 2017 6:28 pm
http://www.ebay.com/itm/16-16-x-7-6-5-5 ... nx&vxp=mtr
I think this is pretty much exactly what I am looking for. The stance should be the same as stock 15x7 snowflakes. The price is great and so is the 3500lbs rating. The Buckshot P78-16 runs 33x10.50-16, so I guess I'll have to get some lift going on... I'll post some pics when I get them together. Thanks!
dma251
Return to Wheels & Tires
