speedo changes
What fits and What performs
speedo changes
Postby Skeletor » Fri May 05, 2017 11:15 am
has anyone noticed a change in their speedo....when they installed much larger tires in their first gen Trooper ?
if so, how much ??
Skeletor
Re: speedo changes
Postby JoeIsuzu » Fri May 05, 2017 12:53 pm
Skeletor wrote:has anyone noticed a change in their speedo....when they installed much larger tires in their first gen Trooper ?
if so, how much ??
You won't see any change in MPH (as indicated on the speedometer) vs RPM. It will change your ACTUAL speed.
Jack
Original owner, 1983 Isuzu P'up LS Diesel. Engine overhauled by JLEMOND. Ready for new paint now!
1994 Isuzu Amigo 2wd
IsuzuPup.com
"There are no dumb questions"?! Maybe not...
but there are smart ways to ask. Old, but classic:
How To Ask Questions The Smart Way
JoeIsuzu
Has thanked: 73 times
Have thanks: 76 times
Re: speedo changes
Postby oldestisuzuist » Fri May 05, 2017 6:47 pm
With larger tires the speed & odometer readings at a given rpm will decrease 3%-4% for each 1" difference in tire diameter within the range of tire diameters that one would normally use. The smaller the tire diameter the greater change percentage per 1" change. At the same time the actual travel speed will increase by the same amount.
A typical new tire has around 16/32" tread depth, so the as the tire wears from new to bald the same variance gradually occurs because the tire diameter decreases about 1".
The speedo reading can be changed by changing the driven gear on the end of the speedo cable to a different tooth count, one tooth difference typically changes the reading by about 5%-6.6%. The smaller the tooth count the greater the change per tooth, fewer teeth increases the speed/odometer readings. Tooth counts range from 15 to 20 that I know of.
'78 LUV, 1.9, headers, 4-spd, SAS Dana 30 front, Dana 20, SOA rear w/Aussie Locker, 31's, serious body cancer, bought new 12/4/78.
'87 Trooper, 2.3, headers, 5-spd, 31's, ball joint flip, Aussie Locker rear, Superwinch hubs, brush guard w/5.5K winch, needs motor, work in progress.
oldestisuzuist
Have thanks: 247 times
Re: speedo changes
Postby JoeIsuzu » Fri May 05, 2017 11:17 pm
We're saying exactly he same thing, but a different way.
Jack
IsuzuPup.com
JoeIsuzu
Return to Wheels & Tires
