1990 Trooper
What fits and What performs
1990 Trooper
Postby Skeletor » Sun Apr 23, 2017 12:54 pm
without raising my trooper.or altering the suspension....largest size to go on a set of snowflake rims....
Skeletor
Re: 1990 Trooper
Postby geoffinbc » Sun Apr 23, 2017 6:14 pm
31's no problem and they wont rub. 33's will dig into the rear fender when the suspension gets compressed but you can stop this with extended bump stops but you limit up travel
geoffinbc
Has thanked: 8 times
Have thanks: 323 times
Re: 1990 Trooper
Postby hessmess » Mon Apr 24, 2017 11:06 am
I have 31's on mine with stock suspension, no problems at all.
88 Trooper (recycled)
viewtopic.php?f=15&t=81567
viewtopic.php?t=55081
hessmess
Have thanks: 144 times
Re: 1990 Trooper
Postby Skeletor » Mon Apr 24, 2017 8:15 pm
geoffinbc wrote:31's no problem and they wont rub. 33's will dig into the rear fender when the suspension gets compressed but you can stop this with extended bump stops but you limit up travel
thanks !
skeletor
Skeletor
Re: 1990 Trooper
hessmess wrote:I have 31's on mine with stock suspension, no problems at all.
thanks !
Skeletor
Skeletor
Return to Wheels & Tires
